[U-Boot] [PATCH v1 0/3] ARM: omap: clean GPMC macros
This patch cleans redundant and unused macros from various board-configs and architecture specific header files. Tested using: MAKEALL -s omap 3 -s omap4 -s omap5 -s am33xx with $ARCH=arm && $CROSS_COMPILE=arm-linux-gnueabihf-
Pekon Gupta (3): ARM: omap: fix GPMC address-map size for NAND and NOR devices ARM: omap: clean redundant PISMO_xx macros used in OMAP3 ARM: omap: move board specific NAND configs out from ti_armv7_common.h
arch/arm/cpu/armv7/omap-common/mem-common.c | 14 ++++++++++---- arch/arm/include/asm/arch-am33xx/mem.h | 7 ------- arch/arm/include/asm/arch-omap3/cpu.h | 1 - arch/arm/include/asm/arch-omap3/mem.h | 13 ------------- doc/README.nand | 12 ++++++++++++ include/configs/am335x_evm.h | 6 ++++++ include/configs/am3517_crane.h | 7 +------ include/configs/am3517_evm.h | 7 +------ include/configs/cm_t335.h | 5 +++++ include/configs/cm_t35.h | 3 --- include/configs/devkit8000.h | 2 -- include/configs/dig297.h | 4 ---- include/configs/mcx.h | 4 ---- include/configs/nokia_rx51.h | 2 -- include/configs/omap3_beagle.h | 13 +++++++------ include/configs/omap3_evm_common.h | 7 ++----- include/configs/omap3_igep00x0.h | 10 +++++++--- include/configs/omap3_logic.h | 8 ++------ include/configs/omap3_overo.h | 12 +++++++----- include/configs/omap3_pandora.h | 7 +------ include/configs/omap3_zoom1.h | 13 +++++++------ include/configs/pengwyn.h | 6 ++++++ include/configs/tam3517-common.h | 4 ---- include/configs/tao3530.h | 7 +------ include/configs/ti_armv7_common.h | 8 -------- include/configs/tricorder.h | 2 -- 26 files changed, 75 insertions(+), 109 deletions(-)
Fixes commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform
1) NAND device are not directly memory-mapped to CPU address-space, they are indirectly accessed via following GPMC registers: - GPMC_NAND_COMMAND_x - GPMC_NAND_ADDRESS_x - GPMC_NAND_DATA_x Therefore from CPU's point of view, NAND address-map can be limited to just above register addresses. But GPMC chip-select address-map can be configured in granularity of 16MB only. So this patch uses GPMC_SIZE_16M for all NAND devices.
2) NOR device are directly memory-mapped to CPU address-space, so its address-map size depends on actual addressable region in NOR FLASH device. So this patch uses CONFIG_SYS_FLASH_SIZE to derive GPMC chip-select address-map size configuration.
Signed-off-by: Pekon Gupta pekon@ti.com --- arch/arm/cpu/armv7/omap-common/mem-common.c | 10 ++++++++-- include/configs/am335x_evm.h | 1 + 2 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/mem-common.c b/arch/arm/cpu/armv7/omap-common/mem-common.c index 5bc7e1f..05b81e0 100644 --- a/arch/arm/cpu/armv7/omap-common/mem-common.c +++ b/arch/arm/cpu/armv7/omap-common/mem-common.c @@ -87,8 +87,13 @@ void gpmc_init(void) STNOR_GPMC_CONFIG6, STNOR_GPMC_CONFIG7 }; - u32 size = GPMC_SIZE_16M; u32 base = CONFIG_SYS_FLASH_BASE; + u32 size = (CONFIG_SYS_FLASH_SIZE > 0x08000000) ? GPMC_SIZE_256M : + /* > 64MB */ ((CONFIG_SYS_FLASH_SIZE > 0x04000000) ? GPMC_SIZE_128M : + /* > 32MB */ ((CONFIG_SYS_FLASH_SIZE > 0x02000000) ? GPMC_SIZE_64M : + /* > 16MB */ ((CONFIG_SYS_FLASH_SIZE > 0x01000000) ? GPMC_SIZE_32M : + /* min 16MB */ GPMC_SIZE_16M))); + #elif defined(CONFIG_NAND) /* configure GPMC for NAND */ const u32 gpmc_regs[GPMC_MAX_REG] = { M_NAND_GPMC_CONFIG1, @@ -99,8 +104,9 @@ void gpmc_init(void) M_NAND_GPMC_CONFIG6, 0 }; - u32 size = GPMC_SIZE_256M; u32 base = CONFIG_SYS_NAND_BASE; + u32 size = GPMC_SIZE_16M; + #elif defined(CONFIG_CMD_ONENAND) const u32 gpmc_regs[GPMC_MAX_REG] = { ONENAND_GPMC_CONFIG1, ONENAND_GPMC_CONFIG2, diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index a48b386..c1a6ada 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -453,6 +453,7 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_FLASH_BASE (0x08000000) #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_SIZE 0x01000000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Reduce SPL size by removing unlikey targets */ #ifdef CONFIG_NOR_BOOT
- NAND device are not directly memory-mapped to CPU address-space, they are
- GPMC_NAND_DATA_x
- NOR device are directly memory-mapped to CPU address-space, so its
Applied to u-boot-ti/master, thanks!
