[U-Boot] [PATCH] ubifs.c: BUG: Error following links
The link_name variable is declared inside the if block and it is used outside it through the name pointer.
Signed-off-by: Ricardo Ribalda Delgado ricardo.ribalda@gmail.com --- fs/ubifs/ubifs.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 0f8128c..2bad027 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -386,6 +386,7 @@ static unsigned long ubifs_findfile(struct super_block *sb, char *filename) unsigned long root_inum = 1; unsigned long inum; int symlink_count = 0; /* Don't allow symlink recursion */ + char link_name[64];
strcpy(fpath, filename);
@@ -422,7 +423,6 @@ static unsigned long ubifs_findfile(struct super_block *sb, char *filename) ui = ubifs_inode(inode);
if ((inode->i_mode & S_IFMT) == S_IFLNK) { - char link_name[64]; char buf[128];
/* We have some sort of symlink recursion, bail out */
Applied to u-boot-ubi/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
