[PATCH] pylibfdt: Fix disable version normalization
From: Philippe Schenker philippe.schenker@toradex.com
On Arch Linux based systems python setuptools does not contain "setuptools.extern" hence it is failing with the following error-message: " ModuleNotFoundError: No module named 'setuptools.extern' "
According to a eschwartz `setuptools.extern` is not a public API and shall not be assumed to be present in the setuptools package. He mentions that the setuptools project anyway wants to drop this. [1]
Use the correct solution introduced by python setuptools developers to disable normalization. [2]
[1] https://bbs.archlinux.org/viewtopic.php?id=259608 [2] https://github.com/pypa/setuptools/pull/2026 Fixes: 440098c42e73 ("pylibfdt: Fix version normalization warning") Signed-off-by: Philippe Schenker philippe.schenker@toradex.com
scripts/dtc/pylibfdt/setup.py | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/scripts/dtc/pylibfdt/setup.py b/scripts/dtc/pylibfdt/setup.py index 9abdb57595ad..c07f65e6bcaf 100755 --- a/scripts/dtc/pylibfdt/setup.py +++ b/scripts/dtc/pylibfdt/setup.py @@ -20,16 +20,12 @@ allows this script to be run stand-alone, e.g.: ./pylibfdt/setup.py install [--prefix=...] """
-from setuptools import setup, Extension +from setuptools import setup, Extension, sic from setuptools.command.build_py import build_py as _build_py -from setuptools.extern.packaging import version import os import re import sys
-# Disable version normalization -version.Version = version.LegacyVersion - srcdir = os.path.dirname(__file__)
with open(os.path.join(srcdir, "../README"), "r") as fh: @@ -141,7 +137,7 @@ class build_py(_build_py):
setup( name='libfdt', - version=version, + version=sic(version), cmdclass = {'build_py' : build_py}, author='Simon Glass', author_email='sjg@chromium.org',
Nice, thank you.
+CC Tom, this should go into this 2023.01 release.
Nice, thank you.
Yes, thanks. I saw a similar change via a GitHub PR that was on my list to properly resubmit.
Hi Philippe,
What are you doing to create that error?
- version=version,
- version=sic(version), cmdclass = {'build_py' : build_py}, author='Simon Glass', author_email='sjg@chromium.org',
-- 2.39.0
On Wed, 2023-01-04 at 13:01 -0700, Simon Glass wrote:
Hi Philippe,
Sorry for the late answer. I hit this error as soon as I tried to build U-Boot using "make *defconfig; make"
Regards,Philippe
- version=version,
-- 2.39.0
[1] https://bbs.archlinux.org/viewtopic.php?id=259608 [2] https://github.com/pypa/setuptools/pull/2026 Fixes: 440098c42e73 ("pylibfdt: Fix version normalization warning") Signed-off-by: Philippe Schenker philippe.schenker@toradex.com Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Simon Glass sjg@chromium.org
Philippe Schenker