PISMO_xx macros were used to define 'Platform Independent Storage MOdule' related GPMC configurations. This patch - Replaces these OMAP3 specific macros with generic CONFIG_xx macros as provided by current u-boot infrastructure. - Removes unused redundant macros, which are no longer required after merging of common platform code in following commit commit a0a37183bd75e74608bc78c8d0e2a34454f95a91 ARM: omap: merge GPMC initialization code for all platform
+-----------------+-----------------------------------------------------------+ | Macro | Reason for removal | +-----------------+-----------------------------------------------------------+ | PISMO1_NOR_BASE | duplicate of CONFIG_SYS_FLASH_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_BASE| duplicate of CONFIG_SYS_NAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_BASE| duplicate of CONFIG_SYS_ONENAND_BASE | +-----------------+-----------------------------------------------------------+ | PISMO1_NAND_SIZE| GPMC accesses NAND device via I/O mapped registers so | | | configuring GPMC chip-select for smallest allowable | | | segment (GPMC_SIZE_16M) is enough. | +-----------------+-----------------------------------------------------------+ | PISMO1_ONEN_SIZE| OneNAND uses a fixed GPMC chip-select address-space of | | | 128MB (GPMC_SIZE_128M) | +-----------------+-----------------------------------------------------------+ +-----------------+-----------------------------------------------------------+ | PISMO1_NOR | Unused Macros | | PISMO1_NAND | | | PISMO2_CS0 | | | PISMO2_CS1 | | | PISMO1_ONENAND | | | PISMO2_NAND_CS0 | | | PISMO2_NAND_CS1 | | | PISMO1_NOR_BASE | | | PISMO1_NAND_BASE| | | PISMO2_CS0_BASE | | +-----------------+-----------------------------------------------------------+
Signed-off-by: Pekon Gupta pekon@ti.com --- arch/arm/cpu/armv7/omap-common/mem-common.c | 4 ++-- arch/arm/include/asm/arch-am33xx/mem.h | 7 ------- arch/arm/include/asm/arch-omap3/cpu.h | 1 - arch/arm/include/asm/arch-omap3/mem.h | 13 ------------- include/configs/am3517_crane.h | 7 +------ include/configs/am3517_evm.h | 7 +------ include/configs/cm_t35.h | 3 --- include/configs/devkit8000.h | 2 -- include/configs/dig297.h | 4 ---- include/configs/mcx.h | 4 ---- include/configs/nokia_rx51.h | 2 -- include/configs/omap3_beagle.h | 7 +------ include/configs/omap3_evm_common.h | 7 ++----- include/configs/omap3_igep00x0.h | 3 --- include/configs/omap3_logic.h | 8 ++------ include/configs/omap3_overo.h | 6 +----- include/configs/omap3_pandora.h | 7 +------ include/configs/omap3_zoom1.h | 7 +------ include/configs/tam3517-common.h | 4 ---- include/configs/tao3530.h | 7 +------ include/configs/tricorder.h | 2 -- 21 files changed, 13 insertions(+), 99 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/mem-common.c b/arch/arm/cpu/armv7/omap-common/mem-common.c index 05b81e0..573ea1e 100644 --- a/arch/arm/cpu/armv7/omap-common/mem-common.c +++ b/arch/arm/cpu/armv7/omap-common/mem-common.c @@ -116,8 +116,8 @@ void gpmc_init(void) ONENAND_GPMC_CONFIG6, 0 }; - u32 base = PISMO1_ONEN_BASE; - u32 size = PISMO1_ONEN_SIZE; + u32 size = GPMC_SIZE_128M; + u32 base = CONFIG_SYS_ONENAND_BASE; #else const u32 gpmc_regs[GPMC_MAX_REG] = { 0, 0, 0, 0, 0, 0, 0 }; u32 size = 0; diff --git a/arch/arm/include/asm/arch-am33xx/mem.h b/arch/arm/include/asm/arch-am33xx/mem.h index e7e8c58..b2412b5 100644 --- a/arch/arm/include/asm/arch-am33xx/mem.h +++ b/arch/arm/include/asm/arch-am33xx/mem.h @@ -59,13 +59,6 @@ /* max number of GPMC regs */ #define GPMC_MAX_REG 7
-#define PISMO1_NOR 1 -#define PISMO1_NAND 2 -#define PISMO2_CS0 3 -#define PISMO2_CS1 4 -#define PISMO1_ONENAND 5 #define DBG_MPDB 6 -#define PISMO2_NAND_CS0 7 -#define PISMO2_NAND_CS1 8
