[U-Boot] [PATCH v2 1/2] nitrogen6x: Fix RAM size variable
Fix the following build error when buildig nitrogen6s1g:
nitrogen6x.c:89:17: error: 'CONFIG_DDR_MB' undeclared (first use in this function) nitrogen6x.c:89:17: note: each undeclared identifier is reported only once for each function it appears in
Reported-by: Albert Aribaud albert.u.boot@aribaud.net Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Rebased against u-boot-imx tree
boards.cfg | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/boards.cfg b/boards.cfg index fb3b197..84f96e0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -260,7 +260,7 @@ nitrogen6dl2g arm armv7 nitrogen6x boundar nitrogen6q arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 -nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,SDRAM_MB=1024 +nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024 cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 omap3_pandora arm armv7 pandora - omap3
When building for the nitrogen boards with 2GB the following warning happens:
nitrogen6x.c:89:38: warning: integer overflow in expression [-Woverflow]
2GB can not fit in 32-bits, so use ulong instead.
Reported-by: Albert Aribaud albert.u.boot@aribaud.net Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - No changes board/boundary/nitrogen6x/nitrogen6x.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 0dbb6d2..e5634d8 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -86,7 +86,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = CONFIG_DDR_MB * 1024 * 1024; + gd->ram_size = (ulong)(CONFIG_DDR_MB * 1024 * 1024);
return 0; }
Hi Fabio,
Changes since v1:
- No changes
- gd->ram_size = (ulong)(CONFIG_DDR_MB * 1024 * 1024);
This does not fix the issue. You're casting, but the value does not fit in 32 bit and the warning still remains.
I am afraid that 32 bit for gd->ram_size are not enough anymore...
We can fix the warning setting maybe a lower amout of memory (I am expecting that now the value is truncated and a wrong output is shown on the console), but for the future gd->ram_size should move to 64 bit.
Best regards, Stefano
From: "fabio.estevam@freescale.com" fabio.estevam@freescale.com
Reported-by: Albert Aribaud albert.u.boot@aribaud.net Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Signed-off-by: Stefano Babic sbabic@denx.de ---
Changes since V1: - move casting inside expression to force using unsigned long
return 0; }
Sorry, discharge this - it is identical to the previous one. I will send the right one in few minutes.
Stefano
Changes since V2: - move casting inside expression to force using unsigned long
diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 0dbb6d2..229c237 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -86,7 +86,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = CONFIG_DDR_MB * 1024 * 1024; + gd->ram_size = ((ulong)CONFIG_DDR_MB * 1024 * 1024);
return 0; }
Dear Stefano Babic,
<nitpick>
unsigned long is 32 bits, too.
And, strictly speaking, GB is a decimal unit, so 2 GB = 2e9 = 0x77359400 which fits nicely into a signed 32 bit number.
What you actually mean is: 2 GiB cannot be expressed as a 32 bit signed number.
</nitpick>
Good point, I will change and re-submit it.
Thanks,
Fabio Estevam
Hi Stefano,
This somehow is redundant with Fabio's patch 2/2 with the same summary, right?
Stefano: once Fabio's series is OK,
- either you rollback your ToT, apply Fabio's series before it, and then send out an amended PR, which is more work but makes your tree build-clean;
- or I apply Fabio's series then your existing PR, which is less work but leaves your current ToT non-build-clean until you merge back from ARM (or mainline once I do my own PR).
What do you prefer? I would favor the first option, FWIW.
Amicalement,
On 14/03/2013 14:15, Albert ARIBAUD wrote:
Hi Stefano,
We sent quite at the same time - I will discharge mine.
I prefer to apply Fabio's patches on top of u-boot-imx and send an amended PR. This is also my favorite option. What do you mean with rollback the ToT ? As I have already pushed on the server, I do not like to rebase it or things like that. My idea is only to apply the patches and send after that a new PR to you.
Stefano
Hi Stefano,
Hi Stefano,
That's fine. :)
Stefano
Amicalement,
Hi Fabio,
Changes since v1:
You're very fast ! Thanks for fixing it !
Regards, Stefano
Albert ARIBAUD
Fabio Estevam
Stefano Babic
