[U-Boot] [PATCH] arm, davinci: Add support for the Calimain board from OMICRON electronics
This patch adds support for the Calimain board from OMICRON electronics GmbH. The board features a Texas Instruments AM1808 SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and CS3.
Signed-off-by: Christian Riesch christian.riesch@omicron.at --- MAINTAINERS | 5 + board/omicron/calimain/Makefile | 45 +++++ board/omicron/calimain/calimain.c | 201 ++++++++++++++++++++ boards.cfg | 1 + include/configs/calimain.h | 364 +++++++++++++++++++++++++++++++++++++ 5 files changed, 616 insertions(+), 0 deletions(-) create mode 100644 board/omicron/calimain/Makefile create mode 100644 board/omicron/calimain/calimain.c create mode 100644 include/configs/calimain.h
diff --git a/MAINTAINERS b/MAINTAINERS index c79283f..25d7a95 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -792,6 +792,11 @@ Thierry Reding thierry.reding@avionic-design.de plutux Tegra2 (ARM7 & A9 Dual Core) medcom Tegra2 (ARM7 & A9 Dual Core)
+Christian Riesch christian.riesch@omicron.at +Manfred Rudigier manfred.rudigier@omicron.at + + calimain ARM926EJS (AM1808 SoC) + Tom Rini trini@ti.com
omap3_evm ARM ARMV7 (OMAP3xx SoC) diff --git a/board/omicron/calimain/Makefile b/board/omicron/calimain/Makefile new file mode 100644 index 0000000..cd1f0d4 --- /dev/null +++ b/board/omicron/calimain/Makefile @@ -0,0 +1,45 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/omicron/calimain/calimain.c b/board/omicron/calimain/calimain.c new file mode 100644 index 0000000..b2f2d96 --- /dev/null +++ b/board/omicron/calimain/calimain.c @@ -0,0 +1,201 @@ +/* + * Copyright (C) 2011 OMICRON electronics GmbH + * + * Based on da850evm.c. Original Copyrights follow: + * + * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2009 Nick Thompson, GE Fanuc, Ltd. nick.thompson@gefanuc.com + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <i2c.h> +#include <net.h> +#include <netdev.h> +#include <watchdog.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/gpio.h> +#include <asm/arch/emif_defs.h> +#include <asm/arch/emac_defs.h> +#include <asm/arch/pinmux_defs.h> +#include <asm/arch/davinci_misc.h> +#include <asm/arch/timer_defs.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define CALIMAIN_HWVERSION_MASK 0x7f000000 +#define CALIMAIN_HWVERSION_SHIFT 24 + +/* Hardware version pinmux settings */ +const struct pinmux_config hwversion_pins[] = { + { pinmux(16), 8, 2 }, /* GP7[15] */ + { pinmux(16), 8, 3 }, /* GP7[14] */ + { pinmux(16), 8, 4 }, /* GP7[13] */ + { pinmux(16), 8, 5 }, /* GP7[12] */ + { pinmux(16), 8, 6 }, /* GP7[11] */ + { pinmux(16), 8, 7 }, /* GP7[10] */ + { pinmux(17), 8, 0 }, /* GP7[9] */ + { pinmux(17), 8, 1 } /* GP7[8] */ +}; + +const struct pinmux_resource pinmuxes[] = { + PINMUX_ITEM(uart2_pins_txrx), + PINMUX_ITEM(emac_pins_mii), + PINMUX_ITEM(emac_pins_mdio), + PINMUX_ITEM(emifa_pins_nor), + PINMUX_ITEM(emifa_pins_cs2), + PINMUX_ITEM(emifa_pins_cs3), +}; + +const