[U-Boot] [PATCH 1/2] mv_ddr: ddr3: fix tRAS timimg parameter
From: Chris Packham chris.packham@alliedtelesis.co.nz
Based on the JEDEC standard JESD79-3F. The tRAS timings should include the highest speed bins at a given frequency. This is similar to commit 683c67b ("mv_ddr: ddr3: fix tfaw timimg parameter") where the wrong comparison was used in the initial implementation.
Signed-off-by: Chris Packham chris.packham@alliedtelesis.co.nz
[https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell/pull/15] Signed-off-by: Chris Packham judge.packham@gmail.com ---
drivers/ddr/marvell/a38x/ddr3_training_db.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/ddr/marvell/a38x/ddr3_training_db.c b/drivers/ddr/marvell/a38x/ddr3_training_db.c index 111a8586c6e3..b2f11a839961 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_db.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_db.c @@ -420,13 +420,13 @@ unsigned int mv_ddr_speed_bin_timing_get(enum mv_ddr_speed_bin index, enum mv_dd result = speed_bin_table_t_rcd_t_rp[index]; break; case SPEED_BIN_TRAS: - if (index < SPEED_BIN_DDR_1066G) + if (index <= SPEED_BIN_DDR_1066G) result = 37500; - else if (index < SPEED_BIN_DDR_1333J) + else if (index <= SPEED_BIN_DDR_1333J) result = 36000; - else if (index < SPEED_BIN_DDR_1600K) + else if (index <= SPEED_BIN_DDR_1600K) result = 35000; - else if (index < SPEED_BIN_DDR_1866M) + else if (index <= SPEED_BIN_DDR_1866M) result = 34000; else result = 33000;
Inactive chip-selects will give invalid values for read_sample so don't consider them when trying to determine the overall min/max read sample.
[https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell/pull/18] Signed-off-by: Chris Packham judge.packham@gmail.com --- Hi Baruch,
Does this help with your boards? It's not the custom g_odt_config you were after but it might mean that the code gets the right ODT value so you don't have to override it.
drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c b/drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c index db0f8ad7fb55..df832ac6dce0 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c @@ -50,6 +50,7 @@ int ddr3_tip_write_additional_odt_setting(u32 dev_num, u32 if_id) int max_phase = MIN_VALUE, current_phase; enum hws_access_type access_type = ACCESS_TYPE_UNICAST; u32 octets_per_if_num = ddr3_tip_dev_attr_get(dev_num, MV_ATTR_OCTET_PER_INTERFACE); + unsigned int max_cs = mv_ddr_cs_num_get();
CHECK_STATUS(ddr3_tip_if_write(dev_num, access_type, if_id, DUNIT_ODT_CTRL_REG, @@ -59,7 +60,7 @@ int ddr3_tip_write_additional_odt_setting(u32 dev_num, u32 if_id) data_read, MASK_ALL_BITS)); val = data_read[if_id];
- for (cs_num = 0; cs_num < MAX_CS_NUM; cs_num++) { + for (cs_num = 0; cs_num < max_cs; cs_num++) { read_sample[cs_num] = GET_RD_SAMPLE_DELAY(val, cs_num);
/* find maximum of read_samples */
Hi Chris,
Hi Baruch,
Maybe. The code looks pretty opaque to me.
Ideally we would like to have ODT_CONFIG (offset 0x1494) set to 0x30000 for all Clearfog platforms, since only ODT0 is connected. This value is good for both 1CS and 2CS systems, although the current 0x10000 is also fine for 1CS.
The current 2CS default hard-coded value of 0x120012 is good when both ODT0/ODT1 are connected and both chip-selects are used. 0x30000 is not optimal for these systems.
baruch
-- http://baruch.siach.name/blog/ ~. .~ Tk Open Systems =}------------------------------------------------ooO--U--Ooo------------{= - baruch@tkos.co.il - tel: +972.52.368.4656, http://www.tkos.co.il -
Applied to u-boot-marvell/master.
Thanks, Stefan
Thanks, Stefan
Baruch Siach
Chris Packham
Stefan Roese
