[PATCH 0/8] env: mmc: improvements and corrections
Update in U-Boot env mmc backend with several cosmetic changes or corrections and 2 new features:
1/ CONFIG_ENV_MMC_USE_DT = no more use CONFIG_ENV_OFFSET in the mmc ENV backend when this config is activated.
Requested by the STM32MP STMicroelectronics boards which activate several ENV_IS_IN_XXX; the value of CONFIG_ENV_OFFSET is invalid for SD-Card / eMMC boot; this offset should only used in SPIFlash backend (sf.c) for SPI-NOR boot.
If this offset is used on mmc backend, when partition name in GPT is not aligned with U-Boot DT: "u-boot,mmc-env-partition", the behavior is difficult to debug: a partition is corrupted on 'env save' command.
2/ selects the GPT env partition by the "u-boot-env" type GUID introduced by the commit c0364ce1c695 ("doc/README.gpt: define partition type GUID for U-Boot environment")
This feature can also avoid issue when 'u-boot-env' partition name change in GPT partitioning but not in the U-Boot DT with "u-boot,mmc-env-partition"
Few check patch warnings remained in the series, but after check I can't remove them :
- IS_ENABLED(ENV_MMC_HWPART_REDUND) is normally used as IS_ENABLED(CONFIG_ENV_MMC_HWPART_REDUND) => ENV_MMC_HWPART_REDUND is locally defined in this file it is not a real CONFIG but I can use the IS_ENABLED() macro as it is defined to 1
- Use 'if (IS_ENABLED(CONFIG...))' instead of '#if or #ifdef' where possible + CONFIG_PARTITION_TYPE_GUID => info.type_guid existence + CONFIG_ENV_OFFSET_REDUND and CONFIG_ENV_MMC_USE_DT => only for define
As I miss the merge window, not targeted for v2023.01 but for next v2023.04.
Regards
Patrick
Patrick Delaunay (8): env: mmc: introduced ENV_MMC_OFFSET env: mcc: Drop unnecessary #ifdefs env: mcc: fix compilation error with ENV_IS_EMBEDDED env: mmc: add CONFIG_ENV_MMC_USE_DT configs: stm32mp: activate CONFIG_ENV_MMC_USE_DT env: mmc: select GPT env partition by type guid env: mmc: add debug message when mmc-env-partition is not found env: mmc: cosmetic: remove unused macro STR(X)
configs/stm32mp13_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + env/Kconfig | 16 +++ env/mmc.c | 182 ++++++++++++++++++---------- 6 files changed, 135 insertions(+), 67 deletions(-)
Introduce ENV_MMC_OFFSET defines. It is a preliminary step to the next patches to simplify the code.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
env/mmc.c | 24 ++++++++++++++++++++---- 1 file changed, 20 insertions(+), 4 deletions(-)
diff --git a/env/mmc.c b/env/mmc.c index c28f4c6c6dc0..42bcf7e775cc 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -24,6 +24,17 @@ #define __STR(X) #X #define STR(X) __STR(X)
+#define ENV_MMC_INVALID_OFFSET ((s64)-1) + +/* Default ENV offset when not defined in Device Tree */ +#define ENV_MMC_OFFSET CONFIG_ENV_OFFSET + +#if defined(CONFIG_ENV_OFFSET_REDUND) +#define ENV_MMC_OFFSET_REDUND CONFIG_ENV_OFFSET_REDUND +#else +#define ENV_MMC_OFFSET_REDUND ENV_MMC_INVALID_OFFSET +#endif + DECLARE_GLOBAL_DATA_PTR;
/* @@ -94,12 +105,12 @@ static inline s64 mmc_offset(int copy) return val; }
- defvalue = CONFIG_ENV_OFFSET; + defvalue = ENV_MMC_OFFSET; propname = dt_prop.offset;
