[U-Boot-Users] [PATCH] Fix fdt set command to conform to dts spec
The fdt set command was treating properties specified as <00> and <0011> as byte streams, rather than as an array of cells. As we already have syntax for expressing the desire for a stream of bytes ([ xx xx ...]), we should use the <> syntax to describe arrays of cells, which are always 32-bits per element. If we imagine this likely (IMHO) scenario:
fdt set /ethernet-phy@1 reg <1>
With the old code, this would create a bad fdt, since the reg cell would be made to be one byte in length. But the cell must be 4 bytes, so this would break mysteriously.
Also, the dts spec calls for constants inside the angle brackets (<>) to conform to C constant standards as they pertain to base. Take this scenario:
fdt set /ethernet@f00 reg <0xe250000\ 0x1000>
The old fdt command would complain that it couldn't parse that. Or, if you wanted to specify that a certain clock ran at 33 MHz, you'd be required to do this:
fdt set /mydev clock <1f78a40>
Whereas the new code will accept decimal numbers.
While I was in there, I extended the fdt command parser to handle property strings which are split across multiple arguments:
fdt set /ethernet@f00 interrupts < 33 2 34 2 36 2 > fdt p /ethernet@f00
ethernet@f00 { interrupts = <0x21 0x2 0x22 0x2 0x24 0x2>; };
Lastly, the fdt print code was rearranged slightly to print arrays of cells if the length of the property is a multiple of 4 bytes, and to not print leading zeros.
Signed-off-by: Andy Fleming afleming@freescale.com --- common/cmd_fdt.c | 137 ++++++++++++++++++++++++++--------------------------- 1 files changed, 67 insertions(+), 70 deletions(-)
diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index a52284e..7436a95 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -42,8 +42,7 @@ DECLARE_GLOBAL_DATA_PTR;
static int fdt_valid(void); -static int fdt_parse_prop(char *pathp, char *prop, char *newval, - char *data, int *len); +static int fdt_parse_prop(char **newval, int count, char *data, int *len); static int fdt_print(const char *pathp, char *prop, int depth);
/* @@ -202,7 +201,7 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) if (argc == 4) { len = 0; } else { - ret = fdt_parse_prop(pathp, prop, argv[4], data, &len); + ret = fdt_parse_prop(&argv[4], argc - 4, data, &len); if (ret != 0) return ret; } @@ -464,69 +463,77 @@ static int fdt_valid(void)
/* * Parse the user's input, partially heuristic. Valid formats: - * <00> - hex byte - * <0011> - hex half word (16 bits) - * <00112233> - hex word (32 bits) - * - hex double words (64 bits) are not supported, must use - * a byte stream instead. + * <0x00112233 4 05> - an array of cells. Numbers follow standard + * C conventions. * [00 11 22 .. nn] - byte stream * "string" - If the the value doesn't start with "<" or "[", it is * treated as a string. Note that the quotes are * stripped by the parser before we get the string. + * newval: An array of strings containing the new property as specified + * on the command line + * count: The number of strings in the array + * data: A bytestream to be placed in the property + * len: The length of the resulting bytestream */ -static int fdt_parse_prop(char *pathp, char *prop, char *newval, - char *data, int *len) +static int fdt_parse_prop(char **newval, int count, char *data, int *len) { char *cp; /* temporary char pointer */ + char *newp; /* temporary newval char pointer */ unsigned long tmp; /* holds converted values */ + int stridx = 0;
- if (*newval == '<') { - /* - * Bigger values than bytes. - */ - *len = 0; - newval++; - while ((*newval != '>') && (*newval != '\0')) { - cp = newval; - tmp = simple_strtoul(cp, &newval, 16); - if ((newval - cp) <= 2) { - *data = tmp & 0xFF; - data += 1; - *len += 1; - } else if ((newval - cp) <= 4) { - *(uint16_t *)data = __cpu_to_be16(tmp); - data += 2; - *len += 2; - } else if ((newval - cp) <= 8) { - *(uint32_t *)data = __cpu_to_be32(tmp); - data += 4; - *len += 4; - } else { + *len = 0; + newp = newval[0]; + + /* An array of cells */ + if (*newp == '<') { + newp++; + while ((*newp != '>') && (stridx < count)) { + /* + * Keep searching until we