[U-Boot-Users] RE: Nothing display in terminal with uboot 1.1.3 on 8347 board!
Simon,
Please let me know what you really had to do to get the flash programmed.
It would be interesting to describe what you might have changed or had not been doing if it is generally something that users would forget porting to a new board.
If it is not concerned with U-BOOT could you mail me separately?
Thanks,
Krishnan
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net]On Behalf Of u-boot-users-request@lists.sourceforge.net Sent: Saturday, November 26, 2005 1:42 AM To: u-boot-users@lists.sourceforge.net Subject: U-Boot-Users digest, Vol 1 #1629 - 15 msgs
Send U-Boot-Users mailing list submissions to u-boot-users@lists.sourceforge.net
To subscribe or unsubscribe via the World Wide Web, visit https://lists.sourceforge.net/lists/listinfo/u-boot-users or, via email, send a message with subject or body 'help' to u-boot-users-request@lists.sourceforge.net
You can reach the person managing the list at u-boot-users-admin@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific than "Re: Contents of U-Boot-Users digest..."
Today's Topics:
- U-boot not starting - sometimes (Martin Egholm Nielsen)
- Re: Time Base register definitions inccorrect in
asm-ppc/processor.h (Wolfgang Denk) 3. Re: U-boot not starting - sometimes (Wolfgang Denk) 4. GIT Repository problems (Dale Dunlea) 5. Re: U-boot not starting - sometimes (Martin Egholm Nielsen) 6. pRamdisk not booting on COM3 (Arun) 7. Re: Re: [U-Boot-Users] A question about initialization of SDRAM (=?gb2312?B?sszk8uTZ?=) 8. Re: GIT Repository problems (Wolfgang Denk) 9. Re: pRamdisk not booting on COM3 (Wolfgang Denk) 10. Re: A question about initialization of SDRAM (Wolfgang Denk) 11. Nothing display in terminal with uboot 1.1.3 on 8347 board! (Simon Yang) 12. Re: [PATCH] Make System IO Config Registers board configurable on MPC83xx (David Updegraff) 13. Re: Nothing display in terminal with uboot 1.1.3 on 8347 board! (Wolfgang Denk) 14. Re: Re: [PATCH] Make System IO Config Registers board configurable on MPC83xx (Wolfgang Denk)
--__--__--
Message: 1 To: u-boot-users@lists.sourceforge.net From: Martin Egholm Nielsen martin@egholm-nielsen.dk Date: Fri, 25 Nov 2005 09:03:31 +0100 Subject: [U-Boot-Users] U-boot not starting - sometimes
We have encountered on some of our 405EP boards that when powered on nothing happens - U-boot doesn't start. Powering off and trying again it "suddenly" works...
When caught in this "not-booting-state", it doesn't even help to activate the reset-pin. However, in the attached serial console, some giberish characters do come out (5-10 chars.).
Now, having seen problems with the memory chips on some of my boards, I was wondering if this could be a similar problem?
Best regards, Martin Egholm
--__--__--
Message: 2 To: Mike Wellington mike.b.wellington@gmail.com cc: u-boot-users@lists.sourceforge.net From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot-Users] Time Base register definitions inccorrect in asm-ppc/processor.h Date: Fri, 25 Nov 2005 09:16:12 +0100
In message d1ed0eb40511241922p45cde91eg2b8652d53fa73eb6@mail.gmail.com = you wrote:
Architecture-specific definition files such as =20 include/asm-ppc/processor.h =20 should be complete and correct, whether u-boot ,( or whatever app,) uses every single register and value defined in them or not.
I agree that they shall be correct.
There is no attempt or intention to make them "complete" (whatever that means).
For me the file is "complete" when it contains all the necessary definitions.
--=20 Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de The number you have dialed is imaginary. Please divide by 0 and try again.
--__--__--
Message: 3 To: Martin Egholm Nielsen martin@egholm-nielsen.dk cc: u-boot-users@lists.sourceforge.net From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot-Users] U-boot not starting - sometimes Date: Fri, 25 Nov 2005 11:07:08 +0100
In message dm6ggk$ut3$1@sea.gmane.org you wrote:
=20 Now, having seen problems with the memory chips on some of my boards, I=
=20
Check your voltages (and their power-on sequence) and especially the clocks.
--=20 Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "It may be that our role on this planet is not to worship God but to create him." - Arthur C. Clarke
--__--__--
Message: 4 Date: Fri, 25 Nov 2005 10:19:59 +0000 From: Dale Dunlea daledunlea@commergy.com To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] GIT Repository problems
Apologies if this is slightly off topic, being in reference to the denx 2.6 kernel git repository as opposed to U-boot specifically.
