[U-Boot] [PATCH 1/3] part: add partition number to disk_partition_t
The FAT filesystem code knows which partition ID it is operating on. Currently, this is passed to fat_register_device() as a parameter. In order to convert FAT to the more standardized fat_set_blk_dev(), the information needs to come from somewhere else, and the partition definition structure is the logical place.
Signed-off-by: Stephen Warren swarren@nvidia.com --- This series is based on the part_efi/dos partition table printing series I just sent.
disk/part.c | 1 + include/part.h | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/disk/part.c b/disk/part.c index a0c77dd..2bc7acb 100644 --- a/disk/part.c +++ b/disk/part.c @@ -391,6 +391,7 @@ int get_partition_info(block_dev_desc_t *dev_desc, int part defined(CONFIG_MMC) || \ defined(CONFIG_SYSTEMACE)
+ info->part = part; #ifdef CONFIG_PARTITION_UUIDS /* The common case is no UUID support */ info->uuid[0] = 0; diff --git a/include/part.h b/include/part.h index 27ea283..ebdebd8 100644 --- a/include/part.h +++ b/include/part.h @@ -88,6 +88,7 @@ typedef struct block_dev_desc { #define DEV_TYPE_OPDISK 0x07 /* optical disk */
typedef struct disk_partition { + int part; /* Partition number */ ulong start; /* # of first block in partition */ ulong size; /* number of blocks in partition */ ulong blksz; /* block size in bytes */
This removes the standalone cur_part_nr variable, opening the way to replacing fat_register_device() with fat_set_blk_dev().
Note that when get_partition_info() fails and we use the entire disk, the correct partition number is 0 (whole disk) not 1 (first partition), so that change is also made here.
An alternative to this (and the previous) patch might be to simply remove the partition number from the printf(). I don't know how attached people are to it.
Signed-off-by: Stephen Warren swarren@nvidia.com --- fs/fat/fat.c | 6 ++---- 1 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index 80156c8..1e0d2a3 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -46,7 +46,6 @@ static void downcase(char *str) }
static block_dev_desc_t *cur_dev; -static unsigned int cur_part_nr; static disk_partition_t cur_part_info;
#define DOS_BOOT_MAGIC_OFFSET 0x1fe @@ -79,7 +78,6 @@ int fat_register_device(block_dev_desc_t * dev_desc, int part_no) /* Read the partition table, if present */ if (!get_partition_info(dev_desc, part_no, &cur_part_info)) { cur_dev = dev_desc; - cur_part_nr = part_no; } #endif
@@ -92,7 +90,7 @@ int fat_register_device(block_dev_desc_t * dev_desc, int part_no) }
cur_dev = dev_desc; - cur_part_nr = 1; + cur_part_info.part = 0; cur_part_info.start = 0; cur_part_info.size = dev_desc->lba; cur_part_info.blksz = dev_desc->blksz; @@ -1235,7 +1233,7 @@ int file_fat_detectfs(void) vol_label[11] = '\0'; volinfo.fs_type[5] = '\0';
- printf("Partition %d: Filesystem: %s "%s"\n", cur_part_nr, + printf("Partition %d: Filesystem: %s "%s"\n", cur_part_info.part, volinfo.fs_type, vol_label);
This makes the FAT filesystem API more consistent with other block-based filesystems. If in the future standard multi-filesystem commands such as "ls" or "load" are implemented, having FAT work the same way as other filesystems will be necessary.
Convert cmd_fat.c to the new API, so the code looks more like other files implementing the same commands for other filesystems.
