[PATCH] watchdog: Drop GD_FLG_WDT_READY as it's not used any more
Since commit c2fd0ca1a822 ("watchdog: Integrate watchdog triggering into the cyclic framework") GD_FLG_WDT_READY has become write-only. This patch now removes this flag completely.
The vacant spot in gd_flags is filled with the newly introduced GD_FLG_CYCLIC_RUNNING flag.
Suggested-by: Rasmus Villemoes rasmus.villemoes@prevas.dk Signed-off-by: Stefan Roese sr@denx.de --- drivers/watchdog/wdt-uclass.c | 1 - include/asm-generic/global_data.h | 8 ++------ 2 files changed, 2 insertions(+), 7 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index 82df0ff0be5a..509896a1b808 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -105,7 +105,6 @@ int initr_watchdog(void) init_watchdog_dev(dev); }
- gd->flags |= GD_FLG_WDT_READY; return 0; }
diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 88829126fb2a..da17ac8cbc88 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -635,9 +635,9 @@ enum gd_flags { */ GD_FLG_LOG_READY = 0x10000, /** - * @GD_FLG_WDT_READY: watchdog is ready for use + * @GD_FLG_CYCLIC_RUNNING: cyclic_run is in progress */ - GD_FLG_WDT_READY = 0x20000, + GD_FLG_CYCLIC_RUNNING = 0x20000, /** * @GD_FLG_SKIP_LL_INIT: don't perform low-level initialization */ @@ -650,10 +650,6 @@ enum gd_flags { * @GD_FLG_FDT_CHANGED: Device tree change has been detected by tests */ GD_FLG_FDT_CHANGED = 0x100000, - /** - * @GD_FLG_CYCLIC_RUNNING: cyclic_run is in progress - */ - GD_FLG_CYCLIC_RUNNING = 0x200000, };
#endif /* __ASSEMBLY__ */
Applied to u-boot-watchdog/master
Thanks, Stefan
*/* @GD_FLG_CYCLIC_RUNNING: cyclic_run is in progress
- GD_FLG_CYCLIC_RUNNING = 0x20000, /**
- @GD_FLG_SKIP_LL_INIT: don't perform low-level initialization
Viele Grüße, Stefan Roese
Stefan Roese