I tried to grab the latest 2.6 code but it consistently bombs out. The following is the exact log:
defaulting to local storage area Fetching head... Fetching objects... progress: 4 objects, 1485 bytes Getting alternates list for http://www.denx.de/git/linux-2.6-denx.git/ progress: 26 objects, 103346 bytes Getting pack list for http://www.denx.de/git/linux-2.6-denx.git/ progress: 27 objects, 103635 bytes Getting index for pack eceba3479417b338c2e156b1c6dfd69f3f0eaad1 Getting index for pack b3c6fbdfa36a326815de6358885c7a570a986b1b Getting index for pack 6122f3ffa476a089122c0bffbbb7a7ce31304b56 Getting index for pack 06949712bb970fc1dd2e13f50accdcd2bf992536 Getting index for pack 459148e2ea863c15479d69ed4886a6f200c79a49 Getting index for pack ad1ecbdb18e6a825fafa9f57ebb11a5dbe6e12ef Getting pack 06949712bb970fc1dd2e13f50accdcd2bf992536 which contains 5014bfa48ac169e0748e1e9651897788feb306dc error: Unable to find 1ad37b580be4215f1b0927b7560f5e8b8d1bc0fa under http://www.denx.de/git/linux-2.6-denx.git/
Cannot obtain needed tree 1ad37b580be4215f1b0927b7560f5e8b8d1bc0fa while processing commit 479ef592f3664dd629417098c8599261c0f689ab. Waiting for http://www.denx.de/git/linux-2.6-denx.git/objects/5f/7f7d7f77d25ebb fdd2f31359257991d92dc69a cg-fetch: objects fetch failed cg-clone: fetch failed
I am using GIT as opposed to the snapshot at ftp://ftp.denx.de/pub/linux/linux-2.6.14.tar.bz2 because gianfar.c fails to compile using the snapshot.
Regards, Dale Dunlea
--__--__--
Message: 5 To: u-boot-users@lists.sourceforge.net From: Martin Egholm Nielsen martin@egholm-nielsen.dk Date: Fri, 25 Nov 2005 12:11:18 +0100 Subject: [U-Boot-Users] Re: U-boot not starting - sometimes
We have tried with two different power-up sequences, and have the same result... Going even more OT: Do you actually know the most optimal powerup sequence for the 405EP? Because the datasheat doesn't specify...
Thx, Martin
--__--__--
Message: 6 Date: Fri, 25 Nov 2005 16:46:48 +0530 To: "wd@denx.de" wd@denx.de Cc: "u-boot-users@lists.sourceforge.net" u-boot-users@lists.sourceforge.net From: Arun arun@rassit.com Organization: RASS Subject: [U-Boot-Users] pRamdisk not booting on COM3
Hello Sir,
We are trying to boot pRamdisk on serial console ttyS2, but we are finding that the booting is stopping after
Freeing unused kernel memory: 284k init
Please suggest us what could be wrong?
Regards R Arun Kumar
--__--__--
Message: 7 Date: Fri, 25 Nov 2005 20:12:54 +0800 From: "=?gb2312?B?sszk8uTZ?=" killercai@21cn.com To: "u-boot-users" u-boot-users@lists.sourceforge.net Subject: Re: Re: [U-Boot-Users] A question about initialization of SDRAM
Thanks for your reply! I had tried several different version of
ppc_8xx-gcc to build the same u-boot.Only version 3.2.1 works ok. All the others(3.2.2, 3.3.1 and 3.3.3) have the problem that I have said before. So I think that maybe there is something different between these versions of gcc. Would you please explain it to me? Thanks a lot.
In message Tx948882797899.26592@send2.inner-21cn.com you wrote:
I am trying to use ELDK to make a u-boot on the
board with MPC852T.
"the board with MPC852T"? There is many such boards, most of
them differnt.
There is declaration of rtx in cpu/mpc8xx/fec.c:
static RTXBD *rtx = NULL;
I think that "rtx" should be NULL at the first time
fec_init() is entered,so the rtx will be given the value.
but after the ELDK make the u-boot, "rtx" isn't
NULL at the first time fec_init() is entered, it is 0xffffffff.
What makes you think so? The code is running perfectly fine on many boards. Which specific problem do you see?
Before the word "memctl->memc_mbmr = 0xD0924114"
in the function initdram, rtx is NULL(0x0),but after that it
is 0xffffffff. Part of the fuction initdram is below:
Looks as if there was a bug in the SDRAM init sequence for your board.