#if defined(CONFIG_ENV_OFFSET_REDUND) if (copy) { - defvalue = CONFIG_ENV_OFFSET_REDUND; + defvalue = ENV_MMC_OFFSET_REDUND; propname = dt_prop.offset_redund; } #endif @@ -108,11 +119,11 @@ static inline s64 mmc_offset(int copy) #else static inline s64 mmc_offset(int copy) { - s64 offset = CONFIG_ENV_OFFSET; + s64 offset = ENV_MMC_OFFSET;
#if defined(CONFIG_ENV_OFFSET_REDUND) if (copy) - offset = CONFIG_ENV_OFFSET_REDUND; + offset = ENV_MMC_OFFSET_REDUND; #endif return offset; } @@ -122,6 +133,11 @@ __weak int mmc_get_env_addr(struct mmc *mmc, int copy, u32 *env_addr) { s64 offset = mmc_offset(copy);
+ if (offset == ENV_MMC_INVALID_OFFSET) { + printf("Invalid ENV offset in MMC, copy=%d\n", copy); + return -ENOENT; + } + if (offset < 0) offset += mmc->capacity;
- defvalue = ENV_MMC_OFFSET; propname = dt_prop.offset;
propname = dt_prop.offset_redund; }defvalue = ENV_MMC_OFFSET_REDUND;
- s64 offset = ENV_MMC_OFFSET;
- if (offset == ENV_MMC_INVALID_OFFSET) {
return -ENOENT;
- if (offset < 0) offset += mmc->capacity;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
This file has a lot of conditional code and much of it is unnecessary. Clean this up to reduce the number of build combinations.
This patch replaces the test on CONFIG_ENV_OFFSET_REDUND for the more coherent CONFIG_SYS_REDUNDAND_ENVIRONMENT.
This patch also corrects a compilation issue in init_mmc_for_env() when CONFIG_SYS_MMC_ENV_PART is not activated, env_mmc_orig_hwpart is not defined.
env/mmc.c | 120 +++++++++++++++++++++++++++++------------------------- 1 file changed, 64 insertions(+), 56 deletions(-)
diff --git a/env/mmc.c b/env/mmc.c index 42bcf7e775cc..b36bd9ad77ee 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -46,7 +46,7 @@ DECLARE_GLOBAL_DATA_PTR; #if (defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) && \ (CONFIG_SYS_MMC_ENV_PART == 1) && \ (CONFIG_ENV_OFFSET == CONFIG_ENV_OFFSET_REDUND)) -#define ENV_MMC_HWPART_REDUND +#define ENV_MMC_HWPART_REDUND 1 #endif
#if CONFIG_IS_ENABLED(OF_CONTROL) @@ -108,12 +108,11 @@ static inline s64 mmc_offset(int copy) defvalue = ENV_MMC_OFFSET; propname = dt_prop.offset;
-#if defined(CONFIG_ENV_OFFSET_REDUND) - if (copy) { + if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT) && copy) { defvalue = ENV_MMC_OFFSET_REDUND; propname = dt_prop.offset_redund; } -#endif + return ofnode_conf_read_int(propname, defvalue); } #else @@ -121,10 +120,9 @@ static inline s64 mmc_offset(int copy) { s64 offset = ENV_MMC_OFFSET;
-#if defined(CONFIG_ENV_OFFSET_REDUND) - if (copy) + if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT) && copy) offset = ENV_MMC_OFFSET_REDUND; -#endif + return offset; } #endif @@ -165,8 +163,24 @@ static int mmc_set_env_part(struct mmc *mmc, uint part)
return ret; } + +static bool mmc_set_env_part_init(struct mmc *mmc) +{ + env_mmc_orig_hwpart = mmc_get_blk_desc(mmc)->hwpart; + if (mmc_set_env_part(mmc, mmc_get_env_part(mmc))) + return false; + + return true; +} + +static int mmc_set_env_part_restore(struct mmc *mmc) +{ + return mmc_set_env_part(mmc, env_mmc_orig_hwpart); +} #else static inline int mmc_set_env_part(struct mmc *mmc, uint part) {return 0; }; +static bool mmc_set_env_part_init(struct mmc *mmc) {return true; } +static inline int mmc_set_env_part_restore(struct mmc *mmc) {return 0; }; #endif