find that last ">" + * That way users don't have to escape the spaces + */ + if (*newp == '\0') { + newp = newval[++stridx]; + continue; + } + + cp = newp; + tmp = simple_strtoul(cp, &newp, 0); + *(uint32_t *)data = __cpu_to_be32(tmp); + data += 4; + *len += 4; + + /* If the ptr didn't advance, something went wrong */ + if ((newp - cp) <= 0) { printf("Sorry, I could not convert "%s"\n", cp); return 1; } - while (*newval == ' ') - newval++; + + while (*newp == ' ') + newp++; } - if (*newval != '>') { - printf("Unexpected character '%c'\n", *newval); + + if (*newp != '>') { + printf("Unexpected character '%c'\n", *newp); return 1; } - } else if (*newval == '[') { + } else if (*newp == '[') { /* * Byte stream. Convert the values. */ - *len = 0; - newval++; - while ((*newval != ']') && (*newval != '\0')) { - tmp = simple_strtoul(newval, &newval, 16); + newp++; + while ((*newp != ']') && (stridx < count)) { + tmp = simple_strtoul(newp, &newp, 16); *data++ = tmp & 0xFF; *len = *len + 1; - while (*newval == ' ') - newval++; + while (*newp == ' ') + newp++; + if (*newp != '\0') + newp = newval[++stridx]; } - if (*newval != ']') { + if (*newp != ']') { printf("Unexpected character '%c'\n", *newval); return 1; } @@ -535,8 +542,11 @@ static int fdt_parse_prop(char *pathp, char *prop, char *newval, * Assume it is a string. Copy it into our data area for * convenience (including the terminating '\0'). */ - *len = strlen(newval) + 1; - strcpy(data, newval); + while (stridx < count) { + *len = strlen(newp) + 1; + strcpy(data, newp); + newp = newval[++stridx]; + } } return 0; } @@ -593,7 +603,6 @@ static int is_printable_string(const void *data, int len) static void print_data(const void *data, int len) { int j; - const u8 *s;
/* no data, don't print */ if (len == 0) @@ -616,32 +625,20 @@ static void print_data(const void *data, int len) return; }
- switch (len) { - case 1: /* byte */ - printf("<0x%02x>", (*(u8 *) data) & 0xff); - break; - case 2: /* half-word */ - printf("<0x%04x>", be16_to_cpu(*(u16 *) data) & 0xffff); - break; - case 4: /* word */ - printf("<0x%08x>", be32_to_cpu(*(u32 *) data) & 0xffffffffU); - break; - case 8: /* double-word */ -#if __WORDSIZE == 64 - printf("<0x%016llx>", be64_to_cpu(*(uint64_t *) data)); -#else - printf("<0x%08x ", be32_to_cpu(*(u32 *) data) & 0xffffffffU); - data += 4; - printf("0x%08x>", be32_to_cpu(*(u32 *) data) & 0xffffffffU); -#endif - break; - default: /* anything else... hexdump */ + if ((len %4) == 0) { + const u32 *p; + + printf("<"); + for (j = 0, p = data; j < len/4; j ++) + printf("0x%x%s", p[j], j < (len/4 - 1) ? " " : ""); + printf(">"); + } else { /* anything else... hexdump */ + const u8 *s; + printf("["); for (j = 0, s = data; j < len; j++) printf("%02x%s", s[j], j < len - 1 ? " " : ""); printf("]"); - - break; } }
@@ -771,7 +768,7 @@ static int fdt_print(const char *pathp, char *prop, int depth) /********************************************************************/
U_BOOT_CMD( - fdt, 5, 0, do_fdt, + fdt, 255, 0, do_fdt, "fdt - flattened device tree utility commands\n", "addr <addr> [<length>] - Set the fdt location to <addr>\n" #ifdef CONFIG_OF_BOARD_SETUP
Hi Andy,
This looks like a very good improvement, fix some of my mistakes and misassumptions.
What I wrote originally was prior to dtc v1.0... at that time, all constants were hex. Bringing our parsing/printing forward to the C-syntax age (dtc v1.0++) is good.
The parsing and print format that I did, I did to make the device tree printout reversible: I compiled source with dtc, loaded it, and printed it out. I adapted the print heuristics so that the fdt print command matched (exactly in almost all cases) the example dtc source. Your point about <> values being 32 bit cells bothers me... either I didn't understand the particulars of the <> notation (quite possible) or something has changed. I would like to understand the genesis of this error/misunderstanding.
I have not had time yet to apply the patch to the u-boot-fdt tree and try it, I'll do that pronto.
Best regards, gvb
Confirmed, my bad. Applied to the u-boot-fdt repo.
Thanks, gvb
Andy Fleming
Jerry Van Baren
Jerry Van Baren
