[U-Boot] [PATCH 0/3] TQM834x: configuration update
The following 3 patches update the configuration for the TQM834x board:
Wolfgang Denk (3): TQM834x: fix environment size; add redundant env. TQM834x: add FDT support TQM834x: use buffered writes to accelerate writing to flash
Signed-off-by: Wolfgang Denk wd@denx.de
Also reserve more space for U-Boot as it will probably grow soon.
Signed-off-by: Wolfgang Denk wd@denx.de --- include/configs/TQM834x.h | 26 ++++++++++++-------------- 1 files changed, 12 insertions(+), 14 deletions(-)
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index b74b404..0cecf3f 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -179,8 +179,8 @@ extern int tqm834x_num_flash_banks; #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
-#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (256 * 1024) /* Reserve 256 kB for malloc */ +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB = 3 sect. for Mon */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserve 512 kB for malloc */
/* * Serial Port @@ -295,22 +295,20 @@ extern int tqm834x_num_flash_banks; /* * Environment */ -#define CONFIG_ENV_OVERWRITE - -#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) - #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 +#ifdef CONFIG_SYS_RAMBOOT +# define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 +# define CONFIG_ENV_IS_IN_FLASH 1 #endif
+#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) for env */ +#define CONFIG_ENV_SIZE 0x8000 /* 32K max size */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) + #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
/* * BOOTP options
Signed-off-by: Wolfgang Denk wd@denx.de --- board/tqc/tqm834x/pci.c | 45 ++++++++++++++++++++++++++++++++ board/tqc/tqm834x/tqm834x.c | 11 ++++++++ include/configs/TQM834x.h | 59 ++++++++++++++++++++++++++++-------------- 3 files changed, 95 insertions(+), 20 deletions(-)
diff --git a/board/tqc/tqm834x/pci.c b/board/tqc/tqm834x/pci.c index cb2cb8d..6c113e3 100644 --- a/board/tqc/tqm834x/pci.c +++ b/board/tqc/tqm834x/pci.c @@ -24,7 +24,15 @@
#include <asm/mmu.h> #include <common.h> +#include <asm/global_data.h> #include <pci.h> +#include <asm/mpc8349_pci.h> +#if defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#include <fdt_support.h> +#endif + +DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_PCI
@@ -217,4 +225,41 @@ pci_init_board(void) */ hose->last_busno = pci_hose_scan(hose); } + +#if defined(CONFIG_OF_LIBFDT) +void ft_pci_setup(void *blob, bd_t *bd) +{ + int nodeoffset; + int tmp[2]; + const char *path; + + nodeoffset = fdt_path_offset(blob, "/aliases"); + if (nodeoffset >= 0) { + path = fdt_getprop(blob, nodeoffset, "pci0", NULL); + if (path) { + tmp[0] = cpu_to_be32(pci1_hose.first_busno); + tmp[1] = cpu_to_be32(pci1_hose.last_busno); + do_fixup_by_path(blob, path, "bus-range", + &tmp, sizeof(tmp), 1); + + tmp[0] = cpu_to_be32(gd->pci_clk); + do_fixup_by_path(blob, path, "clock-frequency", + &tmp, sizeof(tmp[0]), 1); + } +#ifdef CONFIG_MPC83XX_PCI2 + path = fdt_getprop(blob, nodeoffset, "pci1", NULL); + if (path) { + tmp[0] = cpu_to_be32(pci2_hose.first_busno); + tmp[1] = cpu_to_be32(pci2_hose.last_busno); + do_fixup_by_path(blob, path, "bus-range", + &tmp, sizeof(tmp), 1); + + tmp[0] = cpu_to_be32(gd->pci_clk); + do_fixup_by_path(blob, path, "clock-frequency", + &tmp, sizeof(tmp[0]), 1); + } +#endif + } +} +#endif /* CONFIG_OF_LIBFDT */ #endif /* CONFIG_PCI */ diff --git a/board/tqc/tqm834x/tqm834x.c b/board/tqc/tqm834x/tqm834x.c index 106cac2..4fd8cd6 100644 --- a/board/tqc/tqm834x/tqm834x.c +++ b/board/tqc/tqm834x/tqm834x.c @@ -431,3 +431,14 @@ static void set_ddr_config(void) { #endif } } + +#ifdef CONFIG_OF_BOARD_SETUP +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + +#ifdef CONFIG_PCI + ft_pci_setup(blob, bd); +#endif /* CONFIG_PCI */ +} +#endif /* CONFIG_OF_BOARD_SETUP */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 0cecf3f..5590d2e 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -166,9 +166,9 @@ extern int tqm834x_num_flash_banks; #define CONFIG_SYS_MONITOR_BASE TEXT_BASE /* start of monitor */