static const char *init_mmc_for_env(struct mmc *mmc) @@ -183,8 +197,7 @@ static const char *init_mmc_for_env(struct mmc *mmc) if (mmc_init(mmc)) return "MMC init failed"; #endif - env_mmc_orig_hwpart = mmc_get_blk_desc(mmc)->hwpart; - if (mmc_set_env_part(mmc, mmc_get_env_part(mmc))) + if (!mmc_set_env_part_init(mmc)) return "MMC partition switch failed";
return NULL; @@ -192,11 +205,7 @@ static const char *init_mmc_for_env(struct mmc *mmc)
static void fini_mmc_for_env(struct mmc *mmc) { -#ifdef CONFIG_SYS_MMC_ENV_PART - int dev = mmc_get_env_dev(); - - blk_select_hwpart_devnum(UCLASS_MMC, dev, env_mmc_orig_hwpart); -#endif + mmc_set_env_part_restore(mmc); }
#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_SPL_BUILD) @@ -233,21 +242,20 @@ static int env_mmc_save(void) if (ret) goto fini;
-#ifdef CONFIG_ENV_OFFSET_REDUND - if (gd->env_valid == ENV_VALID) - copy = 1; - -#ifdef ENV_MMC_HWPART_REDUND - ret = mmc_set_env_part(mmc, copy + 1); - if (ret) - goto fini; -#endif + if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT)) { + if (gd->env_valid == ENV_VALID) + copy = 1;
-#endif + if (IS_ENABLED(ENV_MMC_HWPART_REDUND)) { + ret = mmc_set_env_part(mmc, copy + 1); + if (ret) + goto fini; + }
- if (mmc_get_env_addr(mmc, copy, &offset)) { - ret = 1; - goto fini; + if (mmc_get_env_addr(mmc, copy, &offset)) { + ret = 1; + goto fini; + } }
printf("Writing to %sMMC(%d)... ", copy ? "redundant " : "", dev); @@ -259,12 +267,12 @@ static int env_mmc_save(void)
ret = 0;
-#ifdef CONFIG_ENV_OFFSET_REDUND - gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : ENV_REDUND; -#endif + if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT)) + gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : ENV_REDUND;
fini: fini_mmc_for_env(mmc); + return ret; }
@@ -308,22 +316,22 @@ static int env_mmc_erase(void) printf("\n"); ret = erase_env(mmc, CONFIG_ENV_SIZE, offset);
-#ifdef CONFIG_ENV_OFFSET_REDUND - copy = 1; + if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT)) { + copy = 1;
-#ifdef ENV_MMC_HWPART_REDUND - ret = mmc_set_env_part(mmc, copy + 1); - if (ret) - goto fini; -#endif + if (IS_ENABLED(ENV_MMC_HWPART_REDUND)) { + ret = mmc_set_env_part(mmc, copy + 1); + if (ret) + goto fini; + }
- if (mmc_get_env_addr(mmc, copy, &offset)) { - ret = CMD_RET_FAILURE; - goto fini; - } + if (mmc_get_env_addr(mmc, copy, &offset)) { + ret = CMD_RET_FAILURE; + goto fini; + }
- ret |= erase_env(mmc, CONFIG_ENV_SIZE, offset); -#endif + ret |= erase_env(mmc, CONFIG_ENV_SIZE, offset); + }
fini: fini_mmc_for_env(mmc); @@ -345,7 +353,7 @@ static inline int read_env(struct mmc *mmc, unsigned long size, return (n == blk_cnt) ? 0 : -1; }
-#ifdef CONFIG_ENV_OFFSET_REDUND +#if defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) static int env_mmc_load(void) { #if !defined(ENV_IS_EMBEDDED) @@ -375,19 +383,19 @@ static int env_mmc_load(void) goto fini; }
-#ifdef ENV_MMC_HWPART_REDUND - ret = mmc_set_env_part(mmc, 1); - if (ret) - goto fini; -#endif + if (IS_ENABLED(ENV_MMC_HWPART_REDUND)) { + ret = mmc_set_env_part(mmc, 1); + if (ret) + goto fini; + }
read1_fail = read_env(mmc, CONFIG_ENV_SIZE, offset1, tmp_env1);
