[PATCH] ddr: fsl: Make bank_addr_bits reflect actual bits
In both the Freescale DDR controller and the SPD spec, bank address bits are stored as the number of bank address bits minus 2. For example, if a chip had 8 banks (3 total bank address bits), the value of bank_addr_bits would be 1. This is rather surprising for users configuring their memory manually, since they can't set bank_addr_bits to the actual number of bank address bits. Rectify this.
There is at least one example of this kind of mistake already, in board/freescale/t102xrdb/ddr.c. The documented MT40A512M8HX has two bank address bits, but bank_addr_bits was set to 2, implying 4 bank address bits. Such a value is reserved in BA_BITS_CS, but I suspect the controller simply ignores the top bit, making this kind of mistake harmless, if misleading.
Fixes: e8a7f1c32b5 ("powerpc/t1023rdb: Add T1023 RDB board support") Signed-off-by: Sean Anderson sean.anderson@seco.com ---
board/freescale/ls1043ardb/ddr.c | 2 +- drivers/ddr/fsl/ctrl_regs.c | 2 +- drivers/ddr/fsl/ddr4_dimm_params.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/freescale/ls1043ardb/ddr.c b/board/freescale/ls1043ardb/ddr.c index 08b43ff5e4c..4d2fce38412 100644 --- a/board/freescale/ls1043ardb/ddr.c +++ b/board/freescale/ls1043ardb/ddr.c @@ -114,7 +114,7 @@ dimm_params_t ddr_raw_timing = { .mirrored_dimm = 0, .n_row_addr = 15, .n_col_addr = 10, - .bank_addr_bits = 0, + .bank_addr_bits = 2, .bank_group_bits = 2, .edc_config = 0, .burst_lengths_bitmask = 0x0c, diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index b5122d1a1c3..0b0b4e5cb7e 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -214,7 +214,7 @@ static void set_csn_config(int dimm_number, int i, fsl_ddr_cfg_regs_t *ddr, odt_rd_cfg = popts->cs_local_opts[i].odt_rd_cfg; odt_wr_cfg = popts->cs_local_opts[i].odt_wr_cfg; #ifdef CONFIG_SYS_FSL_DDR4 - ba_bits_cs_n = dimm_params[dimm_number].bank_addr_bits; + ba_bits_cs_n = dimm_params[dimm_number].bank_addr_bits - 2; bg_bits_cs_n = dimm_params[dimm_number].bank_group_bits; #else n_banks_per_sdram_device diff --git a/drivers/ddr/fsl/ddr4_dimm_params.c b/drivers/ddr/fsl/ddr4_dimm_params.c index e2bdc12ef2c..ea791622628 100644 --- a/drivers/ddr/fsl/ddr4_dimm_params.c +++ b/drivers/ddr/fsl/ddr4_dimm_params.c @@ -246,7 +246,7 @@ unsigned int ddr_compute_dimm_parameters(const unsigned int ctrl_num, /* SDRAM device parameters */ pdimm->n_row_addr = ((spd->addressing >> 3) & 0x7) + 12; pdimm->n_col_addr = (spd->addressing & 0x7) + 9; - pdimm->bank_addr_bits = (spd->density_banks >> 4) & 0x3; + pdimm->bank_addr_bits = ((spd->density_banks >> 4) & 0x3) + 2; pdimm->bank_group_bits = (spd->density_banks >> 6) & 0x3;
In tag: https://source.denx.de/u-boot/custodians/u-boot-fsl-qoriq/-/tags/fsl-qoriq-2...
Waiting CI results.
Regards, Peng.
- .bank_addr_bits = 2, .bank_group_bits = 2, .edc_config = 0, .burst_lengths_bitmask = 0x0c,
bg_bits_cs_n = dimm_params[dimm_number].bank_group_bits; #else n_banks_per_sdram_deviceba_bits_cs_n = dimm_params[dimm_number].bank_addr_bits - 2;
Peng Fan
Sean Anderson
