[PATCH] board: rockchip: Add rk3588 evb
rk3588 evb1 v10 is a evalution board from Rockchip, it is a dev board for rockchip and also a reference board for board vendors.
Hardware: SoC: RK3588 DRAM: LPDDR4X 8GB Debug: UART2 via USB PCIe: 3x4 *1 SATA *2 HDMI out *2 HDMI IN *1 USB2.0 Host *2 USB3.0 Host *1 Type C *1 MIPI DSI panel
rk3588-evb.dts is from Linux v6.2 with rename of rk3588-evb1-v10.dts
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588-evb-u-boot.dtsi | 17 ++++ arch/arm/dts/rk3588-evb.dts | 129 +++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3588/Kconfig | 7 ++ board/rockchip/evb_rk3588/Kconfig | 15 +++ board/rockchip/evb_rk3588/MAINTAINERS | 7 ++ board/rockchip/evb_rk3588/Makefile | 6 ++ board/rockchip/evb_rk3588/evb-rk3588.c | 39 ++++++++ configs/evb-rk3588_defconfig | 70 ++++++++++++++ doc/board/rockchip/rockchip.rst | 10 ++ include/configs/evb_rk3588.h | 15 +++ 11 files changed, 316 insertions(+) create mode 100644 arch/arm/dts/rk3588-evb-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-evb.dts create mode 100644 board/rockchip/evb_rk3588/Kconfig create mode 100644 board/rockchip/evb_rk3588/MAINTAINERS create mode 100644 board/rockchip/evb_rk3588/Makefile create mode 100644 board/rockchip/evb_rk3588/evb-rk3588.c create mode 100644 configs/evb-rk3588_defconfig create mode 100644 include/configs/evb_rk3588.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c160e884bf6..aa4421cad84 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -171,6 +171,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3568) += \
dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588-edgeble-neu6a-io.dtb \ + rk3588-evb.dtb \ rk3588-rock-5b.dtb
dtb-$(CONFIG_ROCKCHIP_RV1108) += \ diff --git a/arch/arm/dts/rk3588-evb-u-boot.dtsi b/arch/arm/dts/rk3588-evb-u-boot.dtsi new file mode 100644 index 00000000000..1e1c676b4bd --- /dev/null +++ b/arch/arm/dts/rk3588-evb-u-boot.dtsi @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Rockchip Electronics Co., Ltd. + */ + +#include "rk3588-u-boot.dtsi" + +/ { + aliases { + mmc0 = &sdmmc; + mmc1 = &sdhci; + }; + + chosen { + u-boot,spl-boot-order = &sdhci; + }; +}; diff --git a/arch/arm/dts/rk3588-evb.dts b/arch/arm/dts/rk3588-evb.dts new file mode 100644 index 00000000000..b91af0204db --- /dev/null +++ b/arch/arm/dts/rk3588-evb.dts @@ -0,0 +1,129 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2021 Rockchip Electronics Co., Ltd. + * + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3588.dtsi" + +/ { + model = "Rockchip RK3588 EVB1 V10 Board"; + compatible = "rockchip,rk3588-evb1-v10", "rockchip,rk3588"; + + aliases { + mmc0 = &sdhci; + serial2 = &uart2; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + power-supply = <&vcc12v_dcin>; + pwms = <&pwm2 0 25000 0>; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc12v_dcin>; + }; +}; + +&gmac0 { + clock_in_out = "output"; + phy-handle = <&rgmii_phy>; + phy-mode = "rgmii-rxid"; + pinctrl-0 = <&gmac0_miim + &gmac0_tx_bus2 + &gmac0_rx_bus2 + &gmac0_rgmii_clk + &gmac0_rgmii_bus>; + pinctrl-names = "default"; + rx_delay = <0x00>; + tx_delay = <0x43>; + status = "okay"; +}; + +&i2c2 { + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PD4 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +&mdio0 { + rgmii_phy: ethernet-phy@1 { + /* RTL8211F */ + compatible = "ethernet-phy-id001c.c916"; + reg = <0x1>; + pinctrl-names = "default"; + pinctrl-0 = <&rtl8211f_rst>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_LOW>; + }; +}; + +&pinctrl { + rtl8211f { + rtl8211f_rst: rtl8211f-rst { + rockchip,pins = <4 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + }; + + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; +}; + +&pwm2 { + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + no-sdio; + no-sd; + non-removable; + max-frequency = <200000000>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index aee71ca1dab..1fde7aefb24 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -1,5 +1,11 @@ if ROCKCHIP_RK3588
+config TARGET_RK3588_EVB + bool "Rockchip EVB1 v10" + select BOARD_LATE_INIT + help + RK3588 EVB is a evaluation board for Rockchp RK3588. + config TARGET_RK3588_NEU6 bool "Edgeble Neural Compute Module 6(Neu6) SoM" select BOARD_LATE_INIT @@ -51,6 +57,7 @@ config SYS_MALLOC_F_LEN default 0x80000
source board/edgeble/neural-compute-module-6/Kconfig +source board/rockchip/evb_rk3588/Kconfig source board/radxa/rock5b-rk3588/Kconfig
