[U-Boot] [PATCH] powerpc/85xx: enable mtdparts for nor flash
Enable mtdparts for nor flash of some P1/P2 boards that include p1020rdb-pd, p1021rdb-pc, p1022ds, p1025twr, and p2020rdb-pc.
Signed-off-by: Xie Xiaobo X.Xie@freescale.com Signed-off-by: Yangbo Lu yangbo.lu@freescale.com Cc: Scott Wood scottwood@freescale.com --- include/configs/P1022DS.h | 11 +++++++++++ include/configs/p1_p2_rdb_pc.h | 30 ++++++++++++++++++++++++++++++ include/configs/p1_twr.h | 11 +++++++++++ 3 files changed, 52 insertions(+)
diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 139d4fe..6f5c19c 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -620,6 +620,17 @@ #endif
/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=e8000000.nor" +#define MTDPARTS_DEFAULT \ + "mtdparts=e8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)" + +/* * Environment */ #ifdef CONFIG_SPIFLASH diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 07b6179..ec7d105 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -77,6 +77,16 @@ #define __SW_BOOT_NAND 0x44 #define __SW_BOOT_PCIE 0x74 #define CONFIG_SYS_L2_SIZE (256 << 10) +/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=ec000000.nor" +#define MTDPARTS_DEFAULT \ + "mtdparts=ec000000.nor:128k(dtb),6016k(kernel),57088k(fs),1m(vsc7385-firmware),1280k(u-boot)" #endif
#if defined(CONFIG_P1021RDB) @@ -95,6 +105,16 @@ #define __SW_BOOT_NAND 0xec #define __SW_BOOT_PCIE 0x6c #define CONFIG_SYS_L2_SIZE (256 << 10) +/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=ef000000.nor" +#define MTDPARTS_DEFAULT \ + "mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)" #endif
#if defined(CONFIG_P1024RDB) @@ -142,6 +162,16 @@ #define __SW_BOOT_NAND 0xe8 #define __SW_BOOT_PCIE 0xa8 #define CONFIG_SYS_L2_SIZE (512 << 10) +/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=ef000000.nor" +#define MTDPARTS_DEFAULT \ + "mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9984k(fs),1280k(u-boot)" #endif
#ifdef CONFIG_SDCARD diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index c296a07..f34ea33 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -389,6 +389,17 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif /* CONFIG_TWR-P1025 */
/* + * Dynamic MTD Partition support with mtdparts + */ +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=ec000000.nor" +#define MTDPARTS_DEFAULT \ + "mtdparts=ec000000.nor:256k(vsc7385-firmware),256k(dtb),5632k(kernel),57856k(fs),256k(qe-ucode-firmware),1280k(u-boot)" + +/* * Environment */ #ifdef CONFIG_SYS_RAMBOOT
Dear Yangbo Lu,
In message 1406534483-1076-1-git-send-email-yangbo.lu@freescale.com you wrote:
The Subject: is misleading - it suggest a global change for all 85xx boards, while actually only a few p10xx and p20xx boards are affected.
- "mtdparts=e8000000.nor:48m(ramdisk),14m(diagnostic),2m(dink),6m(kernel),58112k(fs),512k(dtb),768k(u-boot)"
- "mtdparts=ec000000.nor:128k(dtb),6016k(kernel),57088k(fs),1m(vsc7385-firmware),1280k(u-boot)"
- "mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9728k(fs),256k(qe-ucode-firmware),1280k(u-boot)"
- "mtdparts=ef000000.nor:256k(vsc7385-firmware),256k(dtb),4608k(kernel),9984k(fs),1280k(u-boot)"
- "mtdparts=ec000000.nor:256k(vsc7385-firmware),256k(dtb),5632k(kernel),57856k(fs),256k(qe-ucode-firmware),1280k(u-boot)"
Max line legth is still 80 characters. Please fix.
Yangbo Lu