-#ifdef ENV_MMC_HWPART_REDUND - ret = mmc_set_env_part(mmc, 2); - if (ret) - goto fini; -#endif + if (IS_ENABLED(ENV_MMC_HWPART_REDUND)) { + ret = mmc_set_env_part(mmc, 2); + if (ret) + goto fini; + }
read2_fail = read_env(mmc, CONFIG_ENV_SIZE, offset2, tmp_env2);
@@ -403,7 +411,7 @@ err: #endif return ret; } -#else /* ! CONFIG_ENV_OFFSET_REDUND */ +#else /* ! CONFIG_SYS_REDUNDAND_ENVIRONMENT */ static int env_mmc_load(void) { #if !defined(ENV_IS_EMBEDDED) @@ -448,7 +456,7 @@ err: #endif return ret; } -#endif /* CONFIG_ENV_OFFSET_REDUND */ +#endif /* CONFIG_SYS_REDUNDAND_ENVIRONMENT */
U_BOOT_ENV_LOCATION(mmc) = { .location = ENVL_MMC,
- if (copy) {
- if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT) && copy) { defvalue = ENV_MMC_OFFSET_REDUND; propname = dt_prop.offset_redund; }
-#endif
- return ofnode_conf_read_int(propname, defvalue);
- if (copy)
- if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT) && copy) offset = ENV_MMC_OFFSET_REDUND;
-#endif
- return offset;
return ret; }
return false;
- return true;
- return mmc_set_env_part(mmc, env_mmc_orig_hwpart);
return NULL;
-#endif
- mmc_set_env_part_restore(mmc);
copy = 1;
- if (ret)
goto fini;
-#endif
- if (IS_ENABLED(CONFIG_SYS_REDUNDAND_ENVIRONMENT)) {
copy = 1;
-#endif
if (ret)
goto fini;
ret = 1;
goto fini;
ret = 1;
goto fini;
ret = 0;
-#endif
- return ret;
- copy = 1;
copy = 1;
- if (ret)
goto fini;
-#endif
if (ret)
goto fini;
goto fini;
goto fini;
-#endif
- if (ret)
goto fini;
-#endif
if (ret)
goto fini;
- if (ret)
goto fini;
-#endif
if (ret)
goto fini;
Thanks Patrice
When ENV_IS_EMBEDDED is enabled, ret is not defined but is used as a return value in env_mmc_load(). This patch correct this issue and simplify the existing code, test only one time #if defined(ENV_IS_EMBEDDED) and not in the function.
env/mmc.c | 12 +++++++----- 1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/env/mmc.c b/env/mmc.c index b36bd9ad77ee..661a268ea07d 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -353,10 +353,14 @@ static inline int read_env(struct mmc *mmc, unsigned long size, return (n == blk_cnt) ? 0 : -1; }
-#if defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) +#if defined(ENV_IS_EMBEDDED) +static int env_mmc_load(void) +{ + return 0; +} +#elif defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) static int env_mmc_load(void) { -#if !defined(ENV_IS_EMBEDDED) struct mmc *mmc; u32 offset1, offset2; int read1_fail = 0, read2_fail = 0; @@ -408,13 +412,11 @@ err: if (ret) env_set_default(errmsg, 0);
-#endif return ret; } #else /* ! CONFIG_SYS_REDUNDAND_ENVIRONMENT */ static int env_mmc_load(void) { -#if !defined(ENV_IS_EMBEDDED) ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); struct mmc *mmc; u32 offset; @@ -453,7 +455,7 @@ fini: err: if (ret) env_set_default(errmsg, 0); -#endif + return ret; } #endif /* CONFIG_SYS_REDUNDAND_ENVIRONMENT */
- return ret;
Thanks Patrice
Add a new config CONFIG_ENV_MMC_USE_DT to force configuration of the U-Boot environment offset with device tree config node.
This patch avoids issues when several CONFIG_ENV_IS_IN_XXX are activated, the defconfig file uses the same value for CONFIG_ENV_OFFSET or CONFIG_ENV_OFFSET_REDUND for the several ENV backends (SPI_FLASH, EEPROM NAND, SATA, MMC).