endif diff --git a/board/rockchip/evb_rk3588/Kconfig b/board/rockchip/evb_rk3588/Kconfig new file mode 100644 index 00000000000..836bd897bd3 --- /dev/null +++ b/board/rockchip/evb_rk3588/Kconfig @@ -0,0 +1,15 @@ +if TARGET_RK3588_EVB + +config SYS_BOARD + default "evb_rk3588" + +config SYS_VENDOR + default "rockchip" + +config SYS_CONFIG_NAME + default "evb_rk3588" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/rockchip/evb_rk3588/MAINTAINERS b/board/rockchip/evb_rk3588/MAINTAINERS new file mode 100644 index 00000000000..7b7df3c5a8a --- /dev/null +++ b/board/rockchip/evb_rk3588/MAINTAINERS @@ -0,0 +1,7 @@ +EVB-RK3588 +M: Kever Yang kever.yang@rock-chips.com +S: Maintained +F: board/rockchip/evb_rk3588 +F: include/configs/evb_rk3588.h +F: configs/evb-rk3588_defconfig +F: arch/arm/dts/rk3588-evb-u-boot.dtsi diff --git a/board/rockchip/evb_rk3588/Makefile b/board/rockchip/evb_rk3588/Makefile new file mode 100644 index 00000000000..240d2ec597e --- /dev/null +++ b/board/rockchip/evb_rk3588/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2023 Rockchip Electronics Co,. Ltd. +# + +obj-y += evb-rk3588.o diff --git a/board/rockchip/evb_rk3588/evb-rk3588.c b/board/rockchip/evb_rk3588/evb-rk3588.c new file mode 100644 index 00000000000..caf94d8d29c --- /dev/null +++ b/board/rockchip/evb_rk3588/evb-rk3588.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2023 Rockchip Electronics Co,. Ltd. + */ + +#include <fdtdec.h> +#include <fdt_support.h> + +#ifdef CONFIG_OF_BOARD_SETUP +static int rk3588_add_reserved_memory_fdt_nodes(void *new_blob) +{ + struct fdt_memory gap1 = { + .start = 0x3fc000000, + .end = 0x3fc4fffff, + }; + struct fdt_memory gap2 = { + .start = 0x3fff00000, + .end = 0x3ffffffff, + }; + unsigned long flags = FDTDEC_RESERVED_MEMORY_NO_MAP; + unsigned int ret; + + /* + * Inject the reserved-memory nodes into the DTS + */ + ret = fdtdec_add_reserved_memory(new_blob, "gap1", &gap1, NULL, 0, + NULL, flags); + if (ret) + return ret; + + return fdtdec_add_reserved_memory(new_blob, "gap2", &gap2, NULL, 0, + NULL, flags); +} + +int ft_board_setup(void *blob, struct bd_info *bd) +{ + return rk3588_add_reserved_memory_fdt_nodes(blob); +} +#endif diff --git a/configs/evb-rk3588_defconfig b/configs/evb-rk3588_defconfig new file mode 100644 index 00000000000..39cac760395 --- /dev/null +++ b/configs/evb-rk3588_defconfig @@ -0,0 +1,70 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-evb" +CONFIG_DM_RESET=y +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_RK3588_EVB=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-evb.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYSRESET=y +# CONFIG_BINMAN_FDT is not set +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index b5563b8f7f9..af6e466de1e 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -91,6 +91,7 @@ List of mainline supported Rockchip boards: - Rockchip Evb-RK3568 (evb-rk3568)
* rk3588 + - Rockchip EVB (evb-rk3588) - Edgeble Neural Compute Module 6 SoM - Neu6a (neu6a-io-rk3588) - Radxa ROCK 5B (rock5b-rk3588)
@@ -185,6 +186,15 @@ To build rk3568 boards: make evb-rk3568_defconfig make CROSS_COMPILE=aarch64-linux-gnu-
+To build rk3588 boards: + +.. code-block:: bash + + export BL31=../rkbin/bin/rk35/rk3588_bl31_v1.33.elf + export ROCKCHIP_TPL=../rkbin/bin/rk35/rk3588_ddr_lp4_2112MHz_lp5_2736MHz_v1.09.bin + make evb-rk3588_defconfig + make CROSS_COMPILE=aarch64-linux-gnu- + Flashing --------
diff --git a/include/configs/evb_rk3588.h b/include/configs/evb_rk3588.h new file mode 100644 index 00000000000..4568e2cace6 --- /dev/null +++ b/include/configs/evb_rk3588.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2023 Rockchip Electronics Co., Ltd. + */ + +#ifndef __EVB_RK3588_H +#define __EVB_RK3588_H + +#include <configs/rk3588_common.h> + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#endif
IMHO - do not rename Linux sync (It will break the Linux syncs, every time), Matching DTS from Linux make maintenance easy and easy to fix. If it is really needed then this change has to be in Linux.
Jagan.
Hi Jagan,
I can understand your concern, keep everything the same seems easier.
As I have said for rk3568-evb, not like the boards from other board vendor which sales
to End customer, rockchip EVB is a reference board, many boards copy core part the the
evb schematic. Not all the boards will upstream, but still many boards can re-use the
EVB U-Boot to boot their boards.
For U-Boot, I would like to keep the same usage of evb like other rkxx-evb unless there have
conflict by more than one EVB.
When there is only one evb, and without modification by U-Boot, the Linux sync won't be break.
Thanks, - Kever
Jagan.
Date: Tue, 28 Feb 2023 18:00:35 +0800 From: Kever Yang kever.yang@rock-chips.com
Hi Jagan,
The synchronization process should be as simple as:
cp linux/arch/arm64/boot/dts/rockchip/rk3588-evb1-v10.dts u-boot/arch/arm/dts
Doing it any other way is just going to cause confusion about whether the .dts files are supposed to be the same or if there is some variation.
Cheers,
Mark
Hi Kever,
On Tue, 28 Feb 2023 at 15:30, Kever Yang kever.yang@rock-chips.com wrote:
Hi Jagan,
I was aware of all these details, why cannot we use the same dts name and add it evb-rk3588_defconfig?
So, we have evb-rk3588_defconfig like other evb boards defconfig with rk3588-evb1-v10.dts
Jagan.
Jagan Teki
Kever Yang
Mark Kettenis
