[U-Boot] [PATCH] do_bootm: unify duplicate prototypes
The duplication of the do_bootm prototype has gotten out of hand, and they're pretty much all outdated (wrt constness). Unify them all in command.h.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/barco/barco.c | 1 - board/cm5200/fwupdate.c | 1 - board/esd/common/cmd_loadpci.c | 1 - board/esd/cpci750/cpci750.c | 1 - board/esd/pci405/cmd_pci405.c | 2 -- board/pn62/cmd_pn62.c | 2 -- common/cmd_fdc.c | 1 - common/cmd_fdos.c | 1 - common/cmd_ide.c | 1 - common/cmd_nand.c | 1 - common/cmd_net.c | 2 -- common/cmd_scsi.c | 1 - common/cmd_usb.c | 1 - include/command.h | 2 ++ 14 files changed, 2 insertions(+), 16 deletions(-)
diff --git a/board/barco/barco.c b/board/barco/barco.c index 263a288..bcf6af2 100644 --- a/board/barco/barco.c +++ b/board/barco/barco.c @@ -257,7 +257,6 @@ void barcobcd_boot (void) char *bootm_args[2]; char *buf; int cnt; - extern int do_bootm (cmd_tbl_t *, int, int, char *[]);
buf = (char *)(0x00800000); /* make certain there are enough chars to print the command line here! diff --git a/board/cm5200/fwupdate.c b/board/cm5200/fwupdate.c index c1a4a19..9d4eadc 100644 --- a/board/cm5200/fwupdate.c +++ b/board/cm5200/fwupdate.c @@ -35,7 +35,6 @@
#include "fwupdate.h"
-extern int do_bootm(cmd_tbl_t *, int, int, char * const []); extern long do_fat_read(const char *, void *, unsigned long, int); extern int do_fat_fsload(cmd_tbl_t *, int, int, char * const []);
diff --git a/board/esd/common/cmd_loadpci.c b/board/esd/common/cmd_loadpci.c index 87da27d..8f4ad84 100644 --- a/board/esd/common/cmd_loadpci.c +++ b/board/esd/common/cmd_loadpci.c @@ -29,7 +29,6 @@
#if defined(CONFIG_CMD_BSP)
-extern int do_bootm (cmd_tbl_t *, int, int, char *[]); extern int do_source (cmd_tbl_t *, int, int, char *[]);
#define ADDRMASK 0xfffff000 diff --git a/board/esd/cpci750/cpci750.c b/board/esd/cpci750/cpci750.c index f9f7c7f..f27d65e 100644 --- a/board/esd/cpci750/cpci750.c +++ b/board/esd/cpci750/cpci750.c @@ -122,7 +122,6 @@ static char show_config_tab[][15] = {{"PCI0DLL_2 "}, /* 31 */
extern flash_info_t flash_info[];
-extern int do_bootm (cmd_tbl_t *, int, int, char *[]); extern int do_bootvx (cmd_tbl_t *, int, int, char *[]);
/* ------------------------------------------------------------------------- */ diff --git a/board/esd/pci405/cmd_pci405.c b/board/esd/pci405/cmd_pci405.c index 2fc9fda..13f9019 100644 --- a/board/esd/pci405/cmd_pci405.c +++ b/board/esd/pci405/cmd_pci405.c @@ -34,8 +34,6 @@
-extern int do_bootm (cmd_tbl_t *, int, int, char *[]); - /* * Command loadpci: wait for signal from host and boot image. */ diff --git a/board/pn62/cmd_pn62.c b/board/pn62/cmd_pn62.c index 58c680b..939cb4a 100644 --- a/board/pn62/cmd_pn62.c +++ b/board/pn62/cmd_pn62.c @@ -31,8 +31,6 @@
-extern int do_bootm (cmd_tbl_t *, int, int, char *[]); - /* * Command led: controls the various LEDs 0..11 on the PN62 card. */ diff --git a/common/cmd_fdc.c b/common/cmd_fdc.c index 831a07f..cdb050c 100644 --- a/common/cmd_fdc.c +++ b/common/cmd_fdc.c @@ -826,7 +826,6 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* Check if we should attempt an auto-start */ if (((ep = getenv("autostart")) != NULL) && (strcmp(ep,"yes") == 0)) { char *local_args[2]; - extern int do_bootm (cmd_tbl_t *, int, int, char *[]);
