[U-Boot] [PATCH] ARM: imx6: DHCOM i.MX6 PDK: Switch to DM for I2C
This patch enables DM I2C for DHCOM i.MX6 PDK2 boards and removes non DM I2C code. Tested with DHCOM i.MX6dl and DHCOM i.MX6q.
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.com --- board/dhelectronics/dh_imx6/dh_imx6.c | 105 ++-------------------------------- configs/dh_imx6_defconfig | 7 +++ include/configs/dh_imx6.h | 8 --- 3 files changed, 13 insertions(+), 107 deletions(-)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6.c b/board/dhelectronics/dh_imx6/dh_imx6.c index cca8e832ec..b2a574f0cf 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6.c +++ b/board/dhelectronics/dh_imx6/dh_imx6.c @@ -36,92 +36,8 @@
DECLARE_GLOBAL_DATA_PTR;
-#define I2C_PAD_CTRL \ - (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ - PAD_CTL_HYS | PAD_CTL_ODE | PAD_CTL_SRE_FAST) - #define EEPROM_I2C_ADDRESS 0x50
-#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) - -static struct i2c_pads_info dh6sdl_i2c_pad_info0 = { - .scl = { - .i2c_mode = MX6DL_PAD_EIM_D21__I2C1_SCL | PC, - .gpio_mode = MX6DL_PAD_EIM_D21__GPIO3_IO21 | PC, - .gp = IMX_GPIO_NR(3, 21) - }, - .sda = { - .i2c_mode = MX6DL_PAD_EIM_D28__I2C1_SDA | PC, - .gpio_mode = MX6DL_PAD_EIM_D28__GPIO3_IO28 | PC, - .gp = IMX_GPIO_NR(3, 28) - } -}; - -static struct i2c_pads_info dh6sdl_i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6DL_PAD_KEY_COL3__I2C2_SCL | PC, - .gpio_mode = MX6DL_PAD_KEY_COL3__GPIO4_IO12 | PC, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6DL_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6DL_PAD_KEY_ROW3__GPIO4_IO13 | PC, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -static struct i2c_pads_info dh6sdl_i2c_pad_info2 = { - .scl = { - .i2c_mode = MX6DL_PAD_GPIO_3__I2C3_SCL | PC, - .gpio_mode = MX6DL_PAD_GPIO_3__GPIO1_IO03 | PC, - .gp = IMX_GPIO_NR(1, 3) - }, - .sda = { - .i2c_mode = MX6DL_PAD_GPIO_6__I2C3_SDA | PC, - .gpio_mode = MX6DL_PAD_GPIO_6__GPIO1_IO06 | PC, - .gp = IMX_GPIO_NR(1, 6) - } -}; - -static struct i2c_pads_info dh6dq_i2c_pad_info0 = { - .scl = { - .i2c_mode = MX6Q_PAD_EIM_D21__I2C1_SCL | PC, - .gpio_mode = MX6Q_PAD_EIM_D21__GPIO3_IO21 | PC, - .gp = IMX_GPIO_NR(3, 21) - }, - .sda = { - .i2c_mode = MX6Q_PAD_EIM_D28__I2C1_SDA | PC, - .gpio_mode = MX6Q_PAD_EIM_D28__GPIO3_IO28 | PC, - .gp = IMX_GPIO_NR(3, 28) - } -}; - -static struct i2c_pads_info dh6dq_i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6Q_PAD_KEY_COL3__I2C2_SCL | PC, - .gpio_mode = MX6Q_PAD_KEY_COL3__GPIO4_IO12 | PC, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6Q_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6Q_PAD_KEY_ROW3__GPIO4_IO13 | PC, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -static struct i2c_pads_info dh6dq_i2c_pad_info2 = { - .scl = { - .i2c_mode = MX6Q_PAD_GPIO_3__I2C3_SCL | PC, - .gpio_mode = MX6Q_PAD_GPIO_3__GPIO1_IO03 | PC, - .gp = IMX_GPIO_NR(1, 3) - }, - .sda = { - .i2c_mode = MX6Q_PAD_GPIO_6__I2C3_SDA | PC, - .gpio_mode = MX6Q_PAD_GPIO_6__GPIO1_IO06 | PC, - .gp = IMX_GPIO_NR(1, 6) - } -}; - int dram_init(void) { gd->ram_size = imx_ddr_size(); @@ -214,6 +130,7 @@ int board_usb_phy_mode(int port)
static int setup_dhcom_mac_from_fuse(void) { + struct udevice *dev; unsigned char enetaddr[6]; int ret;
@@ -228,13 +145,14 @@ static int setup_dhcom_mac_from_fuse(void) return 0; }
- ret = i2c_set_bus_num(2); +#ifdef CONFIG_SYS_I2C_MXC_I2C3 + ret = i2c_get_chip_for_busnum(2, EEPROM_I2C_ADDRESS, 1, &dev); if (ret) { - printf("Error switching I2C bus!\n"); + printf("Cannot find EEPROM!\n"); return ret; }
- ret = i2c_read(EEPROM_I2C_ADDRESS, 0xfa, 0x1, enetaddr, 0x6); + ret = dm_i2c_read(dev, 0xfa, enetaddr, 0x6); if (ret) { printf("Error reading configuration EEPROM!\n"); return ret; @@ -242,6 +160,7 @@ static int setup_dhcom_mac_from_fuse(void)
if (is_valid_ethaddr(enetaddr)) eth_env_set_enetaddr("ethaddr", enetaddr); +#endif
return 0; } @@ -265,18 +184,6 @@ int board_init(void) /* Enable eim_slow clocks */ setbits_le32(&mxc_ccm->CCGR6, 0x1 << MXC_CCM_CCGR6_EMI_SLOW_OFFSET);
-#ifdef CONFIG_SYS_I2C_MXC - if (is_mx6dq()) { - setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &dh6dq_i2c_pad_info0); - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &dh6dq_i2c_pad_info1); - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &dh6dq_i2c_pad_info2); - } else { - setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &dh6sdl_i2c_pad_info0); - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &dh6sdl_i2c_pad_info1); - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &dh6sdl_i2c_pad_info2); - } -#endif - setup_dhcom_mac_from_fuse();
return 0; diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 4734ed76e5..b0749a054f 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -48,6 +48,13 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_I2C_SET_DEFAULT_BUS_NUM=y +CONFIG_I2C_DEFAULT_BUS_NUMBER=0x2 +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 3b1d0a99a1..7d2e573846 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -48,14 +48,6 @@ #define CONFIG_FEC_MXC_PHYADDR 0 #define CONFIG_ARP_TIMEOUT 200UL
-/* I2C Configs */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ -#define CONFIG_SYS_I2C_SPEED 100000 - /* MMC Configs */ #define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0
On 7/3/19 10:20 AM, Ludwig Zenz wrote: [...]
- struct udevice *dev; unsigned char enetaddr[6]; int ret;
- ret = i2c_get_chip_for_busnum(2, EEPROM_I2C_ADDRESS, 1, &dev);
Isn't there some DM way which avoids using bus sequence numbers ? If there is, subsequent patch is fine.
if (ret) {
return ret; }printf("Cannot find EEPROM!\n");
- ret = dm_i2c_read(dev, 0xfa, enetaddr, 0x6); if (ret) { printf("Error reading configuration EEPROM!\n"); return ret;
Are these two ^ needed ?
Are these three ^ really needed ?
Ludwig Zenz
