[PATCH v2 00/10] Add support for Ethernet Boot on SK-AM62
This series enables Ethernet Boot on SK-AM62 device.
Link to v1: https://lore.kernel.org/all/20240112064759.1801600-1-s-vadapalli@ti.com/
Changes from v1 to v2: - Updated dram_init_banksize() function to be called from common section instead of board specific function call as suggested by Tom. - Dropped [PATCH 06/10] from this version since it was a clean up patch and not required for AM62x Ethernet Boot functionality. - Removed independent defconfig files for R5 and A53 configs and created a config fragment for them as suggested by Nishanth. - Added new patch [PATCH v2 10/10] in this series to enable CPSW MAC's PHY node "phy_gmii_sel" which is required for Ethernet Boot.
This changes are done as per discussion here: https://lore.kernel.org/r/20240112064759.1801600-1-s-vadapalli@ti.com/
Logs: https://gist.github.com/chintanv133/07bcb1473301581aab6d4e951d9c6572
Chintan Vankar (2): common: spl: spl: Init DRAM size in R5/A53 SPL arch: arm: dts: k3-am62-sk-u-boot: Add missing "bootph-all" property to phy_gmii_sel node
Kishon Vijay Abraham I (6): firmware: ti_sci: Add No-OP for "RX_FL_CFG" soc: ti: k3-navss-ringacc: Initialize base address of ring cfg registers dma: ti: k3-udma: Add support for native configuration of chan/flow arm: mach-k3: am625_init: Probe AM65 CPSW NUSS configs: am62: Add configs for enabling ETHBOOT in R5SPL configs: am62: Enable configs required for Ethboot
Siddharth Vadapalli (1): arm: dts: k3-am625-r5-sk: Enable DM services for main_pktdma
Vignesh Raghavendra (1): soc: ti: k3-navss-ringacc: Fix reset ring API
arch/arm/dts/k3-am625-r5-sk.dts | 5 +++++ arch/arm/dts/k3-am625-sk-u-boot.dtsi | 4 ++++ arch/arm/mach-k3/am625_init.c | 10 ++++++++++ common/spl/spl.c | 2 +- configs/am62x_evm_a53_ethboot_defconfig | 11 +++++++++++ configs/am62x_evm_r5_ethboot_defconfig | 19 +++++++++++++++++++ drivers/dma/ti/k3-udma.c | 6 ++++++ drivers/firmware/ti_sci.c | 8 +++++++- drivers/soc/ti/k3-navss-ringacc-u-boot.c | 9 ++++++++- drivers/soc/ti/k3-navss-ringacc.c | 7 ++++++- 10 files changed, 77 insertions(+), 4 deletions(-) create mode 100644 configs/am62x_evm_a53_ethboot_defconfig create mode 100644 configs/am62x_evm_r5_ethboot_defconfig
Initialize DRAM size in SPL stage since networking requires DDR to be initialized.
Signed-off-by: Chintan Vankar c-vankar@ti.com ---
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-2-s-vadapalli@ti.com/
common/spl/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index e06bc75d36..2a9d58195c 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -718,7 +718,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) initr_watchdog();
if (IS_ENABLED(CONFIG_SPL_OS_BOOT) || CONFIG_IS_ENABLED(HANDOFF) || - IS_ENABLED(CONFIG_SPL_ATF)) + IS_ENABLED(CONFIG_SPL_ATF) || IS_ENABLED(CONFIG_SPL_NET)) dram_init_banksize();
if (CONFIG_IS_ENABLED(PCI) && !(gd->flags & GD_FLG_DM_DEAD)) {
RX_FL_CFG message should not be forwarded to TIFS and should be handled within R5 SPL (when DM services are not available). Add a no-op function to not handle RX_FL_CFG messages.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com Signed-off-by: Chintan Vankar c-vankar@ti.com ---
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-3-s-vadapalli@ti.com/
Changes from v1 to v2: - No changes.
drivers/firmware/ti_sci.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/firmware/ti_sci.c b/drivers/firmware/ti_sci.c index 6c581b9df9..2e9cc1d86c 100644 --- a/drivers/firmware/ti_sci.c +++ b/drivers/firmware/ti_sci.c @@ -2452,6 +2452,12 @@ fail: return ret; }
+static int ti_sci_cmd_rm_udmap_rx_flow_cfg_noop(const struct ti_sci_handle *handle, + const struct ti_sci_msg_rm_udmap_flow_cfg *params) +{ + return 0; +} + /** * ti_sci_cmd_set_fwl_region() - Request for configuring a firewall region * @handle: pointer to TI SCI handle @@ -2897,7 +2903,7 @@ static __maybe_unused int ti_sci_dm_probe(struct udevice *dev) udmap_ops = &ops->rm_udmap_ops; udmap_ops->tx_ch_cfg = ti_sci_cmd_rm_udmap_tx_ch_cfg; udmap_ops->rx_ch_cfg = ti_sci_cmd_rm_udmap_rx_ch_cfg; - udmap_ops->rx_flow_cfg = ti_sci_cmd_rm_udmap_rx_flow_cfg; + udmap_ops->rx_flow_cfg = ti_sci_cmd_rm_udmap_rx_flow_cfg_noop;
return ret; }
Initialize base address of ring config registers required to natively setup ring cfg registers in the absence of Device Manager (DM) services at R5 SPL stage.
