[U-Boot] [PATCH] armv8: Disable exception vectors in SPL by default
Commit 1416e2d2253 ("armv8: make SPL exception vectors optional") had a typo in it which effectively disabled exception handling in SPL code always.
Since nobody complained, I guess we may as well disable exception handling in SPL always by default.
So fix the bug to make the config option effective, but disable exception handling in SPL by default. This gets us to the same functionality as before by default, but with much less code included in the binary.
Signed-off-by: Alexander Graf agraf@suse.de --- arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/start.S | 6 +++--- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 1c12bbde75..fb061c8d73 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -3,7 +3,7 @@ if ARM64 config ARMV8_SPL_EXCEPTION_VECTORS bool "Install crash dump exception vectors" depends on SPL - default y + default n help The default exception vector table is only used for the crash dump, but still takes quite a lot of space in the image size. diff --git a/arch/arm/cpu/armv8/start.S b/arch/arm/cpu/armv8/start.S index 12a78ee38b..87bff9408b 100644 --- a/arch/arm/cpu/armv8/start.S +++ b/arch/arm/cpu/armv8/start.S @@ -88,11 +88,11 @@ pie_fixup_done: bl reset_sctrl #endif
-#if defined(CONFIG_ARMV8__SPL_EXCEPTION_VECTORS) || !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_ARMV8_SPL_EXCEPTION_VECTORS) || !defined(CONFIG_SPL_BUILD) .macro set_vbar, regname, reg msr \regname, \reg .endm - adr x0, vectors + adr x0, _start #else .macro set_vbar, regname, reg .endm @@ -354,7 +354,7 @@ ENDPROC(smp_kick_all_cpus) /*-----------------------------------------------------------------------*/
ENTRY(c_runtime_cpu_setup) -#if defined(CONFIG_ARMV8__SPL_EXCEPTION_VECTORS) || !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_ARMV8_SPL_EXCEPTION_VECTORS) || !defined(CONFIG_SPL_BUILD) /* Relocate vBAR */ adr x0, vectors switch_el x1, 3f, 2f, 1f
- default y
- default n help The default exception vector table is only used for the crash dump, but still takes quite a lot of space in the image size.
- adr x0, vectors
- adr x0, _start
If there is any reason you want to set vbar_elX to _start instead the exception entry point, then please explain this in the commit message :)
other then that: Reviewed-by: Matthias Brugger mbrugger@suse.com
- default y
- adr x0, vectors
- adr x0, _start
Ugh, no, that was a stale change from a previous experiment. Thanks for catching it!
Alex
Alexander Graf
Matthias Brugger