int pinmuxes_size = ARRAY_SIZE(pinmuxes); + +static const struct lpsc_resource lpsc[] = { + { DAVINCI_LPSC_AEMIF }, /* NAND, NOR */ + { DAVINCI_LPSC_EMAC }, /* image download */ + { DAVINCI_LPSC_UART2 }, /* console */ + { DAVINCI_LPSC_GPIO }, +}; + +/* read board revision from GPIO7[8..14] */ +u32 get_board_rev(void) +{ + lpsc_on(DAVINCI_LPSC_GPIO); + if (davinci_configure_pin_mux(hwversion_pins, + ARRAY_SIZE(hwversion_pins)) != 0) + return 0xffffffff; + + return (davinci_gpio_bank67->in_data & CALIMAIN_HWVERSION_MASK) + >> CALIMAIN_HWVERSION_SHIFT; +} + +/* + * determine the oscillator frequency depending on the board revision + * + * rev 0x00 ... 25 MHz oscillator + * rev 0x01 ... 24 MHz oscillator + */ +int calimain_get_osc_freq(void) +{ + u32 rev; + int freq; + + rev = get_board_rev(); + switch (rev) { + case 0x00: + freq = 25000000; + break; + default: + freq = 24000000; + break; + } + return freq; +} + + +int board_early_init_f(void) +{ + /* + * Power on required peripherals + * ARM does not have access by default to PSC0 and PSC1 + * assuming here that the DSP bootloader has set the IOPU + * such that PSC access is available to ARM + */ + if (da8xx_configure_lpsc_items(lpsc, ARRAY_SIZE(lpsc))) + return 1; + + return 0; +} + +int board_init(void) +{ + int val; + +#ifndef CONFIG_USE_IRQ + irq_init(); +#endif + + /* address of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + +#ifdef CONFIG_DRIVER_TI_EMAC + /* select emac MII mode */ + val = readl(&davinci_syscfg_regs->cfgchip3); + val &= ~(1 << 8); + writel(val, &davinci_syscfg_regs->cfgchip3); +#endif /* CONFIG_DRIVER_TI_EMAC */ + +#ifdef CONFIG_HW_WATCHDOG + davinci_hw_watchdog_enable(); +#endif + + printf("Input clock frequency: %d Hz\n", calimain_get_osc_freq()); + printf("Board revision: %d\n", get_board_rev()); + + return 0; +} + +#ifdef CONFIG_DRIVER_TI_EMAC +/* + * Initializes on-board ethernet controllers. + */ +int board_eth_init(bd_t *bis) +{ + if (!davinci_emac_initialize()) { + printf("Error: Ethernet init failed!\n"); + return -1; + } + + return 0; +} +#endif /* CONFIG_DRIVER_TI_EMAC */ + +#ifdef CONFIG_HW_WATCHDOG +void hw_watchdog_reset(void) +{ + davinci_hw_watchdog_reset(); +} +#endif + +#if defined(CONFIG_BOOTCOUNT_LIMIT) +void bootcount_store(ulong a) +{ + struct davinci_rtc *reg = + (struct davinci_rtc *)CONFIG_SYS_BOOTCOUNT_ADDR; + + /* + * write RTC kick register to enable write + * for RTC Scratch registers. Cratch0 and 1 are + * used for bootcount values. + */ + writel(RTC_KICK0R_WE, ®->kick0r); + writel(RTC_KICK1R_WE, ®->kick1r); + writel(a, ®->scratch0); + writel(BOOTCOUNT_MAGIC, ®->scratch1); +} + +ulong bootcount_load(void) +{ + struct davinci_rtc *reg = + (struct davinci_rtc *)CONFIG_SYS_BOOTCOUNT_ADDR; + + if (readl(®->scratch1) != BOOTCOUNT_MAGIC) + return 0; + else + return readl(®->scratch0); +} +#endif diff --git a/boards.cfg b/boards.cfg index