[U-Boot] [u-boot-denx-usb] Build break on current u-boot-usb master
Hi Marek,
When I was "cleaning up" my patchwork todo list I've found following problem (s):
A lot of boards are broken with message:
LD u-boot drivers/usb/host/built-in.o: In function `xhci_dwc3_remove': /home/lukma/work/embedded/u-boot-denx/drivers/usb/host/xhci-dwc3.c:161: undefined reference to `generic_phy_exit' drivers/usb/host/built-in.o: In function `xhci_dwc3_probe': /home/lukma/work/embedded/u-boot-denx/drivers/usb/host/xhci-dwc3.c:127: undefined reference to `generic_phy_get_by_index' /home/lukma/work/embedded/u-boot-denx/drivers/usb/host/xhci-dwc3.c:134: undefined reference to `generic_phy_init' /opt/tfk-sc58x/2.3/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.bfd: BFD (GNU Binutils) 2.28.0.20170307 assertion fail ../../bfd/elf32-arm.c:9512 /opt/tfk-sc58x/2.3/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.bfd: BFD (GNU Binutils) 2.28.0.20170307 assertion fail ../../bfd/elf32-arm.c:9512 /opt/tfk-sc58x/2.3/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.bfd: BFD (GNU Binutils) 2.28.0.20170307 assertion fail ../../bfd/elf32-arm.c:9512 Makefile:1248: recipe for target 'u-boot' failed
The branch is:
u-boot-usb/master
I've tried to do "bisect" but another error showed up:
drivers/usb/host/xhci-dwc3.c: In function ‘xhci_dwc3_probe’: drivers/usb/host/xhci-dwc3.c:109:29: warning: unused variable ‘plat’ [-Wunused-variable] struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); ^~~~ drivers/usb/host/xhci-dwc3.c: At top level: drivers/usb/host/xhci-dwc3.c:143:37: error: invalid application of ‘sizeof’ to incomplete type ‘struct xhci_dwc3_platdata’ .platdata_auto_alloc_size = sizeof(struct xhci_dwc3_platdata), ^~~~~~ scripts/Makefile.build:280: recipe for target 'drivers/usb/host/xhci-dwc3.o' failed make[1]: *** [drivers/usb/host/xhci-dwc3.o] Error 1
Patrice and Bin - please fix those errors and make the u-boot-usb tree bisectable again.
The last working commit:
commit 041a8808fd06b4a276dd6fbbb5153deb3b5d391c Author: Masahiro Yamada yamada.masahiro@socionext.com Date: Thu Jun 22 16:35:14 2017 +0900
usb: add static to local symbols
Sparse reports "... was not declared. Should it be static?"
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com
For easy reproduction please use odroid-xu3_defconfig.
On 07/22/2017 08:18 PM, Łukasz Majewski wrote:
Hi Marek,
The branch is:
u-boot-usb/master
I believe this is already underway since 2 days ago: https://www.mail-archive.com/u-boot@lists.denx.de/msg256611.html
Hi Marek,
The branch is:
u-boot-usb/master
Ok. Good :-) Thanks
Hi Marek
Hi Marek,
The branch is:
u-boot-usb/master
Regarding the bisection issue detected by Łukasz, it will imposed to replace my "Extend xhci-dwc3" series already merged into your u-boot-usb branch.
How do you want to proceed ? I can resubmit the full 2 series with all fixes (bisection + compilation issue) for "usb: Extend ehci and ohci generic driver" and "Extend xhci-dwc3"
Patrice
On Mon, Jul 24, 2017 at 2:48 PM, Patrice CHOTARD patrice.chotard@st.com wrote:
Hi Marek
Hi Marek,
The branch is:
u-boot-usb/master
I think Marek can drop your previous series on u-boot-usb/master completely then reapply your new series. After all, it's not on u-boot/master yet, so everything can change.
Regards, Bin
Hi Marek
Hi Marek,
The branch is:
u-boot-usb/master
+1
Regards, Bin
Hi Marek
Hi Marek,
The branch is:
u-boot-usb/master
+1
I'd prefer incremental changes, so it's easier to review .
Hi Marek
Hi Marek,
The branch is:
u-boot-usb/master
+1
Oh, and please, do NOT resubmit patches before getting feedback from me, it really doesn't help. I just deleted both series I had from you.
Bin Meng
Patrice CHOTARD
Łukasz Majewski