#endif /* endif _MEM_H_ */ diff --git a/arch/arm/include/asm/arch-omap3/cpu.h b/arch/arm/include/asm/arch-omap3/cpu.h index 4d06ef8..53cc2b0 100644 --- a/arch/arm/include/asm/arch-omap3/cpu.h +++ b/arch/arm/include/asm/arch-omap3/cpu.h @@ -98,7 +98,6 @@ struct ctrl_id { #define DEBUG_BASE 0x08000000 /* debug board */ #define NAND_BASE 0x30000000 /* NAND addr */ /* (actual size small port) */ -#define PISMO2_BASE 0x18000000 /* PISMO2 CS1/2 */ #define ONENAND_MAP 0x20000000 /* OneNand addr */ /* (actual size small port) */ /* SMS */ diff --git a/arch/arm/include/asm/arch-omap3/mem.h b/arch/arm/include/asm/arch-omap3/mem.h index d2dfb1e..0b78c1c 100644 --- a/arch/arm/include/asm/arch-omap3/mem.h +++ b/arch/arm/include/asm/arch-omap3/mem.h @@ -427,20 +427,7 @@ enum { /* max number of GPMC regs */ #define GPMC_MAX_REG 7
-#define PISMO1_NOR 1 -#define PISMO1_NAND 2 -#define PISMO2_CS0 3 -#define PISMO2_CS1 4 -#define PISMO1_ONENAND 5 #define DBG_MPDB 6 -#define PISMO2_NAND_CS0 7 -#define PISMO2_NAND_CS1 8 - -/* make it readable for the gpmc_init */ -#define PISMO1_NOR_BASE FLASH_BASE -#define PISMO1_NAND_BASE NAND_BASE -#define PISMO2_CS0_BASE PISMO2_MAP1 -#define PISMO1_ONEN_BASE ONENAND_MAP #define DBG_MPDB_BASE DEBUG_BASE
#ifndef __ASSEMBLY__ diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index ad4cbd8..d826214 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -252,17 +252,12 @@ */
/* **** PISMO SUPPORT *** */ - -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M - #define CONFIG_SYS_MAX_FLASH_SECT 520 /* max number of sectors */ /* on one chip */ #define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
-#define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE +#define CONFIG_SYS_FLASH_BASE NAND_BASE
/* Monitor at start of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 0102ff5..a9c5a8f 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -259,18 +259,13 @@ */
#if defined(CONFIG_CMD_NAND) -#define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE +#define CONFIG_SYS_FLASH_BASE NAND_BASE #endif
/* Monitor at start of flash */ diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 5c484ef..d8d71a9 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -258,9 +258,6 @@ */
/* **** PISMO SUPPORT *** */ -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M - /* Monitor at start of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 5308790..cc53fc9 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -262,8 +262,6 @@ #define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1
/* NAND and environment organization */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M - #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
#define CONFIG_ENV_IS_IN_NAND 1 diff --git a/include/configs/dig297.h b/include/configs/dig297.h index ce205e9..7e47c56 100644 --- a/include/configs/dig297.h +++ b/include/configs/dig297.h @@ -251,10 +251,6 @@ */
/* **** PISMO SUPPORT *** */ - -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M - #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
#define CONFIG_SYS_FLASH_BASE boot_flash_base diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 47244c0..75abb60 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -316,10 +316,6 @@ */
/* **** PISMO SUPPORT *** */ - -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M - #define CONFIG_NAND_OMAP_GPMC #define CONFIG_ENV_IS_IN_NAND #define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */ diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index e0c0fac..216dbef 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -220,8 +220,6 @@
#ifdef ONENAND_SUPPORT
-#define PISMO1_NAND_SIZE GPMC_SIZE_128M -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 3782049..74a3d1a 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -266,13 +266,8 @@ */
/* **** PISMO SUPPORT *** */ - -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M - #if defined(CONFIG_CMD_NAND) -#define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE +#define CONFIG_SYS_FLASH_BASE NAND_BASE #endif
