Re: [U-Boot] [PATCH] arm: socfpga: Fix QSPI doesn't work on socdk board
On Dec 22, 2015, at 12:33 PM, Marek Vasut marex@denx.de wrote:
On Tuesday, December 22, 2015 at 09:19:16 PM, Marek Vasut wrote: On Tuesday, December 22, 2015 at 10:18:09 AM, shengjiangwu wrote:
Updated pinmux group MIXED1IO[15-20] for QSPI. Updated QSPI clock.
Signed-off-by: shengjiangwu shengjiangwu@icloud.com Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de
Applied, thanks.
I will push your patches to [1] in a few hours, can you try and see if the CV SOCDK works fine for you? Thanks
[1] http://git.denx.de/?p=u-boot/u-boot- socfpga.git;a=shortlog;h=refs/heads/master
Pushed. Please let me know how SoCDK works for you now and if there are still some problems.
Best regards, Marek Vasut
Hi Marek,
Thank you for your help, I tested the master branch, emac1 and QSPI works. Below is log.
Best Regards, ShengjiangWu
=> reset resetting ...
U-Boot SPL 2016.01-rc2-09121-gc339ea5 (Dec 23 2015 - 09:13:52) drivers/ddr/altera/sequencer.c: Preparing to start memory calibration drivers/ddr/altera/sequencer.c: CALIBRATION PASSED drivers/ddr/altera/sequencer.c: Calibration complete Trying to boot from MMC
U-Boot 2016.01-rc2-09121-gc339ea5 (Dec 23 2015 - 09:13:52 +0800)
CPU: Altera SoCFPGA Platform FPGA: Altera Cyclone V, SE/A6 or SX/C6 or ST/D6, version 0x0 BOOT: SD/MMC External Transceiver (1.8V) Watchdog enabled I2C: ready DRAM: 1 GiB MMC: dwmmc0@ff704000: 0 *** Warning - bad CRC, using default environment
In: serial Out: serial Err: serial Model: Altera SOCFPGA Cyclone V SoC Development Kit Net: Error: ethernet@ff702000 address not set. No ethernet found. Hit any key to stop autoboot: 0 => env default -a ## Resetting to default environment => setenv netmask 255.255.254.0 => setenv gatewayip 128.224.98.1 => setenv ipaddr 128.224.98.85 => setenv serverip 128.224.99.137 => setenv ethaddr 00:04:9f:13:57:b4 => saveenv Saving Environment to MMC... Writing to MMC(0)... done => reset resetting ...
CPU: Altera SoCFPGA Platform FPGA: Altera Cyclone V, SE/A6 or SX/C6 or ST/D6, version 0x0 BOOT: SD/MMC External Transceiver (1.8V) Watchdog enabled I2C: ready DRAM: 1 GiB MMC: dwmmc0@ff704000: 0 In: serial Out: serial Err: serial Model: Altera SOCFPGA Cyclone V SoC Development Kit Net: eth0: ethernet@ff702000 Hit any key to stop autoboot: 0 => tftp 0x8000000 /tftpboot/altera/uVxWorks Speed: 100, full duplex Using ethernet@ff702000 device TFTP from server 128.224.99.137; our IP address is 128.224.98.85 Filename '/tftpboot/altera/uVxWorks'. Load address: 0x8000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################ 3.3 MiB/s done Bytes transferred = 6418496 (61f040 hex) => sf probe SF: Detected N25Q1024 with page size 256 Bytes, erase size 64 KiB, total 128 MiB => sf read 0x7000000 0 0x60000 device 0 offset 0x0, size 0x60000 SF: 393216 bytes @ 0x0 Read: OK => md 0x7000000 07000000: ea00001a e59ff014 e59ff014 e59ff014 ................ 07000010: e59ff014 e59ff014 e59ff014 e59ff014 ................ 07000020: ffff0020 ffff0024 ffff0028 ffff002c ...$...(...,... 07000030: ffff0030 ffff0100 ffff0038 12345678 0.......8...xV4. 07000040: 31305341 2e160000 01390000 ea000007 AS01......9..... 07000050: 01000040 0000b854 0000b854 0000b900 @...T...T....... 07000060: 0000b854 0badc0de 0badc0de 0badc0de T............... 07000070: eb000040 e10f0000 e3c0001f e38000d3 @............... 07000080: e129f000 ee110f10 e3c00a02 ee010f10 ..)............. 07000090: e59f00a8 ee0c0f10 eb000008 eb000015 ................ 070000a0: eb000690 ee070f15 ee070f9a ee070f95 ................ 070000b0: e59f0088 ee0c0f10 e12fff1e e12fff1e ........../.../. 070000c0: e3a00000 ee080f17 ee070f15 ee070fd5 ................ 070000d0: ee070f9a ee070f95 ee110f10 e3c00a02 ................ 070000e0: e3c00007 e3800002 e3800b02 e3800a01 ................ 070000f0: ee010f10 e1a0f00e ea000018 e320f000 .............. . =>
Applied, thanks.
