[U-Boot] [PATCH] spl: add debug print for early malloc usage
To find out how big the early malloc heap must be in SPL, add a debug print statement that dumps its usage before switching to relocated heap in spl_relocate_stack_gd() via CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN.
Signed-off-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com ---
common/spl/spl.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 2e2af1b28e..88d4b8a9bf 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -728,6 +728,8 @@ ulong spl_relocate_stack_gd(void)
#if defined(CONFIG_SPL_SYS_MALLOC_SIMPLE) && CONFIG_VAL(SYS_MALLOC_F_LEN) if (CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN) { + debug("SPL malloc() before relocation used 0x%lx bytes (%ld KB)\n", + gd->malloc_ptr, gd->malloc_ptr / 1024); ptr -= CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN; gd->malloc_base = ptr; gd->malloc_limit = CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN;
Shouldn't this use %p ?
Despite its name, 'gd->malloc_ptr' is of type 'unsigned long', so I think this is correct. After all, I only copied the code from other places where the heap usage is dumped, too.
-- Best regards, Marek Vasut
Isn't that broken on some arm64 systems then ? :)
I don't think it's broken for 'ptr' as that seems to be the offset into the malloc pool.
Some 64-bit platforms migth have a problem with gd->malloc_base being unsigned long though - I don't know the size of unsigned long on arm64.
Simon Goldschmidt