local_args[0] = argv[0]; local_args[1] = NULL; diff --git a/common/cmd_fdos.c b/common/cmd_fdos.c index a8822d9..2af4ca0 100644 --- a/common/cmd_fdos.c +++ b/common/cmd_fdos.c @@ -101,7 +101,6 @@ int do_fdosboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* Check if we should attempt an auto-start */ if (((ep = getenv("autostart")) != NULL) && (strcmp(ep,"yes") == 0)) { char *local_args[2]; - extern int do_bootm (cmd_tbl_t *, int, int, char *[]); local_args[0] = argv[0]; local_args[1] = NULL; printf ("Automatic boot of image at addr 0x%08lX ...\n", load_addr); diff --git a/common/cmd_ide.c b/common/cmd_ide.c index ea0f4a7..df7bdf5 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -498,7 +498,6 @@ int do_diskboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* Check if we should attempt an auto-start */ if (((ep = getenv("autostart")) != NULL) && (strcmp(ep,"yes") == 0)) { char *local_args[2]; - extern int do_bootm (cmd_tbl_t *, int, int, char *[]);
local_args[0] = argv[0]; local_args[1] = NULL; diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 634d036..6783645 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -789,7 +789,6 @@ static int nand_load_image(cmd_tbl_t *cmdtp, nand_info_t *nand, /* Check if we should attempt an auto-start */ if (((ep = getenv("autostart")) != NULL) && (strcmp(ep, "yes") == 0)) { char *local_args[2]; - extern int do_bootm(cmd_tbl_t *, int, int, char *[]);
local_args[0] = cmd; local_args[1] = NULL; diff --git a/common/cmd_net.c b/common/cmd_net.c index b131006..090ecea 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -28,8 +28,6 @@ #include <command.h> #include <net.h>
-extern int do_bootm (cmd_tbl_t *, int, int, char * const []); - static int netboot_common (proto_t, cmd_tbl_t *, int , char * const []);
int do_bootp (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git a/common/cmd_scsi.c b/common/cmd_scsi.c index 6b937f9..be4fe74 100644 --- a/common/cmd_scsi.c +++ b/common/cmd_scsi.c @@ -329,7 +329,6 @@ int do_scsiboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* Check if we should attempt an auto-start */ if (((ep = getenv("autostart")) != NULL) && (strcmp(ep,"yes") == 0)) { char *local_args[2]; - extern int do_bootm (cmd_tbl_t *, int, int, char *[]); local_args[0] = argv[0]; local_args[1] = NULL; printf ("Automatic boot of image at addr 0x%08lX ...\n", addr); diff --git a/common/cmd_usb.c b/common/cmd_usb.c index 226ea0d..b04a8df 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -490,7 +490,6 @@ int do_usbboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* Check if we should attempt an auto-start */ if (((ep = getenv("autostart")) != NULL) && (strcmp(ep, "yes") == 0)) { char *local_args[2]; - extern int do_bootm(cmd_tbl_t *, int, int, char *[]); local_args[0] = argv[0]; local_args[1] = NULL; printf("Automatic boot of image at addr 0x%08lX ...\n", addr); diff --git a/include/command.h b/include/command.h index a153ce9..7cebf8a 100644 --- a/include/command.h +++ b/include/command.h @@ -95,6 +95,8 @@ extern int cmd_auto_complete(const char *const prompt, char *buf, int *np, int * extern int cmd_get_data_size(char* arg, int default_size); #endif
+extern int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); + #endif /* __ASSEMBLY__ */
Dear Mike Frysinger,
Applied to "next" branch, thanks.
Mike Frysinger