I wonder what happens in "memctl->memc_mbmr =
0xD0924114;",would you please explain it to me ? Thanks!
Please see the processor's User's Manual; read the memory controller section.
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de WARNING: This Product Attracts Every Other Piece of Matter in the Universe, Including the Products of Other Manufacturers, with a Force Proportional to the Product of the Masses and Inversely Proportional to the Distance Between Them.
--__--__--
Message: 8 To: Dale Dunlea daledunlea@commergy.com cc: u-boot-users@lists.sourceforge.net From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot-Users] GIT Repository problems Date: Fri, 25 Nov 2005 15:24:04 +0100
Dear Dale,
in message 4386E54F.8040406@commergy.com you wrote:
=20 Apologies if this is slightly off topic, being in reference to the denx=
=20
2.6 kernel git repository as opposed to U-boot specifically. =20 I tried to grab the latest 2.6 code but it consistently bombs out. Th=
e=20
We've seen this before, and it is still totally unclear to me what is causing the problem or how to avoid it :-(
Try "cg-clone rsync://..." instead...
--=20 Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de He had been eight years upon a project for extracting sunbeams out of cucumbers, which were to be put in vials hermetically sealed, and let out to warm the air in raw inclement summers. - Jonathan Swift _Gulliver's Travels_ ``A Voyage to Laputa, etc.'' ch. 5
--__--__--
Message: 9 To: Arun arun@rassit.com cc: u-boot-users@lists.sourceforge.net From: Wolfgang Denk wd@denx.de Date: Fri, 25 Nov 2005 15:26:35 +0100 Subject: [U-Boot-Users] Re: pRamdisk not booting on COM3
In message ops0smyar41ujopx@arunkumar.rassit.local you wrote:
=20 We are trying to boot pRamdisk on serial console ttyS2, but we are find=
=20 Freeing unused kernel memory: 284k init =20 Please suggest us what could be wrong?
You probably configured a wrong console port in Linux. [But this is off topic here on the U-Boot mailing list.]
--=20 Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de A metaphor is like a simile.
--__--__--
Message: 10 To: "=?gb2312?B?sszk8uTZ?=" killercai@21cn.com cc: "u-boot-users" u-boot-users@lists.sourceforge.net From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot-Users] A question about initialization of SDRAM Date: Fri, 25 Nov 2005 15:28:20 +0100
In message v7948874798944.27002@send4.inner-21cn.com you wrote:
=20 I had tried several different version of
ppc_8xx-gcc to build the sam= e u-boot.Only version 3.2.1 works ok.
All the others(3.2.2, 3.3.1 and 3.3.3) have the problem that I have sai=
something different between these versions of gcc. Would you please exp=
I cannot confirm your observation. For example, ELDK release 3.1.1 uses GCC 3.3.3, and this works perfectly fine.
--=20 Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Parkinson's Law: Work expands to fill the time alloted it.
--__--__--
Message: 11 Date: Sat, 26 Nov 2005 00:58:04 +0800 From: Simon Yang bestwish.simon@gmail.com To: U-Boot-Users@lists.sourceforge.net Subject: [U-Boot-Users] Nothing display in terminal with uboot 1.1.3 on 8347 board!
Dear All,
After we program the HRCW and uboot.bin(1.1.3) into Flash and power on, nothing is shown in terminal, it seems that the UART doesn't initialize correctlly. Our board information is as follow: CPU:MPC8347E Memory:256 DDR 333 DIMM Flash:S29GL064MR2 8MB (8Mx8x1)
We program the HRCW into FF800000 and uboot.bin into FFF00000, and we also use Debugger check the values we programed, both Flash and Memory can be written when power on through the Debugger we find it really goes to the Address FFF00100 where the start of UBoot(start.S) to run the uboot image, but how can I trace the running process step by step? If no information display in terminal, whether it is caused by the wrong address set in configuration file or by the serial initialization?
Best Regards,
Simon
--__--__--
Message: 12 To: u-boot-users@lists.sourceforge.net From: David Updegraff dave@cray.com Date: Wed, 23 Nov 2005 14:47:36 -0600 Subject: [U-Boot-Users] Re: [PATCH] Make System IO Config Registers board configurable on MPC83xx
Kumar
Now I wonder if a similar thing might be done in start.S, so that the [re] mapped size of flash complies with what is defined in the config file? Either from flash size, or from the _PRELIM_* settings that are already there? Instead of current status quo of hardwired to 8M flash size?