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-4-s-vadapalli@ti.com/
drivers/soc/ti/k3-navss-ringacc.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/soc/ti/k3-navss-ringacc.c b/drivers/soc/ti/k3-navss-ringacc.c index ed39ff2fa4..0a96ed666c 100644 --- a/drivers/soc/ti/k3-navss-ringacc.c +++ b/drivers/soc/ti/k3-navss-ringacc.c @@ -1030,8 +1030,8 @@ static int k3_nav_ringacc_init(struct udevice *dev, struct k3_nav_ringacc *ringa struct k3_nav_ringacc *k3_ringacc_dmarings_init(struct udevice *dev, struct k3_ringacc_init_data *data) { + void __iomem *base_rt, *base_cfg; struct k3_nav_ringacc *ringacc; - void __iomem *base_rt; int i;
ringacc = devm_kzalloc(dev, sizeof(*ringacc), GFP_KERNEL); @@ -1049,6 +1049,10 @@ struct k3_nav_ringacc *k3_ringacc_dmarings_init(struct udevice *dev, if (!base_rt) return ERR_PTR(-EINVAL);
+ base_cfg = dev_read_addr_name_ptr(dev, "cfg"); + if (!base_cfg) + return ERR_PTR(-EINVAL); + ringacc->rings = devm_kzalloc(dev, sizeof(*ringacc->rings) * ringacc->num_rings * 2, @@ -1063,6 +1067,7 @@ struct k3_nav_ringacc *k3_ringacc_dmarings_init(struct udevice *dev, for (i = 0; i < ringacc->num_rings; i++) { struct k3_nav_ring *ring = &ringacc->rings[i];
+ ring->cfg = base_cfg + KNAV_RINGACC_CFG_REGS_STEP * i; ring->rt = base_rt + K3_DMARING_RING_RT_REGS_STEP * i; ring->parent = ringacc; ring->ring_id = i;
Expectation of k3_ringacc_ring_reset_raw() is to reset the ring to requested size and not to 0. Fix this.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com Signed-off-by: Chintan Vankar c-vankar@ti.com ---
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-5-s-vadapalli@ti.com/
drivers/soc/ti/k3-navss-ringacc-u-boot.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/soc/ti/k3-navss-ringacc-u-boot.c b/drivers/soc/ti/k3-navss-ringacc-u-boot.c index f958239c2a..5d650b9de7 100644 --- a/drivers/soc/ti/k3-navss-ringacc-u-boot.c +++ b/drivers/soc/ti/k3-navss-ringacc-u-boot.c @@ -25,9 +25,16 @@ struct k3_nav_ring_cfg_regs { #define KNAV_RINGACC_CFG_RING_SIZE_ELSIZE_MASK GENMASK(26, 24) #define KNAV_RINGACC_CFG_RING_SIZE_ELSIZE_SHIFT (24)
+#define KNAV_RINGACC_CFG_RING_SIZE_MASK GENMASK(15, 0) + static void k3_ringacc_ring_reset_raw(struct k3_nav_ring *ring) { - writel(0, &ring->cfg->size); + u32 reg; + + reg = readl(&ring->cfg->size); + reg &= KNAV_RINGACC_CFG_RING_SIZE_MASK; + reg |= ring->size; + writel(reg, &ring->cfg->size); }
static void k3_ringacc_ring_reconfig_qmode_raw(struct k3_nav_ring *ring, enum k3_nav_ring_mode mode)
In absence of Device Manager (DM) services such as at R5 SPL stage, driver will have to natively setup TCHAN/RCHAN/RFLOW cfg registers. Existing UDMA driver performed the above mentioned configuration for UDMA. Add similar configuration for PKTDMA here.