After this patch a bad offset value is not possible when the selected partition in device tree is not found.
env/Kconfig | 16 ++++++++++++++++ env/mmc.c | 7 +++++++ 2 files changed, 23 insertions(+)
diff --git a/env/Kconfig b/env/Kconfig index 24111dfaf47b..f8ee99052b97 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -242,6 +242,13 @@ config ENV_IS_IN_MMC This value is also in units of bytes, but must also be aligned to an MMC sector boundary.
+ CONFIG_ENV_MMC_USE_DT (optional): + + These define forces the configuration by the config node in device + tree with partition name: "u-boot,mmc-env-partition" or with + offset: "u-boot,mmc-env-offset", "u-boot,mmc-env-offset-redundant". + CONFIG_ENV_OFFSET and CONFIG_ENV_OFFSET_REDUND are not used. + config ENV_IS_IN_NAND bool "Environment in a NAND device" depends on !CHAIN_OF_TRUST @@ -650,6 +657,15 @@ config SYS_MMC_ENV_PART partition 0 or the first boot partition, which is 1 or some other defined partition.
+config ENV_MMC_USE_DT + bool "Read partition name and offset in DT" + depends on ENV_IS_IN_MMC && OF_CONTROL + help + Only use the device tree to get the environment location in MMC + device, with partition name or with offset. + The 2 defines CONFIG_ENV_OFFSET, CONFIG_ENV_OFFSET_REDUND + are not used as fallback. + config USE_DEFAULT_ENV_FILE bool "Create default environment from file" help diff --git a/env/mmc.c b/env/mmc.c index 661a268ea07d..1894b6483220 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -26,6 +26,12 @@
+#if defined(CONFIG_ENV_MMC_USE_DT) +/* ENV offset is invalid when not defined in Device Tree */ +#define ENV_MMC_OFFSET ENV_MMC_INVALID_OFFSET +#define ENV_MMC_OFFSET_REDUND ENV_MMC_INVALID_OFFSET + +#else /* Default ENV offset when not defined in Device Tree */ #define ENV_MMC_OFFSET CONFIG_ENV_OFFSET
@@ -34,6 +40,7 @@ #else #define ENV_MMC_OFFSET_REDUND ENV_MMC_INVALID_OFFSET #endif +#endif
- bool "Read partition name and offset in DT"
- depends on ENV_IS_IN_MMC && OF_CONTROL
- help
Thanks Patrice
Activate by default CONFIG_ENV_MMC_USE_DT as "u-boot,mmc-env-partition" should be always use in STMicroelectronics boards device tree to locate the environment for mmc backend. The 2 defines: CONFIG_ENV_OFFSET=0x280000 CONFIG_ENV_OFFSET_REDUND=0x2C0000 are only valid for spi-nor and not for SD-Card or eMMC.
configs/stm32mp13_defconfig | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/stm32mp13_defconfig b/configs/stm32mp13_defconfig index af6b1839d039..4cab07647349 100644 --- a/configs/stm32mp13_defconfig +++ b/configs/stm32mp13_defconfig @@ -46,6 +46,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=-1 +CONFIG_ENV_MMC_USE_DT=y CONFIG_CLK_SCMI=y CONFIG_GPIO_HOG=y CONFIG_DM_I2C=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 86ebbef0a6c8..4a96ad22bcc8 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -91,6 +91,7 @@ CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=-1 +CONFIG_ENV_MMC_USE_DT=y # CONFIG_SPL_ENV_IS_NOWHERE is not set # CONFIG_SPL_ENV_IS_IN_SPI_FLASH is not set CONFIG_TFTP_TSIZE=y diff --git a/configs/stm32mp15_defconfig b/configs/stm32mp15_defconfig index caa79e68834f..151981849de9 100644 --- a/configs/stm32mp15_defconfig +++ b/configs/stm32mp15_defconfig @@ -65,6 +65,7 @@ CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=-1 +CONFIG_ENV_MMC_USE_DT=y CONFIG_TFTP_TSIZE=y CONFIG_STM32_ADC=y CONFIG_CLK_SCMI=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 3309c2e79246..098eedc9b727 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -66,6 +66,7 @@ CONFIG_ENV_UBI_VOLUME="uboot_config" CONFIG_ENV_UBI_VOLUME_REDUND="uboot_config_r" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=-1 +CONFIG_ENV_MMC_USE_DT=y CONFIG_TFTP_TSIZE=y CONFIG_STM32_ADC=y CONFIG_CLK_SCMI=y
Thanks Patrice
Since commit c0364ce1c695 ("doc/README.gpt: define partition type GUID for U-Boot environment"), a specific type GUID can be used to indicate the U-Boot environment partition on the device with GPT partition table.