Signed-off-by: Kumar Gala galak@kernel.crashing.org
CHANGELOG:
- Make System IO Config Registers board configurable on MPC83xx Patch by Kumar Gala 23 Nov 2005
commit 01b445b70c5e296c115b93a894ff3c7ffc1586d5 tree 2a2398b1bd34aa9b79e7ba34b4ccf7c28c932734 parent f6a259d086597f691d821a5ac2181ce249fad987 author Kumar Gala galak@kernel.crashing.org Wed, 23 Nov 2005
14:31:37 -0600
committer Kumar Gala galak@kernel.crashing.org Wed, 23 Nov
2005 14:31:37 -0600
cpu/mpc83xx/cpu_init.c | 8 ++++++-- include/configs/MPC8349ADS.h | 4 ++++ include/configs/TQM834x.h | 4 ++++ 3 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/cpu/mpc83xx/cpu_init.c b/cpu/mpc83xx/cpu_init.c index dcb3445..e75b8b7 100644 --- a/cpu/mpc83xx/cpu_init.c +++ b/cpu/mpc83xx/cpu_init.c @@ -63,8 +63,12 @@ void cpu_init_f (volatile immap_t * im) im->sysconf.spcr |= SPCR_TBEN;
/* System General Purpose Register */
- im->sysconf.sicrh = SICRH_TSOBI1;
- im->sysconf.sicrl = SICRL_LDP_A;
+#ifdef CFG_SICRH
- im->sysconf.sicrh = CFG_SICRH;
+#endif +#ifdef CFG_SICRL
- im->sysconf.sicrl = CFG_SICRL;
/* * Memory Controller: diff --git a/include/configs/MPC8349ADS.h b/include/configs/MPC8349ADS.h index 41309ac..7197e0f 100644 --- a/include/configs/MPC8349ADS.h +++ b/include/configs/MPC8349ADS.h @@ -504,6 +504,10 @@ HRCWH_TSEC2M_IN_GMII ) #endif
+/* System IO Config */ +#define CFG_SICRH SICRH_TSOBI1 +#define CFG_SICRL SICRL_LDP_A
#define CFG_HID0_INIT 0x000000000
#define CFG_HID0_FINAL CFG_HID0_INIT diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index c25a777..a2184ee 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -417,6 +417,10 @@ extern int tqm834x_num_flash_banks; HRCWH_TSEC2M_IN_GMII ) #endif
/* i-cache and d-cache disabled */ #define CFG_HID0_INIT 0x000000000 #define CFG_HID0_FINAL CFG_HID0_INIT
This SF.net email is sponsored by: Splunk Inc. Do you grep
through log files
for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
--__--__--
Message: 13 To: Simon Yang bestwish.simon@gmail.com cc: U-Boot-Users@lists.sourceforge.net From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot-Users] Nothing display in terminal with uboot 1.1.3 on 8347 board! Date: Fri, 25 Nov 2005 21:09:16 +0100
In message 1c3e00040511250858v2e2db1e4q@mail.gmail.com you wrote:
=20 After we program the HRCW and uboot.bin(1.1.3) into Flash and power on, nothing is shown in terminal, it seems that the UART doesn't initialize correctlly.
Well, then debug it...
Use your debugger.
Or by any other error in your port. You have a debugger attached, use it. That's what it was made for.
--=20 Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de ... bacteriological warfare ... hard to believe we were once foolish enough to play around with that. -- McCoy, "The Omega Glory", stardate unknown
--__--__--
Message: 14 To: David Updegraff dave@cray.com cc: u-boot-users@lists.sourceforge.net From: Wolfgang Denk wd@denx.de Subject: Re: [U-Boot-Users] Re: [PATCH] Make System IO Config Registers board configurable on MPC83xx Date: Fri, 25 Nov 2005 21:10:58 +0100
In message dm2kgr$u4s$1@sea.gmane.org you wrote:
=20 Now I wonder if a similar thing might be done in start.S, so that the=20 [re] mapped size of flash complies with what is defined in the config=20 file? Either from flash size, or from the _PRELIM_* settings that are=20 already there? Instead of current status quo of hardwired to 8M flash =
size?
start.S is definitely not the place for (re)mapping flash. Please read the README. Only after relocation to RAM the flash seize can be determined, and only then the final mapping can be set up. Just like it is done now - at list in all sane ports.
--=20 Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "Data is a lot like humans: It is born. Matures. Gets married to other data, divorced. Gets old. One thing that it doesn't do is die. It has to be killed." - Arthur Miller
--__--__--
U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
End of U-Boot-Users Digest
Krishnan