Hi Marek,
Good! so we're happy ? Can you give USB a spin too? I think it might have some issues and I don't have the necessary cable here.
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Wednesday, December 23, 2015 9:25 AM To: 圣江 吴 Cc: u-boot@lists.denx.de; clsee@altera.com; dinguyen@opensource.altera.com; dinh.linux@gmail.com; pavel@denx.de; sr@denx.de Subject: Re: [PATCH] arm: socfpga: Fix QSPI doesn't work on socdk board
Applied, thanks.
Hi Marek,
Hi Marek,
Yes, emac1 and qspi are working now. I'm afraid USB is not working,
=> usb reset resetting USB... USB0: Core Release: 2.93a dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! dwc_otg_core_host_init: Timeout! scanning bus 0 for devices... 1 USB Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) U-Boot Root Hub
Applied, thanks.
Hi Marek,
Hi Marek,
Hm, darn. Can you or Chin check it ? It's either pinmux or wrong USB node in DT in arch/arm/dts/socfpga_cyclone5_socdk.dts .
Hi Marek,
I am still setting up the SPL into SD card. In the mean time, I believe the error come from pinmux. Shengjiang, can you try out below change?
diff --git a/board/altera/cyclone5-socdk/qts/pinmux_config.h b/board/altera/cyclone5-socdk/qts/pinmux_config.h index 06783dc..fb8648b 100644 --- a/board/altera/cyclone5-socdk/qts/pinmux_config.h +++ b/board/altera/cyclone5-socdk/qts/pinmux_config.h @@ -8,20 +8,20 @@ #define __SOCFPGA_PINMUX_CONFIG_H__
const u8 sys_mgr_init_table[] = { - 3, /* EMACIO0 */ - 3, /* EMACIO1 */ - 3, /* EMACIO2 */ - 3, /* EMACIO3 */ - 3, /* EMACIO4 */ - 3, /* EMACIO5 */ - 3, /* EMACIO6 */ - 3, /* EMACIO7 */ - 3, /* EMACIO8 */ - 3, /* EMACIO9 */ - 3, /* EMACIO10 */ - 3, /* EMACIO11 */ - 3, /* EMACIO12 */ - 3, /* EMACIO13 */ + 0, /* EMACIO0 */ + 2, /* EMACIO1 */ + 2, /* EMACIO2 */ + 2, /* EMACIO3 */ + 2, /* EMACIO4 */ + 2, /* EMACIO5 */ + 2, /* EMACIO6 */ + 2, /* EMACIO7 */ + 2, /* EMACIO8 */ + 0, /* EMACIO9 */ + 2, /* EMACIO10 */ + 2, /* EMACIO11 */ + 2, /* EMACIO12 */ + 2, /* EMACIO13 */ 0, /* EMACIO14 */ 0, /* EMACIO15 */ 0, /* EMACIO16 */
Thanks Chin Liang
Chin Liang See
ShengjiangWu
圣江 吴
