[U-Boot] [PATCH v4] pci: pcie_imx: Fix hang on mx6qp
PCI driver currently hangs on mx6qp.
Toggle the reset bit with the appropriate timings to fix the issue.
Based on the FSL kernel driver implementation.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v3: - Remove blank line from commit log Changes since v2: - Remove unneeded blank line (Bin)
arch/arm/include/asm/arch-mx6/iomux.h | 2 ++ drivers/pci/pcie_imx.c | 8 ++++++++ 2 files changed, 10 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx6/iomux.h b/arch/arm/include/asm/arch-mx6/iomux.h index 9b3a91f..907cb40 100644 --- a/arch/arm/include/asm/arch-mx6/iomux.h +++ b/arch/arm/include/asm/arch-mx6/iomux.h @@ -18,6 +18,8 @@ #define IOMUXC_GPR1_REF_SSP_EN (1 << 16) #define IOMUXC_GPR1_TEST_POWERDOWN (1 << 18)
+#define IOMUXC_GPR1_PCIE_SW_RST (1 << 29) + /* * IOMUXC_GPR5 bit fields */ diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index 1568f20..f1e189e 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -19,6 +19,7 @@ #include <asm/io.h> #include <linux/sizes.h> #include <errno.h> +#include <asm/arch/sys_proto.h>
#define PCI_ACCESS_READ 0 #define PCI_ACCESS_WRITE 1 @@ -430,6 +431,10 @@ static int imx_pcie_write_config(struct pci_controller *hose, pci_dev_t d, static int imx6_pcie_assert_core_reset(void) { struct iomuxc *iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR; + + if (is_mx6dqp()) + setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_PCIE_SW_RST); + #if defined(CONFIG_MX6SX) struct gpc *gpc_regs = (struct gpc *)GPC_BASE_ADDR;
@@ -536,6 +541,9 @@ static int imx6_pcie_deassert_core_reset(void)
enable_pcie_clock();
+ if (is_mx6dqp()) + clrbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_PCIE_SW_RST); + /* * Wait for the clock to settle a bit, when the clock are sourced * from the CPU, we need about 30 ms to settle.
Changes since v3:
Changes since v2:
- IOMUXC_GPR5 bit fields
- if (is_mx6dqp())
- if (is_mx6dqp())
- Wait for the clock to settle a bit, when the clock are sourced
- from the CPU, we need about 30 ms to settle.
Thanks Fabio - as fix, I pick it up for the release.
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi Stefano,
I don't see this one included in your pull request for Tom.
Thanks
On 15/10/2015 14:23, Fabio Estevam wrote:
Hi Stefano,
Aargh ! Thanks for noting this, I am fixing it.
Regards, Stefano
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Acked-by: Stefano Babic sbabic@denx.de
Fabio Estevam
Fabio Estevam
Stefano Babic