da1a3ce..d0d046b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -136,6 +136,7 @@ hawkboard arm arm926ejs da8xxevm davinci hawkboard_nand arm arm926ejs da8xxevm davinci davinci hawkboard:NAND_U_BOOT hawkboard_uart arm arm926ejs da8xxevm davinci davinci hawkboard:UART_U_BOOT enbw_cmc arm arm926ejs enbw_cmc enbw davinci +calimain arm arm926ejs calimain omicron davinci km_kirkwood arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_DISABLE_PCI km_kirkwood_pci arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_RECONFIG_XLX mgcoge3un arm arm926ejs km_arm keymile kirkwood diff --git a/include/configs/calimain.h b/include/configs/calimain.h new file mode 100644 index 0000000..4a3b80a --- /dev/null +++ b/include/configs/calimain.h @@ -0,0 +1,364 @@ +/* + * Copyright (C) 2011 OMICRON electronics GmbH + * + * Based on da850evm.h. Original Copyrights follow: + * + * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/ + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * Board + */ +#define CONFIG_DRIVER_TI_EMAC +#define MACH_TYPE_CALIMAIN 3528 +#define CONFIG_MACH_TYPE MACH_TYPE_CALIMAIN + +/* + * SoC Configuration + */ +#define CONFIG_MACH_DAVINCI_CALIMAIN +#define CONFIG_ARM926EJS /* arm926ejs CPU core */ +#define CONFIG_SOC_DA8XX /* TI DA8xx SoC */ +#define CONFIG_SOC_DA850 /* TI DA850 SoC */ +#define CONFIG_SYS_CLK_FREQ clk_get(DAVINCI_ARM_CLKID) +#define CONFIG_SYS_OSCIN_FREQ calimain_get_osc_freq() +#define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE +#define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SYS_TEXT_BASE 0x60000000 +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_DA850_LOWLEVEL +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DA8XX_GPIO +#define CONFIG_HW_WATCHDOG +#define CONFIG_SYS_WDTTIMERBASE DAVINCI_TIMER1_BASE +#define CONFIG_SYS_WDT_PERIOD_LOW \ + (60 * CONFIG_SYS_OSCIN_FREQ) /* 60 s heartbeat */ +#define CONFIG_SYS_WDT_PERIOD_HIGH 0x0 +#define CONFIG_SYS_DV_NOR_BOOT_CFG (0x11) + +/* + * PLL configuration + */ +#define CONFIG_SYS_DV_CLKMODE 0 +#define CONFIG_SYS_DA850_PLL0_POSTDIV 1 +#define CONFIG_SYS_DA850_PLL0_PLLDIV1 0x8000 +#define CONFIG_SYS_DA850_PLL0_PLLDIV2 0x8001 +#define CONFIG_SYS_DA850_PLL0_PLLDIV3 0x8002 +#define CONFIG_SYS_DA850_PLL0_PLLDIV4 0x8003 +#define CONFIG_SYS_DA850_PLL0_PLLDIV5 0x8002 +#define CONFIG_SYS_DA850_PLL0_PLLDIV6 CONFIG_SYS_DA850_PLL0_PLLDIV1 +#define CONFIG_SYS_DA850_PLL0_PLLDIV7 0x8005 + +#define CONFIG_SYS_DA850_PLL1_POSTDIV 1 +#define CONFIG_SYS_DA850_PLL1_PLLDIV1 0x8000 +#define CONFIG_SYS_DA850_PLL1_PLLDIV2 0x8001 +#define CONFIG_SYS_DA850_PLL1_PLLDIV3 0x8002 + +#define CONFIG_SYS_DA850_PLL0_PLLM \ + ((calimain_get_osc_freq() == 25000000) ? 23 : 24) +#define CONFIG_SYS_DA850_PLL1_PLLM \ + ((calimain_get_osc_freq() == 25000000) ? 