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-6-s-vadapalli@ti.com/
drivers/dma/ti/k3-udma.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/dma/ti/k3-udma.c b/drivers/dma/ti/k3-udma.c index ef3074aa13..ad3fa4a515 100644 --- a/drivers/dma/ti/k3-udma.c +++ b/drivers/dma/ti/k3-udma.c @@ -2119,6 +2119,9 @@ static int bcdma_tisci_tx_channel_config(struct udma_chan *uc) if (ret) dev_err(ud->dev, "tchan%d cfg failed %d\n", tchan->id, ret);
+ if (IS_ENABLED(CONFIG_K3_DM_FW)) + udma_alloc_tchan_raw(uc); + return ret; }
@@ -2167,6 +2170,9 @@ static int pktdma_tisci_rx_channel_config(struct udma_chan *uc) dev_err(ud->dev, "flow%d config failed: %d\n", uc->rflow->id, ret);
+ if (IS_ENABLED(CONFIG_K3_DM_FW)) + udma_alloc_rchan_raw(uc); + return ret; }
In order to support Ethernet boot on AM62x, probe AM65 CPSW NUSS driver in board_init_f().
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-8-s-vadapalli@ti.com/
arch/arm/mach-k3/am625_init.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c index 668f9a51ef..9bf61b1e83 100644 --- a/arch/arm/mach-k3/am625_init.c +++ b/arch/arm/mach-k3/am625_init.c @@ -277,6 +277,16 @@ void board_init_f(ulong dummy) if (ret) panic("DRAM init failed: %d\n", ret); } + + if (IS_ENABLED(CONFIG_SPL_ETH) && IS_ENABLED(CONFIG_TI_AM65_CPSW_NUSS) && + spl_boot_device() == BOOT_DEVICE_ETHERNET) { + struct udevice *cpswdev; + + if (uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(am65_cpsw_nuss), + &cpswdev)) + printf("Failed to probe am65_cpsw_nuss driver\n"); + } + spl_enable_cache();
fixup_a53_cpu_freq_by_speed_grade();
- No changes.
- if (IS_ENABLED(CONFIG_SPL_ETH) && IS_ENABLED(CONFIG_TI_AM65_CPSW_NUSS) &&
&cpswdev))
This looks like a HACK. The network driver should be probed only when the networking feature is actually required.
spl_enable_cache();
No changes.
&cpswdev))
Driver is probed only when the condition above "spl_boot_device() == BOOT_DEVICE_ETHERNET" is true, which says Boot device is Ethernet, and here we are booting with Ethernet so driver is getting probed.
spl_enable_cache();
- No changes.
I think you misunderstood what I was saying as am625_init.c is not using any Ethernet function it should not cause the Ethernet driver to probe.
Instead it should be probed by the networking use case.
What happens if you don't use this patch? Where is it failing?
spl_enable_cache(); fixup_a53_cpu_freq_by_speed_grade();
- No changes.
You are correct that it should be probed by the networking use case and we are using networking functionality of "Booting via Ethernet". Regarding its probing, I already had discussion that why do I have to probe it explicitly at here: https://lore.kernel.org/r/ee1d16fd-b99b-4b07-97bb-a896e179157a@ti.com/
Now if I don't use this patch then Ethernet will not get initialized at SPL stage, and in "spl_net_load_image()" function, there will be an error saying "No Ethernet Found", and since we selected booting via Ethernet it will fail to boot.
- No changes.
OK Now I see the problem.
in am65-cpsw-nuss.c the following is defined:
U_BOOT_DRIVER(am65_cpsw_nuss) = { .name = "am65_cpsw_nuss", .id = UCLASS_MISC, .of_match = am65_cpsw_nuss_ids, .probe = am65_cpsw_probe_nuss, .priv_auto = sizeof(struct am65_cpsw_common), };
U_BOOT_DRIVER(am65_cpsw_nuss_port) = { .name = "am65_cpsw_nuss_port", .id = UCLASS_ETH, .probe = am65_cpsw_port_probe, .ops = &am65_cpsw_ops, .priv_auto = sizeof(struct am65_cpsw_priv), .plat_auto = sizeof(struct eth_pdata), .flags = DM_FLAG_ALLOC_PRIV_DMA | DM_FLAG_OS_PREPARE, };
Now I suppose spl_net_load_image() tries to probe all UCLASS_ETH devices which should call am65_cpsw_port_probe() but it fails to probe am65_cpsw_probe_nuss().
This limitation was introduced by commit 38922b1f4acc ("net: ti: am65-cpsw: Add support for multi port independent MAC mode")
which says "Since top level driver is now UCLASS_MISC, board files would need to instantiate this driver explicitly.
I wonder if there can be a better solution to this?
Add configs for enabling ETHBOOT in R5SPL.
