[U-Boot] [PATCH] net: fman: Support both new and legacy FMan Compatibles
Recently the FMan Port and MAC compatibles were changed. This patch aligns the FMan Port and MAC compatibles to the new FMan device tree binding document. The FMan device tree binding document can be found in the Linux kernel: ./Documentation/devicetree/bindings/net/fsl-fman.txt
This patch doesn't affect legacy compatibles support.
Signed-off-by: Zhao Qiang qiang.zhao@nxp.com --- drivers/net/fm/init.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index 147d043..e3b1a50 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -328,7 +328,8 @@ void fdt_fixup_fman_ethernet(void *blob) ft_fixup_port(blob, &fm_info[i], "fsl,fman-1g-mac"); } else { - if (ft_fixup_port(blob, &fm_info[i], "fsl,fman-tgec")) + if (ft_fixup_port(blob, &fm_info[i], "fsl,fman-tgec") && + ft_fixup_port(blob, &fm_info[i], "fsl,fman-xgec")) ft_fixup_port(blob, &fm_info[i], "fsl,fman-10g-mac"); }
It would be helpful to know which version or commit has this change. It doesn't impact this patch though.
Reviewed-by: York Sun york.sun@nxp.com
kernel:
Thank you for your suggestion! I will add it in next version.
BR
Qiang Zhao
Please reference the Linux commit that made the change and the version of the kernel that made the change.
Joe Hershberger
Qiang Zhao
York Sun
Zhao Qiang
