[U-Boot] Pull request u-boot-blackfin.git
The following changes since commit 9d8811c5bd2b7dd6307742cf22fbdb7953b6f816: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-usb
git://www.denx.de/git/u-boot-blackfin.git master
Mike Frysinger (7): Blackfin: update anomaly lists Blackfin: use on-chip syscontrol() rom function when available Blackfin: set default voltage levels for BF538/BF539 parts Blackfin: check for reserved settings in DDR MMRs Blackfin: add support for fast SPI reads with Boot ROM Blackfin: dynamically update UART speed when initializing Blackfin: move default boot SPI CS to common code
board/bf537-stamp/spi_flash.c | 8 +- cpu/blackfin/initcode.c | 157 +++++++++++++++----------- cpu/blackfin/serial.h | 72 +++--------- include/asm-blackfin/blackfin-config-pre.h | 9 ++ include/asm-blackfin/mach-bf527/anomaly.h | 166 ++++++++++++++++++++-------- include/asm-blackfin/mach-bf533/anomaly.h | 55 ++++++---- include/asm-blackfin/mach-bf537/anomaly.h | 14 ++- include/asm-blackfin/mach-bf548/anomaly.h | 45 +++++--- include/asm-blackfin/mach-bf561/anomaly.h | 17 +++- 9 files changed, 331 insertions(+), 212 deletions(-)
Dear Mike Frysinger,
Applied, thanks.
Mike Frysinger