This patch uses this type GUID to found the env partition as fallback when the partition name property "u-boot,mmc-env-partition" is not present in config node or if the indicated partition name is not found.
The mmc_offset_try_partition() function is reused, it selects the first partition with the correct type GUID when the parameter 'str' is NULL.
env/mmc.c | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/env/mmc.c b/env/mmc.c index 1894b6483220..bd7d51e6b633 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -74,8 +74,18 @@ static inline int mmc_offset_try_partition(const char *str, int copy, s64 *val) if (ret < 0) return ret;
- if (!strncmp((const char *)info.name, str, sizeof(info.name))) + if (str && !strncmp((const char *)info.name, str, sizeof(info.name))) break; +#ifdef CONFIG_PARTITION_TYPE_GUID + if (!str) { + const efi_guid_t env_guid = PARTITION_U_BOOT_ENVIRONMENT; + efi_guid_t type_guid; + + uuid_str_to_bin(info.type_guid, type_guid.b, UUID_STR_FORMAT_GUID); + if (!memcmp(&env_guid, &type_guid, sizeof(efi_guid_t))) + break; + } +#endif }
/* round up to info.blksz */ @@ -112,6 +122,13 @@ static inline s64 mmc_offset(int copy) return val; }
+ /* try the GPT partition with "U-Boot ENV" TYPE GUID */ + if (IS_ENABLED(CONFIG_PARTITION_TYPE_GUID)) { + err = mmc_offset_try_partition(NULL, copy, &val); + if (!err) + return val; + } + defvalue = ENV_MMC_OFFSET; propname = dt_prop.offset;
if (!str) {
break;
+#endif }
- /* try the GPT partition with "U-Boot ENV" TYPE GUID */
- if (IS_ENABLED(CONFIG_PARTITION_TYPE_GUID)) {
if (!err)
return val;
Thanks Patrice
Add a debug message to indicate a potential issue when "u-boot,mmc-env-partition" is present in config node of device tree but this partition name is not found in the mmc device.
env/mmc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/env/mmc.c b/env/mmc.c index bd7d51e6b633..8941e0f5ff39 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -120,6 +120,7 @@ static inline s64 mmc_offset(int copy) err = mmc_offset_try_partition(str, copy, &val); if (!err) return val; + debug("env partition '%s' not found (%d)", str, err); }
Thanks Patrice
Remove the unused macro STR(X) since the commit 2b2f727500dc ("env: mmc: allow support of mmc_get_env_dev with OF_CONTROL")
env/mmc.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/env/mmc.c b/env/mmc.c index 8941e0f5ff39..85761417f283 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -21,9 +21,6 @@ #include <errno.h> #include <dm/ofnode.h>
-#define __STR(X) #X -#define STR(X) __STR(X) - #define ENV_MMC_INVALID_OFFSET ((s64)-1)
Thanks Patrice
Hi Patrick,
On Thu, 10 Nov 2022 at 03:49, Patrick Delaunay patrick.delaunay@foss.st.com wrote:
- CONFIG_PARTITION_TYPE_GUID => info.type_guid existence
- CONFIG_ENV_OFFSET_REDUND and CONFIG_ENV_MMC_USE_DT => only for define
Shouldn't this all move to device tree? Using CONFIG options is such a mess. We have the devices in DT so can indicate which ones have an environment and what the parameters are for each.
On Thu, Nov 10, 2022 at 01:40:32PM -0700, Simon Glass wrote:
Hi Patrick,
And there's already the Documentation/devicetree/bindings/nvmem/u-boot,env.yaml to build upon.
Patrice CHOTARD
Patrick Delaunay