/* Monitor at start of flash */ diff --git a/include/configs/omap3_evm_common.h b/include/configs/omap3_evm_common.h index ae4ce63..739d392 100644 --- a/include/configs/omap3_evm_common.h +++ b/include/configs/omap3_evm_common.h @@ -95,9 +95,6 @@ /* * PISMO support */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M - /* Monitor at start of flash - Reserve 2 sectors */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
@@ -205,12 +202,12 @@ * NAND / OneNAND */ #if defined(CONFIG_CMD_NAND) -#define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE +#define CONFIG_SYS_FLASH_BASE NAND_BASE
#define CONFIG_NAND_OMAP_GPMC #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #elif defined(CONFIG_CMD_ONENAND) -#define CONFIG_SYS_FLASH_BASE PISMO1_ONEN_BASE +#define CONFIG_SYS_FLASH_BASE ONENAND_MAP #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP #endif
diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 79daabd..0bb79ab 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -146,8 +146,6 @@ */
#ifdef CONFIG_BOOT_ONENAND -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M /* Configure the PISMO */ - #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ @@ -158,7 +156,6 @@ #endif
#ifdef CONFIG_NAND -#define PISMO1_NAND_SIZE GPMC_SIZE_128M /* Configure the PISMO */ #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE (512 << 10) /* Total Size Environment */ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 8dcbba3..717c935 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -277,16 +277,12 @@ */
#if defined(CONFIG_CMD_NAND) -#define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE +#define CONFIG_SYS_FLASH_BASE NAND_BASE #elif defined(CONFIG_CMD_ONENAND) -#define CONFIG_SYS_FLASH_BASE PISMO1_ONEN_BASE +#define CONFIG_SYS_FLASH_BASE ONENAND_MAP #endif
/* Monitor at start of flash */ diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index f7483a0..38f8dab 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -173,12 +173,8 @@ 0x01F00000) /* 31MB */
/* FLASH and environment organization */ -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M - #if defined(CONFIG_NAND) -#define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE +#define CONFIG_SYS_FLASH_BASE NAND_BASE #endif
/* Monitor at start of flash */ diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index da67787..c22c1fc 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -220,15 +220,10 @@ */
/* **** PISMO SUPPORT *** */ - -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M - #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
/* Monitor at start of flash */ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 3efe4cf..236281a 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -165,13 +165,8 @@ */
/* Monitor at start of flash */ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 0c2f0f1..aa0ea16 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -181,10 +181,6 @@ */
/* **** PISMO SUPPORT *** */ - -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M - #define CONFIG_NAND #define CONFIG_NAND_OMAP_GPMC #define CONFIG_ENV_IS_IN_NAND diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 1b0fee9..d414aed 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -253,13 +253,8 @@ */
/* **** PISMO SUPPORT *** */ - -/* Configure the PISMO */ -#define PISMO1_NAND_SIZE GPMC_SIZE_128M -#define PISMO1_ONEN_SIZE GPMC_SIZE_128M - #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */ -#define CONFIG_SYS_FLASH_BASE PISMO1_NAND_BASE +#define CONFIG_SYS_FLASH_BASE NAND_BASE
/* Monitor at start of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 80985a2..bf9551e 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -315,8 +315,6 @@ #define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
This patch moves some board specific NAND configs: - FROM: generic config file 'ti_armv7_common.h' - TO: individual board config files using these configs. So that each board can independently set the value as per its design.
