[U-Boot] [PATCH] ARM: socfpga: Add boot0 hook to prevent SPL corruption
Valid Altera SoCFPGA preloader image must contain special data at offsets 0x40, 0x44, 0x48 and valid instructions at address 0x4c or 0x50. These addresses are by default used by U-Boot's vector table and a piece of reset handler, thus a valid preloader corrupts those addresses slightly. While this works most of the time, this can and does prevent the board from rebooting sometimes and triggering this issue may even depend on compiler.
The problem is that when SoCFPGA performs warm reset, it checks the addresses 0x40..0x4b in SRAM for a valid preloader signature and header checksum. If those are found, it jumps to address 0x4c or 0x50 (this is unclear). These addresses are populated by the first few instructions of arch/arm/cpu/armv7/start.S:
ffff0040 <data_abort>: ffff0040: ebfffffe bl ffff0040 <data_abort>
ffff0044 <reset>: ffff0044: ea000012 b ffff0094 <save_boot_params>
ffff0048 <save_boot_params_ret>: ffff0048: e10f0000 mrs r0, CPSR ffff004c: e200101f and r1, r0, #31 ffff0050: e331001a teq r1, #26
Without this patch, the CPU will enter the code at 0xffff004c or 0xffff0050 , at which point the value of r0 and r1 registers is undefined. Moreover, jumping directly to the preloader entry point at address 0xffff0000 will also fail, because address 0xffff004. is invalid and contains the preloader magic.
Add BOOT0 hook which reserves the area at offset 0x40..0x5f and populates offset 0x50 with jump to the entry point. This way, the preloader signature is stored in reserved space and can not corrupt the SPL code.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Stefan Roese sr@denx.de --- arch/arm/Kconfig | 1 + arch/arm/mach-socfpga/include/mach/boot0.h | 28 ++++++++++++++++++++++++++++ 2 files changed, 29 insertions(+) create mode 100644 arch/arm/mach-socfpga/include/mach/boot0.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index d7a9b11..25bda14 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -551,6 +551,7 @@ config ARCH_SOCFPGA select DM select DM_SPI_FLASH select DM_SPI + select ENABLE_ARM_SOC_BOOT0_HOOK
config TARGET_CM_T43 bool "Support cm_t43" diff --git a/arch/arm/mach-socfpga/include/mach/boot0.h b/arch/arm/mach-socfpga/include/mach/boot0.h new file mode 100644 index 0000000..aaada31 --- /dev/null +++ b/arch/arm/mach-socfpga/include/mach/boot0.h @@ -0,0 +1,28 @@ +/* + * Specialty padding for the Altera SoCFPGA preloader image + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __BOOT0_H +#define __BOOT0_H + +#ifdef CONFIG_SPL_BUILD +#define ARM_SOC_BOOT0_HOOK \ + .balignl 64,0xf33db33f; \ + \ + .word 0x1337c0d3; /* SoCFPGA preloader validation word */ \ + .word 0xc01df00d; /* Version, flags, length */ \ + .word 0xcafec0d3; /* Checksum, zero-pad */ \ + nop; \ + \ + b reset; /* SoCFPGA jumps here */ \ + nop; \ + nop; \ + nop; +#else +#define ARM_SOC_BOOT0_HOOK +#endif + + +#endif /* __BOOT0_H */
With this patch, I can properly do a soft reset on an Atlas DE0 Nano board.
So feel free to add:
Tested-by: Dinh Nguyen dinguyen@opensource.altera.com
Dinh
That's great, thanks for checking ! You probably want to propagate this fix to your downstream U-Boot mutation and also that MPL loader.
<save_boot_params>
Great, this fix in time as we noticed this issue early of this week. We were testing out the Arria10 SoC SPL. While for downstream, we already cater that but not gracefully as we modified the start.s :)
THanks Chin Liang
-- Best regards, Marek Vasut
Confidentiality Notice. This message may contain information that is confidential or otherwise protected from disclosure. If you are not the intended recipient, you are hereby notified that any use, disclosure, dissemination, distribution, or copying of this message, or any attachments, is strictly prohibited. If you have received this message in error, please advise the sender by reply e-mail, and delete the message and any attachments. Thank you.
On Wed, 16 Nov 2016 17:54:14 +0100 Marek Vasut marex@denx.de wrote: ...
Tested-by: Anatolij Gustschin agust@denx.de
Anatolij Gustschin
Chin Liang See
Dinh Nguyen