Signed-off-by: Kishon Vijay Abraham I kishon@ti.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com Signed-off-by: Chintan Vankar c-vankar@ti.com ---
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-9-s-vadapalli@ti.com/
Changes from v1 to v2: - Removed independent defconfig files for R5 configs and created a config fragment for them as suggested by Nishanth.
configs/am62x_evm_r5_ethboot_defconfig | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+) create mode 100644 configs/am62x_evm_r5_ethboot_defconfig
diff --git a/configs/am62x_evm_r5_ethboot_defconfig b/configs/am62x_evm_r5_ethboot_defconfig new file mode 100644 index 0000000000..5100165aa2 --- /dev/null +++ b/configs/am62x_evm_r5_ethboot_defconfig @@ -0,0 +1,19 @@ +#include<configs/am62x_evm_r5_defconfig> + +CONFIG_SPL_GPIO=y +CONFIG_SPL_MMC=n +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200000 +CONFIG_SPL_DMA=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_ETH=y +CONFIG_SPL_I2C=y +CONFIG_SPL_NET=y +CONFIG_SPL_NET_VCI_STRING="AM62X U-Boot R5 SPL" +CONFIG_CMD_DHCP=y +CONFIG_SPL_SYSCON=y +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y +CONFIG_DM_I2C=y +CONFIG_PHY_TI_DP83867=y +CONFIG_TI_AM65_CPSW_NUSS=y
Enable config options needed to support Ethernet boot on AM62x SK.
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-10-s-vadapalli@ti.com/
Changes from v1 to v2: - Removed independent defconfig files for A53 configs and created a config fragment for them as suggested by Nishanth.
configs/am62x_evm_a53_ethboot_defconfig | 11 +++++++++++ 1 file changed, 11 insertions(+) create mode 100644 configs/am62x_evm_a53_ethboot_defconfig
diff --git a/configs/am62x_evm_a53_ethboot_defconfig b/configs/am62x_evm_a53_ethboot_defconfig new file mode 100644 index 0000000000..e49221ee23 --- /dev/null +++ b/configs/am62x_evm_a53_ethboot_defconfig @@ -0,0 +1,11 @@ +#include <configs/am62x_evm_a53_defconfig> + +CONFIG_SPL_STACK_R_ADDR=0x83000000 +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_DMA=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_ETH=y +CONFIG_SPL_NET=y +CONFIG_SPL_NET_VCI_STRING="AM62X U-Boot A53 SPL" +CONFIG_SPL_SYSCON=y
Enable DM services for main_pktdma during R5 SPL stage.
Link to v1: https://lore.kernel.org/r/20240112064759.1801600-11-s-vadapalli@ti.com/
arch/arm/dts/k3-am625-r5-sk.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/k3-am625-r5-sk.dts b/arch/arm/dts/k3-am625-r5-sk.dts index 6b9f40e555..0912b953db 100644 --- a/arch/arm/dts/k3-am625-r5-sk.dts +++ b/arch/arm/dts/k3-am625-r5-sk.dts @@ -83,3 +83,8 @@ reg = <0x00 0x0fc40000 0x00 0x100>, <0x00 0x60000000 0x00 0x08000000>; }; + +&main_pktdma { + ti,sci = <&dm_tifs>; + bootph-all; +};
Add "bootph-all" property to CPSW MAC's PHY node phy_gmii_sel.
Changes from v1 to v2: - This patch is newly added in this series to enable CPSW MAC's PHY node "phy_gmii_sel". As per discussion at here: https://lore.kernel.org/r/20240112130127.rvvrhz7p4vmlyalh@smother/ changes made by this patch can be dropped in the future when the DT-Sync is performed with am62-main.dtsi containing this change in the Linux DT which will match U-Boot's DT.
arch/arm/dts/k3-am625-sk-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index fa778b0ff4..e9a1afde95 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -46,3 +46,7 @@ &cpsw_port2 { status = "disabled"; }; + +&phy_gmii_sel { + bootph-all; +};
I don't think bootph-all exists in am62-main.dtsi. It should come from board.dts
+&phy_gmii_sel {
- bootph-all;
Yes, I am having the same discussion at here: https://lore.kernel.org/all/c13ac165-7cbd-4e53-914e-8c6bc28250e3@ti.com/
+&phy_gmii_sel {
- bootph-all;
Since I have posted patch which adds bootph-all property to "k3-am62x-sk-common.dtsi" at here: https://lore.kernel.org/r/20240430085048.3143665-1-c-vankar@ti.com/ and it has no open comments and this series also does not have any open comments, so can it be merged ?
Since bootph-all is being added to k3-am62x-sk-common.dtsi don't you have to drop patch 10 from this series?
Yes you are correct, but that patch is not merged yet.
Chintan Vankar
Roger Quadros