20 : 21) + +/* + * DDR2 memory configuration + */ +#define CONFIG_SYS_DA850_DDR2_DDRPHYCR (DV_DDR_PHY_PWRDNEN | \ + DV_DDR_PHY_EXT_STRBEN | \ + (0x4 << DV_DDR_PHY_RD_LATENCY_SHIFT)) + +#define CONFIG_SYS_DA850_DDR2_SDBCR ( \ + (1 << DV_DDR_SDCR_DDR2EN_SHIFT) | \ + (1 << DV_DDR_SDCR_DDRDRIVE0_SHIFT) | \ + (1 << DV_DDR_SDCR_DDREN_SHIFT) | \ + (1 << DV_DDR_SDCR_SDRAMEN_SHIFT) | \ + (1 << DV_DDR_SDCR_BUS_WIDTH_SHIFT) | \ + (0x3 << DV_DDR_SDCR_CL_SHIFT) | \ + (0x3 << DV_DDR_SDCR_IBANK_SHIFT) | \ + (0x2 << DV_DDR_SDCR_PAGESIZE_SHIFT)) + +/* SDBCR2 is only used if IBANK_POS bit in SDBCR is set */ +#define CONFIG_SYS_DA850_DDR2_SDBCR2 0 + +#define CONFIG_SYS_DA850_DDR2_SDTIMR ( \ + (16 << DV_DDR_SDTMR1_RFC_SHIFT) | \ + (1 << DV_DDR_SDTMR1_RP_SHIFT) | \ + (1 << DV_DDR_SDTMR1_RCD_SHIFT) | \ + (1 << DV_DDR_SDTMR1_WR_SHIFT) | \ + (5 << DV_DDR_SDTMR1_RAS_SHIFT) | \ + (7 << DV_DDR_SDTMR1_RC_SHIFT) | \ + (1 << DV_DDR_SDTMR1_RRD_SHIFT) | \ + (1 << DV_DDR_SDTMR1_WTR_SHIFT)) + +#define CONFIG_SYS_DA850_DDR2_SDTIMR2 ( \ + (7 << DV_DDR_SDTMR2_RASMAX_SHIFT) | \ + (2 << DV_DDR_SDTMR2_XP_SHIFT) | \ + (0 << DV_DDR_SDTMR2_ODT_SHIFT) | \ + (18 << DV_DDR_SDTMR2_XSNR_SHIFT) | \ + (199 << DV_DDR_SDTMR2_XSRD_SHIFT) | \ + (0 << DV_DDR_SDTMR2_RTP_SHIFT) | \ + (2 << DV_DDR_SDTMR2_CKE_SHIFT)) + +#define CONFIG_SYS_DA850_DDR2_SDRCR 0x000003FF +#define CONFIG_SYS_DA850_DDR2_PBBPR 0x30 + +/* + * Flash memory timing + */ + +#define CONFIG_SYS_DA850_CS2CFG ( \ + DAVINCI_ABCR_WSETUP(2) | \ + DAVINCI_ABCR_WSTROBE(5) | \ + DAVINCI_ABCR_WHOLD(3) | \ + DAVINCI_ABCR_RSETUP(1) | \ + DAVINCI_ABCR_RSTROBE(14) | \ + DAVINCI_ABCR_RHOLD(0) | \ + DAVINCI_ABCR_TA(3) | \ + DAVINCI_ABCR_ASIZE_16BIT) + +/* single 64 MB NOR flash device connected to CS2 and CS3 */ +#define CONFIG_SYS_DA850_CS3CFG CONFIG_SYS_DA850_CS2CFG + +/* + * Memory Info + */ +#define CONFIG_SYS_MALLOC_LEN (0x10000 + 1*1024*1024) /* malloc() len */ +#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ +#define PHYS_SDRAM_1_SIZE (128 << 20) /* SDRAM size 128MB */ +#define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* max size from SPRS586*/ + +#define CONFIG_SYS_DA850_SYSCFG_SUSPSRC ( \ + DAVINCI_SYSCFG_SUSPSRC_TIMER0 | \ + DAVINCI_SYSCFG_SUSPSRC_SPI1 | \ + DAVINCI_SYSCFG_SUSPSRC_UART2 | \ + DAVINCI_SYSCFG_SUSPSRC_EMAC | \ + DAVINCI_SYSCFG_SUSPSRC_I2C) + +/* memtest start addr */ +#define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM_1 + 0x2000000) + +/* memtest will be run on 16MB */ +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (16 << 20)) + +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define CONFIG_STACKSIZE (256*1024) /* regular stack */ + +/* + * Serial Driver info + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 /* NS16550 register size */ +#define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE /* Base address of UART2 */ +#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) +#define CONFIG_CONS_INDEX 1 /* use UART0 for console */ +#define CONFIG_BAUDRATE 115200 /* Default baud rate */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } +#define CONFIG_SYS_DA850_LPSC_UART DAVINCI_LPSC_UART2 + +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of flash banks */ +#define CONFIG_SYS_FLASH_SECT_SZ (128 << 10) /* 128KB */ +#define CONFIG_SYS_FLASH_BASE DAVINCI_ASYNC_EMIF_DATA_CE2_BASE +#define CONFIG_ENV_SECT_SIZE CONFIG_SYS_FLASH_SECT_SZ +#define CONFIG_ENV_ADDR \ + (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_FLASH_SECT_SZ * 2) +#define CONFIG_ENV_SIZE (128 << 10) +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define PHYS_FLASH_SIZE (64 << 20) /* Flash size 64MB */ +#define CONFIG_SYS_MAX_FLASH_SECT \ + ((PHYS_FLASH_SIZE/CONFIG_SYS_FLASH_SECT_SZ) + 3) + +/* + * Network & Ethernet Configuration + */ +#ifdef CONFIG_DRIVER_TI_EMAC +#define CONFIG_EMAC_MDIO_PHY_NUM 1 +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI +#endif + +/* + * U-Boot general configuration + */ +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "Calimain > " /* Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ +#define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) +#define CONFIG_LOADADDR 0xc0700000 +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* + * Linux Information + */ +#define LINUX_BOOT_PARAM_ADDR (PHYS_SDRAM_1 + 0x100) +#define CONFIG_CMDLINE_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTARGS "" +#define CONFIG_BOOTCOMMAND "run checkupdate; run checkbutton;" +#define CONFIG_BOOTDELAY 0 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_BOOT_RETRY_TIME 60 /* continue boot after 60 s inactivity */ +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_DELAY_STR "\x0d" /* press ENTER to interrupt BOOT */ +#define CONFIG_RESET_TO_RETRY + +/* + * Default environment settings + * gpio0 = button, gpio1 = led green, gpio2 = led red + * verify = n ... disable kernel checksum verification for faster booting + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "tftpdir=calimero\0" \ + "flashkernel=tftpboot $loadaddr $tftpdir/uImage; " \ + "erase 0x60800000 +0x400000; " \ + "cp.b $loadaddr 0x60800000 $filesize\0" \ + "flashrootfs=" \ + "tftpboot $loadaddr $tftpdir/rootfs.jffs2; " \ + "erase 0x60c00000 +0x2e00000; " \ + "cp.b $loadaddr 0x60c00000 $filesize\0" \ + "flashuboot=tftpboot $loadaddr $tftpdir/u-boot.bin; " \ + "protect off all; " \ + "erase 0x60000000 +0x80000; " \ + "cp.b $loadaddr 0x60000000 $filesize\0" \ + "flashrlk=tftpboot $loadaddr $tftpdir/uImage-rlk; " \ + "erase 0x60080000 +0x780000; " \ + "cp.b $loadaddr 0x60080000 $filesize\0" \ + "erase_persistent=erase 0x63a00000 +0x600000;\0" \ + "bootnor=setenv bootargs console=ttyS2,115200n8 " \ + "root=/dev/mtdblock3 rw rootfstype=jffs2 " \ + "rootwait ethaddr=$ethaddr; " \ + "gpio c 1; gpio s 2; bootm 0x60800000\0" \ + "bootrlk=gpio s 1; gpio s 2;" \ + "setenv bootargs console=ttyS2,115200n8 " \ + "ethaddr=$ethaddr; bootm 0x60080000\0" \ + "boottftp=setenv bootargs console=ttyS2,115200n8 " \ + "root=/dev/mtdblock3 rw rootfstype=jffs2 " \ + "rootwait ethaddr=$ethaddr; " \ + "tftpboot $loadaddr $tftpdir/uImage;" \ + "gpio c 1; gpio s 2; bootm $loadaddr\0" \ + "checkupdate=if test -n $update_flag; then " \ + "echo Previous update failed - starting RLK; " \ + "run bootrlk; fi; " \ + "if test -n $initial_setup; then " \ + "echo Running initial setup procedure; " \ + "sleep 1; run flashall; fi\0" \ + "product=accessory\0" \ + "serial=XX12345\0" \ + "checknor=" \ + "if gpio i 0; then run bootnor; fi;\0" \ + "checkrlk=" \ + "if gpio i 0; then run bootrlk; fi;\0" \ + "checkbutton=" \ + "run checknor; sleep 1;" \ + "run checknor; sleep 1;" \ + "run checknor; sleep 1;" \ + "run checknor; sleep 1;" \ + "run checknor;" \ + "gpio s 1; gpio s 2;" \ + "echo ---- Release button to boot RLK ----;" \ + "run checkrlk; sleep 1;" \ + "run checkrlk; sleep 1;" \ + "run checkrlk; sleep 1;" \ + "run checkrlk; sleep 1;" \ + "run checkrlk; sleep 1;" \ + "run checkrlk;" \ + "echo ---- Factory reset requested ----;" \ + "gpio c 1;" \ + "setenv factory_reset true;" \ + "saveenv;" \ + "run bootnor;\0" \ + "flashall=run flashrlk;" \ + "run flashkernel;" \ + "run flashrootfs;" \ + "setenv erase_datafs true;" \ + "setenv initial_setup;" \ + "saveenv;" \ + "run bootnor;\0" \ + "verify=n\0" \ + "clearenv=protect off all;" \ + "erase 0x60040000 +0x40000;\0" \ + "bootlimit=3\0" \ + "altbootcmd=run bootrlk\0" + +#define CONFIG_PREBOOT \ + "echo Version: $ver; " \ + "echo Serial: $serial; " \ + "echo MAC: $ethaddr; " \ + "echo Product: $product; " \ + "gpio c 1; gpio c 2;" + +/* + * U-Boot commands + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_GPIO + +#ifndef CONFIG_DRIVER_TI_EMAC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_PING +#endif + +/* additions for new relocation code, must added to all boards */ +#define CONFIG_SYS_SDRAM_BASE 0xc0000000 +/* initial stack pointer in internal SRAM */ +#define CONFIG_SYS_INIT_SP_ADDR (0x8001ff00) + +#define CONFIG_BOOTCOUNT_LIMIT +#define CONFIG_SYS_BOOTCOUNT_ADDR DAVINCI_RTC_BASE + +#ifndef __ASSEMBLY__ +int calimain_get_osc_freq(void); +#endif + +#endif /* __CONFIG_H */
On Tue, Jan 10, 2012 at 5:56 AM, Christian Riesch christian.riesch@omicron.at wrote:
[snip]
No longer used. Since there's one no longer used CONFIG variable can you please audit for others and then v2? Otherwise looks fine to me. Thanks.
Hello Christian,
just one comment, see below
- if (da8xx_configure_lpsc_items(lpsc, ARRAY_SIZE(lpsc)))
return 1;
Please look at my comment to the patch from Sughosh here:
http://lists.denx.de/pipermail/u-boot/2012-January/115312.html
da8xx_configure_lpsc_items() should used in arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c
so you can remove this here ... Maybe you can have a look at this patch too?
Rest looks good to me, thanks!
bye, Heiko
Hello Heiko,
On Wed, Jan 11, 2012 at 8:21 AM, Heiko Schocher hs@denx.de wrote:
Hello Christian,
Yes, I'll wait for v3 of Sughosh's patch and then resubmit. Regards, Christian
Christian Riesch
Heiko Schocher
