[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 5cf618ee60a752d058a767372ca1ecb8d9c09b16:
Merge git://git.denx.de/u-boot-arc (2017-03-24 08:19:30 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git
for you to fetch changes up to 78be6222b01efa12d9267876ad1d1d0daf38dfa0:
pcie-layerscape: Fixup iommu-map property of pci node (2017-03-28 10:54:09 -0700)
---------------------------------------------------------------- Ashish kumar (1): armv8: fsl-lsch3: Conditionally apply workaround for erratum a0009203
Bharat Bhushan (7): armv8: fsl-lsch3: rename ls2080a_stream_id.h to stream_id_lsch3.h armv8: fsl-lsch3: Rewrite comment for stream IDs arvm8: pcie-layerscape: Define stream-ids for Layerscape Chassis-2 armv8: fsl-lsch2: Use Chassis-2 streamid definition for ls1046a armv8: fsl-lsch2: Use Chassis-2 streamid definition for ls1012a pcie-layerscape: Initialize pci-lut for NXP chasis-2 socs pcie-layerscape: Fixup iommu-map property of pci node
Hou Zhiqiang (9): fsl-layerscape/ppa: cleanup ppa.h pci: layerscape: enable PCIe config ready pci: layerscape: add LS2088A series SoC pcie support pci: layerscape: Fixup device tree node for ls2088a mtd: nand: add initialization flag mtd: nand: remove nand size print from nand_init function fsl: PPA: add support PPA image loading from NAND and SD armv8: Kconfig: fsl-ppa: support load PPA from eMMC/SD and NAND Flash fsl-layerscape/ls104xardb: enable PPA support for eMMC/SD and NAND boot
Prabhakar Kushwaha (2): arm: fsl-layerscape: Move QSGMII wriop_init to SoC file armv8:fsl-layerscape: Avoid RCWSR28 register hard-coding
Priyanka Jain (1): armv8/fsl-layerscape: Update erratum A009635 implementation
Santan Kumar (2): armv8: ls2080ardb, ls2080aqds: Add mcmemsize in default env setting board: freescale: ls2080a/ls2088a: Enable PPA
Suresh Gupta (2): spi: fsl_qspi: Add support for single chip select armv8: dts: fsl-ls1012a: Change number of CS in SPI node
Udit Agarwal (3): armv8: lsch3: SECURE_BOOT: Define CONFIG_SYS_LS_PPA_ESBC_ADDR for LS2080A armv8: LS2080A: Move sec_init to board_init fsl: Secure Boot: Enable IE (Key extention) Feature
Wenbin Song (1): armv8: ls1043a/ls1046aqds: fix the offsets of MTD partitions on NOR flash
Yingxi Yu (1): armv8/fsl-layerscape: fdt: Skip checking USB clock on LS1012A
yuan linyu (1): tools: plbimage support generate rcw file
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 20 +++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 55 +++++++- arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 3 +- .../cpu/armv8/fsl-layerscape/fsl_lsch3_serdes.c | 53 ++++---- arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 143 ++++++++++++++++++++- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 4 + arch/arm/dts/fsl-ls1012a.dtsi | 2 +- .../include/asm/arch-fsl-layerscape/fsl_serdes.h | 8 +- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 9 ++ arch/arm/include/asm/arch-fsl-layerscape/ppa.h | 7 +- .../asm/arch-fsl-layerscape/stream_id_lsch2.h | 63 +++++++++ .../{ls2080a_stream_id.h => stream_id_lsch3.h} | 15 ++- arch/arm/include/asm/armv8/sec_firmware.h | 4 - arch/arm/include/asm/fsl_secure_boot.h | 8 +- board/freescale/common/fsl_validate.c | 88 ++++++++++--- board/freescale/ls1043ardb/ls1043ardb.c | 2 - board/freescale/ls2080aqds/ls2080aqds.c | 13 +- board/freescale/ls2080ardb/ls2080ardb.c | 11 +- common/board_r.c | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1046ardb_emmc_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + drivers/mtd/nand/nand.c | 17 ++- drivers/net/ldpaa_eth/ls2080a.c | 30 +++++ drivers/pci/pcie_layerscape.c | 42 ++++++ drivers/pci/pcie_layerscape.h | 10 ++ drivers/pci/pcie_layerscape_fixup.c | 94 ++++++++++++-- drivers/spi/fsl_qspi.c | 5 +- include/configs/ls1012a_common.h | 1 + include/configs/ls1043a_common.h | 15 ++- include/configs/ls1046a_common.h | 1 + include/configs/ls1046aqds.h | 14 +- include/configs/ls2080a_common.h | 2 +- include/configs/ls2080aqds.h | 2 + include/configs/ls2080ardb.h | 2 + include/fsl-mc/ldpaa_wriop.h | 1 + include/fsl_validate.h | 24 +++- include/nand.h | 1 + tools/pblimage.c | 48 ++++--- 42 files changed, 691 insertions(+), 133 deletions(-) create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h rename arch/arm/include/asm/arch-fsl-layerscape/{ls2080a_stream_id.h => stream_id_lsch3.h} (80%)
Thanks.
York
On Tue, Mar 28, 2017 at 06:02:35PM +0000, york sun wrote:
Tom,
york sun
