[PATCH] imx: spl: Fix typo BMODE_EMI -> BMODE_EIM
The interface for NOR/OneNAND is called "EIM" not "EMI". Fix this.
Signed-off-by: Harald Seiler hws@denx.de --- arch/arm/include/asm/mach-imx/sys_proto.h | 10 +++++----- arch/arm/mach-imx/spl.c | 4 ++-- 2 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/sys_proto.h b/arch/arm/include/asm/mach-imx/sys_proto.h index 444834995ed0..804a9b953642 100644 --- a/arch/arm/include/asm/mach-imx/sys_proto.h +++ b/arch/arm/include/asm/mach-imx/sys_proto.h @@ -88,9 +88,9 @@ struct bd_info; #define IMX6_SRC_GPR10_PERSIST_SECONDARY_BOOT BIT(30)
#define IMX6_BMODE_MASK GENMASK(7, 0) -#define IMX6_BMODE_SHIFT 4 -#define IMX6_BMODE_EMI_MASK BIT(3) -#define IMX6_BMODE_EMI_SHIFT 3 +#define IMX6_BMODE_SHIFT 4 +#define IMX6_BMODE_EIM_MASK BIT(3) +#define IMX6_BMODE_EIM_SHIFT 3 #define IMX6_BMODE_SERIAL_ROM_MASK GENMASK(26, 24) #define IMX6_BMODE_SERIAL_ROM_SHIFT 24
@@ -105,13 +105,13 @@ enum imx6_bmode_serial_rom { IMX6_BMODE_I2C3, };
-enum imx6_bmode_emi { +enum imx6_bmode_eim { IMX6_BMODE_NOR, IMX6_BMODE_ONENAND, };
enum imx6_bmode { - IMX6_BMODE_EMI, + IMX6_BMODE_EIM, #if defined(CONFIG_MX6UL) || defined(CONFIG_MX6ULL) IMX6_BMODE_QSPI, IMX6_BMODE_RESERVED, diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index 427b7f785990..2832b7350964 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -57,9 +57,9 @@ u32 spl_boot_device(void) /* BOOT_CFG1[7:4] - see IMX6DQRM Table 8-8 */ switch ((reg & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) { /* EIM: See 8.5.1, Table 8-9 */ - case IMX6_BMODE_EMI: + case IMX6_BMODE_EIM: /* BOOT_CFG1[3]: NOR/OneNAND Selection */ - switch ((reg & IMX6_BMODE_EMI_MASK) >> IMX6_BMODE_EMI_SHIFT) { + switch ((reg & IMX6_BMODE_EIM_MASK) >> IMX6_BMODE_EIM_SHIFT) { case IMX6_BMODE_ONENAND: return BOOT_DEVICE_ONENAND; case IMX6_BMODE_NOR:
Reviewed-by: Fabio Estevam festevam@gmail.com
The interface for NOR/OneNAND is called "EIM" not "EMI". Fix this. Signed-off-by: Harald Seiler hws@denx.de Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
Harald Seiler
sbabic@denx.de