#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -#define CONFIG_SYS_RAMBOOT +# define CONFIG_SYS_RAMBOOT #else -#undef CONFIG_SYS_RAMBOOT +# undef CONFIG_SYS_RAMBOOT #endif
#define CONFIG_SYS_INIT_RAM_LOCK 1 @@ -295,12 +295,7 @@ extern int tqm834x_num_flash_banks; /* * Environment */ -#ifdef CONFIG_SYS_RAMBOOT -# define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ -#else -# define CONFIG_ENV_IS_IN_FLASH 1 -#endif - +#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) for env */ #define CONFIG_ENV_SIZE 0x8000 /* 32K max size */ @@ -324,14 +319,18 @@ extern int tqm834x_num_flash_banks; */ #include <config_cmd_default.h>
+#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM #define CONFIG_CMD_I2C +#define CONFIG_CMD_NFS #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SNTP
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI @@ -368,6 +367,11 @@ extern int tqm834x_num_flash_banks;
#undef CONFIG_WATCHDOG /* watchdog disabled */
+/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + /* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is @@ -512,20 +516,35 @@ extern int tqm834x_num_flash_banks; "addip=setenv bootargs ${bootargs} " \ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}:${netdev}:off panic=1\0" \ - "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ - "flash_nfs=run nfsargs addip addtty;" \ + "addcons=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ + "flash_nfs_old=run nfsargs addip addcons;" \ "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip addtty;" \ + "flash_nfs=run nfsargs addip addcons;" \ + "bootm ${kernel_addr} - ${fdt_addr}\0" \ + "flash_self_old=run ramargs addip addcons;" \ "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 400000 ${bootfile};run nfsargs addip addtty;" \ - "bootm\0" \ + "flash_self=run ramargs addip addcons;" \ + "bootm ${kernel_addr} ${ramdisk_addr} ${fdt_addr}\0" \ + "net_nfs_old=tftp 400000 ${bootfile};" \ + "run nfsargs addip addcons;bootm\0" \ + "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ + "tftp ${fdt_addr_r} ${fdt_file}; " \ + "run nfsargs addip addcons; " \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ "rootpath=/opt/eldk/ppc_6xx\0" \ - "bootfile=/tftpboot/tqm834x/uImage\0" \ - "kernel_addr=80060000\0" \ - "ramdisk_addr=80160000\0" \ - "load=tftp 100000 /tftpboot/tqm834x/u-boot.bin\0" \ - "update=protect off 80000000 8003ffff; " \ - "era 80000000 8003ffff; cp.b 100000 80000000 40000\0" \ + "bootfile=tqm834x/uImage\0" \ + "fdtfile=tqm834x/tqm834x.dtb\0" \ + "kernel_addr_r=400000\0" \ + "fdt_addr_r=600000\0" \ + "ramdisk_addr_r=800000\0" \ + "kernel_addr=800C0000\0" \ + "fdt_addr=800A0000\0" \ + "ramdisk_addr=80300000\0" \ + "u-boot=tqm834x/u-boot.bin\0" \ + "load=tftp 200000 ${u-boot}\0" \ + "update=protect off 80000000 +${filesize};" \ + "era 80000000 +${filesize};" \ + "cp.b 200000 80000000 ${filesize}\0" \ "upd=run load update\0" \ ""
Also enable display of 'E'mpty sectors in "lsinfo" output.
Signed-off-by: Wolfgang Denk wd@denx.de --- include/configs/TQM834x.h | 7 +++---- 1 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 5590d2e..c504ecb 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -78,13 +78,12 @@ * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #undef CONFIG_SYS_FLASH_CHECKSUM #define CONFIG_SYS_FLASH_BASE 0x80000000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 8 /* FLASH size in MB */ - -/* buffered writes in the AMD chip set is not supported yet */ -#undef CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sectors */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE
/* * FLASH bank number detection
Hi Wolfgang,
s lsinfo/flinfo.
Best regards, Stefan
Also enable display of 'E'mpty sectors in "flinfo" output.
Signed-off-by: Wolfgang Denk wd@denx.de --- v2: fix "flinfo" misspelling
Dear Stefan Roese,
In message 200905150608.13837.sr@denx.de you wrote:
Hi Wolfgang,
s lsinfo/flinfo.
Thanks for catching this. Will fix.
applied 1-3/3 to u-boot-mpc83xx next branch.
Kim
Kim Phillips
Stefan Roese
