[U-Boot] am335x_evm SPL no longer fits
As of v2019.10-rc3 am335x_evm builds fail here as SPL doesn't fit.
v2019.10-rc2 builds. v2019.10-rc4 still fails:
LD spl/u-boot-spl arm-none-eabi-ld.bfd: u-boot-spl section `.u_boot_list' will not fit in region `.sram' arm-none-eabi-ld.bfd: region `.sram' overflowed by 100 bytes
I bisected this to the below commit but reverting it only slightly helps
arm-none-eabi-ld.bfd: u-boot-spl section `.u_boot_list' will not fit in region `.sram' arm-none-eabi-ld.bfd: region `.sram' overflowed by 72 bytes
Building with gcc-linaro-6.3.2017.02 and binutils-2.27
b83edfbde9a845d47a2766f4677deb336abfa42a is the first bad commit commit b83edfbde9a845d47a2766f4677deb336abfa42a Author: Lukas Auer lukas.auer@aisec.fraunhofer.de Date: Wed Aug 21 21:14:42 2019 +0200
spl: fit: use U-Boot device tree when FIT image has no device tree
As part of the SPL FIT boot flow, the device tree is appended to U-Boot proper. The device tree is used to record information on the loadables to make them available to the SPL framework and U-Boot proper. Depending on the U-Boot device tree provider, the FIT image might not include a device tree. Information on the loadables is missing in this case.
When booting via firmware bundled with the FIT image, U-Boot SPL loads the firmware binary and U-Boot proper before starting the firmware. The firmware, in turn, is responsible for starting U-Boot proper. Information on the memory location of the U-Boot proper loadable must be available to the SPL framework so that it can be passed to the firmware binary. To support this use case when no device tree is found in the FIT image, fall back to the U-Boot device tree in this situation.
At the same time, update the comment to remove the note that the destination address must be aligned to ARCH_DMA_MINALIGN. Alignment is only required as an intermediate step when reading external data. This is automatically handled by spl_fit_append_fdt(). After reading the external data, it is copied to the specified address, which does not have to be aligned to ARCH_DMA_MINALIGN.
Signed-off-by: Lukas Auer lukas.auer@aisec.fraunhofer.de Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Anup Patel anup.patel@wdc.com
common/spl/spl_fit.c | 37 ++++++++++++++++++++++++------------- 1 file changed, 24 insertions(+), 13 deletions(-)
fits with gcc-linaro-7.4.2019.02
Jonathan Gray
