[PATCH] tools: env: update lock path in README
Commit aeb40f1166 ("tools: env: use /run to store lockfile") updated the path to the lockfile but did not update the documentation to match.
Use the new path in the documentation.
Fixes: aeb40f1166 ("tools: env: use /run to store lockfile") Signed-off-by: John Keeping john@metanate.com --- tools/env/README | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/env/README b/tools/env/README index 709251383c..480a893202 100644 --- a/tools/env/README +++ b/tools/env/README @@ -59,5 +59,5 @@ this environment instance. On NAND this is used to limit the range within which bad blocks are skipped, on NOR it is not used.
To prevent losing changes to the environment and to prevent confusing the MTD -drivers, a lock file at /var/lock/fw_printenv.lock is used to serialize access +drivers, a lock file at /run/fw_printenv.lock is used to serialize access to the environment.
Fixes: aeb40f1166 ("tools: env: use /run to store lockfile") Signed-off-by: John Keeping john@metanate.com Reviewed-by: Simon Glass sjg@chromium.org
John Keeping
