[U-Boot-Users] Question on do_bootm in cmd_bootm.c
Can someone, maybe Wolfgang, comment on the maximum 4MB uncompressed size of gunzip (and, possibly, bzip2) images? I've been working on a Coldfire 5272 system for quite some time with u-boot and uClinux. Both have been remarkably stable. We use the uClinux default build wherein the root filesystem (romfs) is appended to the end of the kernel image, starting where the bss would normally be. The kernel startup code relocates the romfs image to just beyond the bss, then, and everything runs smoothly. I know that many folks in the PPC world use separate kernel and root filesystem images, for many good reasons, but many (most?) of the uClinux platforms use this concatenated kernel+romfs image. Recently, we've been adding more content to the root filesystem. As our root filesystem grew larger (say about 3MB), however, we started seeing boot problems where the kernel would boot fine but the root filesystem was clearly corrupt. I've spent the better part of two days trying to track down where things go wrong, from the kernel to u-boot. Of course, I used a hardware debugger, looked at u-boot's memory assignments, image load addresses, entry points, malloc areas, etc. I just located the source of my trouble, a hard-coded 4MB maximum uncompressed size in do_bootm:
int do_bootm (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { ulong iflag; ulong addr; ulong data, len, checksum; ulong *len_ptr; uint unc_len = 0x400000; ^^^^^^^^^ int i, verify;
SNIP
case IH_COMP_GZIP: printf (" Uncompressing %s ... ", name); if (gunzip ((void *)ntohl(hdr->ih_load), unc_len, ^^^^^^^^ (uchar *)data, (int *)&len) != 0) { printf ("GUNZIP ERROR - must RESET board to recover\n"); SHOW_BOOT_PROGRESS (-6); do_reset (cmdtp, flag, argc, argv); } break;
SNIP
Increasing unc_len to larger values (like 6MB) seems to solve my problem. With an uncompressed image larger than 4MB, gunzip doesn't seem to generate any errors (granted, I haven't stepped through gunzip and zlib), but merrily runs along, although the data beyond the 4MB boundary seems to be missing or corrupt. It looks like there's a truncation (about line 1875 in zlib.c) to z.avail_out in zlib that prevents data from being copied beyond unc_len - maybe that should be an error instead of silently truncating data? Just a thought. I'll into submitting a patch for that. I was wondering if there was some reason for the 0x400000 magic number for unc_len. Is that just a magic number? Is that larger than anyone uses for images? I guess I'm a little surprised that this hasn't bitten anyone else so far (nothing I could see on the mailing list archive, at least). Our 1MB kernel and 3MB romfs root filesystem might be exceptionally large, I don't know. Would there be any issues with making unc_len a CFG_ macro, if I submitted a patch?
Nick Barendt
This was probably copied from the PowerPC Linux "bootloader" source code, which was created a long, long time ago. We used this value in that code because long ago when compressed images were necessary the embedded boards were lucky to have 8M of RAM. Based on the (then fixed) load address and sizes of memory, you couldn't uncompress images larger than this without writing over the uncompressing code. To prevent large images from just hanging the system, we stopped short and continued to boot. At least this way we got an error later that the ramdisk isn't correct. Back then it was common to know this kind of failure.
I don't think a configuration macro is appropriate, just submit a patch with a much larger and still reasonable value, maybe 16M or so.
Thanks.
-- Dan
In message 2687F354-245C-11D9-9164-000A95A5473A@gumstix.com you wrote:
"16 Meg ought to be enough for anybody"
For how long?
For how long?
I think this should be handled in a very similar manner to the CFG_MALLOC_LEN, but I don't want to make everyone update their config header files. So, I propose a patch that leaves 4MB as a default, allows board config header files to override the 4MB default, and makes zlib return an error if the output buffer fills up so these types of errors are painfully obvious. How does that sound?
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If the hours are long enough and the pay is short enough, someone will say it's women's work.
This SF.net email is sponsored by: IT Product Guide on ITManagersJournal Use IT products in your business? Tell us what you think of them. Give us Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more http://productguide.itmanagersjournal.com/guidepromo.tmpl _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
On Oct 22, 2004, at 3:22 PM, Nick Barendt wrote:
.... So, I propose a patch ...
Let's see it :-)
.... and makes zlib return an error if the output buffer fills up so these types of errors are painfully obvious.
It may already return some error status if we choose to test it.
-- Dan
Let's see it :-)
I've made all of the mods, but I won't have time to get a patch together (crossing my t's, dotting my i's, CHANGELOG entry, etc.) today, and I'm out of the office next week. I'll get the patch together and mail it out when I get back.
Nope, no error is returned. inflate_flush() in zlib.c just silently truncates the output:
local int inflate_flush(s, z, r) inflate_blocks_statef *s; z_stream *z; int r; {
SNIP
/* compute number of bytes to copy as far as end of window */ n = (uInt)((q <= s->write ? s->write : s->end) - q); if (n > z->avail_out) n = z->avail_out; ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
SNIP
The bzip2 code actually returns a specific error for this, BZ_OUTPUT_BUFF_FULL. I've modified zlib to behave similarly.
-- Dan
Dear Nick,
I guess you forgot about this, but it's still open in my list of issues.
Can you please submit your patch?
I'd really like to add this...
Craig Hughes
Dan Malek
Nick Barendt
