[U-Boot] [PATCH 0/2] *** SUBJECT HERE ***
*** BLURB HERE *** Fix 2 armada37x0 pinctrl issues.
Ken Ma (2): pinctrl: a3700: Fix uart2 group selection register mask pinctrl: a3700: Fix the issue that gpio controller is registered with wrong node id
drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
If north bridge selection register bit1 is clear, pins [10:8] are for SDIO0 Resetn, Wakeup, and PDN while if bit1 is set, pins [10:8]are for GPIO; when bit1 is clear, pin 9 and pin 10 can be used for uart2 RTSn and CTSn, so bit1 should be added to uart2 group and it must be set for both "gpio" and "uart" functions of uart2 group.
Signed-off-by: Ken Ma make@marvell.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Michal Simek michal.simek@xilinx.com Cc: Kostya Porotchkin kostap@marvell.com --- drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c index 3bb4c43..2ac66ec 100644 --- a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c +++ b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c @@ -159,8 +159,9 @@ static struct armada_37xx_pin_group armada_37xx_nb_groups[] = { PIN_GRP_GPIO("onewire", 4, 1, BIT(16), "onewire"), PIN_GRP_GPIO("uart1", 25, 2, BIT(17), "uart"), PIN_GRP_GPIO("spi_quad", 15, 2, BIT(18), "spi"), - PIN_GRP_EXTRA("uart2", 9, 2, BIT(13) | BIT(14) | BIT(19), - BIT(13) | BIT(14), BIT(19), 18, 2, "gpio", "uart"), + PIN_GRP_EXTRA("uart2", 9, 2, BIT(1) | BIT(13) | BIT(14) | BIT(19), + BIT(1) | BIT(13) | BIT(14), BIT(1) | BIT(19), + 18, 2, "gpio", "uart"), PIN_GRP_GPIO("led0_od", 11, 1, BIT(20), "led"), PIN_GRP_GPIO("led1_od", 12, 1, BIT(21), "led"), PIN_GRP_GPIO("led2_od", 13, 1, BIT(22), "led"),
In armada_37xx_gpiochip_register, the return value of fdtdec_get_bool should be true when gpio-controller is found; current codes makes a wrong inverse return value judgement, this patch fixes it.
Signed-off-by: Ken Ma make@marvell.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Michal Simek michal.simek@xilinx.com Cc: Kostya Porotchkin kostap@marvell.com --- drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c index 2ac66ec..27165b0 100644 --- a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c +++ b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c @@ -539,7 +539,7 @@ static int armada_37xx_gpiochip_register(struct udevice *parent, }
fdt_for_each_subnode(subnode, blob, node) { - if (!fdtdec_get_bool(blob, subnode, "gpio-controller")) { + if (fdtdec_get_bool(blob, subnode, "gpio-controller")) { ret = 0; break; }
make@marvell.com
