[PATCH] video: simplefb: modernise DT parsing
simplefb was using old style FDT parsing which doesn't behave well in combination with livetree. Update it to use ofnode instead and add a missing null check for the "format" property.
Standardise the error logging while we're here.
Fixes: 971d7e64245d ("video: simplefb") Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/video/simplefb.c | 32 ++++++++++++++++++++------------ 1 file changed, 20 insertions(+), 12 deletions(-)
diff --git a/drivers/video/simplefb.c b/drivers/video/simplefb.c index 235ec761f70b..3d83bf8f2e88 100644 --- a/drivers/video/simplefb.c +++ b/drivers/video/simplefb.c @@ -15,14 +15,14 @@ static int simple_video_probe(struct udevice *dev) { struct video_uc_plat *plat = dev_get_uclass_plat(dev); struct video_priv *uc_priv = dev_get_uclass_priv(dev); - const void *blob = gd->fdt_blob; - const int node = dev_of_offset(dev); + ofnode node = dev_ofnode(dev); const char *format; + int ret; fdt_addr_t base; fdt_size_t size; + u32 width, height, rot;
- base = fdtdec_get_addr_size_auto_parent(blob, dev_of_offset(dev->parent), - node, "reg", 0, &size, false); + base = dev_read_addr_size(dev, &size); if (base == FDT_ADDR_T_NONE) { debug("%s: Failed to decode memory region\n", __func__); return -EINVAL; @@ -41,17 +41,25 @@ static int simple_video_probe(struct udevice *dev)
debug("%s: Query resolution...\n", __func__);
- uc_priv->xsize = fdtdec_get_uint(blob, node, "width", 0); - uc_priv->ysize = fdtdec_get_uint(blob, node, "height", 0); - uc_priv->rot = fdtdec_get_uint(blob, node, "rot", 0); - if (uc_priv->rot > 3) { - log_debug("%s: invalid rot\n", __func__); - return log_msg_ret("rot", -EINVAL); + ret = ofnode_read_u32(node, "width", &width); + ret = ret ?: ofnode_read_u32(node, "height", &height); + if (ret || !width || !height) { + log_err("%s: invalid width or height: %d\n", __func__, ret); + return ret; } + ofnode_read_u32(node, "rot", &rot); + uc_priv->rot = rot; + uc_priv->xsize = width; + uc_priv->ysize = height;
- format = fdt_getprop(blob, node, "format", NULL); + format = ofnode_read_string(node, "format"); debug("%s: %dx%d@%s\n", __func__, uc_priv->xsize, uc_priv->ysize, format);
+ if (!format) { + log_err("%s: please add required property "format"\n", __func__); + return -EINVAL; + } + if (strcmp(format, "r5g6b5") == 0) { uc_priv->bpix = VIDEO_BPP16; } else if (strcmp(format, "a8b8g8r8") == 0 || @@ -67,7 +75,7 @@ static int simple_video_probe(struct udevice *dev) uc_priv->bpix = VIDEO_BPP32; uc_priv->format = VIDEO_X2R10G10B10; } else { - printf("%s: invalid format: %s\n", __func__, format); + log_err("%s: invalid format: %s\n", __func__, format); return -EINVAL; }
- ret = ofnode_read_u32(node, "width", &width);
- ret = ret ?: ofnode_read_u32(node, "height", &height);
- if (ret || !width || !height) {
return ret;
This should be something like:
return ret ?: -EINVAL;
Perhaps print the width and height in the error message as well.
regards, dan carpenter
On Fri, 16 Feb 2024 18:38:06 +0000 Caleb Connolly caleb.connolly@linaro.org wrote:
applied to u-boot-video.
-- Anatolij
Anatolij Gustschin
Caleb Connolly
Dan Carpenter