Signed-off-by: Stephen Warren swarren@nvidia.com --- common/cmd_fat.c | 8 +++--- fs/fat/fat.c | 65 ++++++++++++++++++++++++++--------------------------- include/fat.h | 1 + 3 files changed, 37 insertions(+), 37 deletions(-)
diff --git a/common/cmd_fat.c b/common/cmd_fat.c index 5a5698b..c38302d 100644 --- a/common/cmd_fat.c +++ b/common/cmd_fat.c @@ -55,7 +55,7 @@ int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
dev = dev_desc->dev; - if (fat_register_device(dev_desc,part)!=0) { + if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatload **\n", argv[1], dev, part); return 1; @@ -111,7 +111,7 @@ int do_fat_ls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
dev = dev_desc->dev; - if (fat_register_device(dev_desc,part)!=0) { + if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatls **\n", argv[1], dev, part); return 1; @@ -149,7 +149,7 @@ int do_fat_fsinfo (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
dev = dev_desc->dev; - if (fat_register_device(dev_desc,part)!=0) { + if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatinfo **\n", argv[1], dev, part); return 1; @@ -185,7 +185,7 @@ static int do_fat_fswrite(cmd_tbl_t *cmdtp, int flag,
- if (fat_register_device(dev_desc, part) != 0) { + if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatwrite **\n", argv[1], dev, part); return 1; diff --git a/fs/fat/fat.c b/fs/fat/fat.c index 1e0d2a3..f205df6 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -61,42 +61,12 @@ static int disk_read(__u32 block, __u32 nr_blocks, void *buf) cur_part_info.start + block, nr_blocks, buf); }
-int fat_register_device(block_dev_desc_t * dev_desc, int part_no) +int fat_set_blk_dev(block_dev_desc_t *dev_desc, disk_partition_t *info) { ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buffer, dev_desc->blksz);
- /* First close any currently found FAT filesystem */ - cur_dev = NULL; - -#if (defined(CONFIG_CMD_IDE) || \ - defined(CONFIG_CMD_SATA) || \ - defined(CONFIG_CMD_SCSI) || \ - defined(CONFIG_CMD_USB) || \ - defined(CONFIG_MMC) || \ - defined(CONFIG_SYSTEMACE) ) - - /* Read the partition table, if present */ - if (!get_partition_info(dev_desc, part_no, &cur_part_info)) { - cur_dev = dev_desc; - } -#endif - - /* Otherwise it might be a superfloppy (whole-disk FAT filesystem) */ - if (!cur_dev) { - if (part_no != 0) { - printf("** Partition %d not valid on device %d **\n", - part_no, dev_desc->dev); - return -1; - } - - cur_dev = dev_desc; - cur_part_info.part = 0; - cur_part_info.start = 0; - cur_part_info.size = dev_desc->lba; - cur_part_info.blksz = dev_desc->blksz; - memset(cur_part_info.name, 0, sizeof(cur_part_info.name)); - memset(cur_part_info.type, 0, sizeof(cur_part_info.type)); - } + cur_dev = dev_desc; + cur_part_info = *info;
/* Make sure it has a valid FAT header */ if (disk_read(0, 1, buffer) != 1) { @@ -120,6 +90,35 @@ int fat_register_device(block_dev_desc_t * dev_desc, int part_no) return -1; }
+int fat_register_device(block_dev_desc_t *dev_desc, int part_no) +{ + disk_partition_t info; + + /* First close any currently found FAT filesystem */ + cur_dev = NULL; + + /* Read the partition table, if present */ + if (!get_partition_info(dev_desc, part_no, &info)) { + if (part_no != 0) { + printf("** Partition %d not valid on device %d **\n", + part_no, dev_desc->dev); + return -1; + } + + info.part = 0; + info.start = 0; + info.size = dev_desc->lba; + info.blksz = dev_desc->blksz; + memset(info.name, 0, sizeof(info.name)); + memset(info.type, 0, sizeof(info.type)); +#ifdef CONFIG_PARTITION_UUIDS + memset(info.uuid, 0, sizeof(info.uuid)); +#endif + info.bootable = 0; + } + + return fat_set_blk_dev(dev_desc, &info); +}
/* * Get the first occurence of a directory delimiter ('/' or '') in a string. diff --git a/include/fat.h b/include/fat.h index cc85b06..706cd7a 100644 --- a/include/fat.h +++ b/include/fat.h @@ -212,6 +212,7 @@ long file_fat_read_at(const char *filename, unsigned long pos, void *buffer, unsigned long maxsize); long file_fat_read(const char *filename, void *buffer, unsigned long maxsize); const char *file_getfsname(int idx); +int fat_set_blk_dev(block_dev_desc_t *rbdd, disk_partition_t *info); int fat_register_device(block_dev_desc_t *dev_desc, int part_no);
int file_fat_write(const char *filename, void *buffer, unsigned long maxsize);
Hi Stephen,
- if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatload **\n", argv[1], dev, part); return 1;
- if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatls **\n", argv[1], dev, part); return 1;
- if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatinfo **\n", argv[1], dev, part); return 1;
- if (fat_set_blk_dev(dev_desc, &info) != 0) { printf("\n** Unable to use %s %d:%d for fatwrite **\n", argv[1], dev, part); return 1;
- cur_dev = NULL;
cur_dev = dev_desc;
-#endif
- if (!cur_dev) {
if (part_no != 0) {
return -1;
cur_dev = dev_desc;
cur_dev = dev_desc;
- disk_partition_t info;
- cur_dev = NULL;
- if (!get_partition_info(dev_desc, part_no, &info)) {
This should rather be: + if (get_partition_info(dev_desc, part_no, &info)) {
Here, the code is handling the case of FAT filling the storage device without any partition.
if (part_no != 0) {
return -1;
info.part = 0;
info.start = 0;
info.bootable = 0;
- return fat_set_blk_dev(dev_desc, &info);
- Get the first occurence of a directory delimiter ('/' or '') in
Best regards, Benoît
Benoît Thébaudeau
Stephen Warren