Following configs are affected in this patch: CONFIG_SYS_NAND_U_BOOT_OFFS: <refer doc/README.nand> CONFIG_CMD_SPL_NAND_OFS: <refer doc/README.falcon> CONFIG_SYS_NAND_SPL_KERNEL_OFFS: <refer doc/README.falcon> CONFIG_CMD_SPL_WRITE_SIZE: <refer doc/README.falcon>
This patch also updates documentation for few of above NAND configs.
Signed-off-by: Pekon Gupta pekon@ti.com --- doc/README.nand | 12 ++++++++++++ include/configs/am335x_evm.h | 5 +++++ include/configs/cm_t335.h | 5 +++++ include/configs/omap3_beagle.h | 6 ++++++ include/configs/omap3_igep00x0.h | 7 +++++++ include/configs/omap3_overo.h | 6 ++++++ include/configs/omap3_zoom1.h | 6 ++++++ include/configs/pengwyn.h | 6 ++++++ include/configs/ti_armv7_common.h | 8 -------- 9 files changed, 53 insertions(+), 8 deletions(-)
diff --git a/doc/README.nand b/doc/README.nand index 70cf768..e29188f 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -89,6 +89,10 @@ Commands:
Configuration Options:
+ CONFIG_SYS_NAND_U_BOOT_OFFS + NAND Offset from where SPL will read u-boot image. This is the starting + address of u-boot MTD partition in NAND. + CONFIG_CMD_NAND Enables NAND support and commmands.
@@ -226,6 +230,14 @@ Platform specific options detection. However ECC calculation on such plaforms would still be done by GPMC controller.
+ CONFIG_SPL_NAND_AM33XX_BCH + Enables SPL-NAND driver (am335x_spl_bch.c) which supports ELM based + hardware ECC correction. This is useful for platforms which have ELM + hardware engine and use NAND boot mode. + Some legacy platforms like OMAP3xx do not have in-built ELM h/w engine, + so those platforms should use CONFIG_SPL_NAND_SIMPLE for enabling + SPL-NAND driver with software ECC correction support. + CONFIG_NAND_OMAP_ECCSCHEME On OMAP platforms, this CONFIG specifies NAND ECC scheme. It can take following values: diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index c1a6ada..f5bfd5d 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -254,6 +254,11 @@ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_CMD_SPL_NAND_OFS 0x00080000 /* os parameters */ +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x00200000 /* kernel offset */ +#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 +#endif #endif #endif
diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 4d1dd28..a3e6452 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -150,6 +150,11 @@ #define CONFIG_ENV_OFFSET 0x300000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #define CONFIG_SYS_NAND_ONFI_DETECTION +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_CMD_SPL_NAND_OFS 0x400000 /* un-assigned: (using dtb) */ +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x500000 +#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 +#endif
/* GPIO pin + bank to pin ID mapping */ #define GPIO_PIN(_bank, _pin) ((_bank << 5) + _pin) diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 74a3d1a..b665979 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -304,5 +304,11 @@ #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +/* NAND: SPL falcon mode configs */ +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_CMD_SPL_NAND_OFS 0x240000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 +#endif
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 0bb79ab..006c9a9 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -196,6 +196,13 @@ #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +/* NAND: SPL falcon mode configs */ +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_CMD_SPL_NAND_OFS 0x240000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 +#endif #endif
#endif /* __IGEP00X0_H */ diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 38f8dab..e66f306 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -216,5 +216,11 @@ #define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +/* NAND: SPL falcon mode configs */ +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_CMD_SPL_NAND_OFS 0x240000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 +#endif
#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 236281a..93f4d62 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -70,6 +70,12 @@ "4m(kernel),-(fs)"
#if defined(CONFIG_CMD_NAND) +/* NAND: SPL falcon mode configs */ +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_CMD_SPL_NAND_OFS 0x240000 +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 +#endif #define CONFIG_CMD_NAND_LOCK_UNLOCK /* Enable lock/unlock support */ #endif
diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index 8510405..4684ad6 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -159,6 +159,12 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +/* NAND: SPL falcon mode configs */ +#ifdef CONFIG_SPL_OS_BOOT +#define CONFIG_CMD_SPL_NAND_OFS 0x240000 /* un-assigned */ +#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 +#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 +#endif
/* * USB configuration. We enable MUSB support, both for host and for diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 6e0bf09..85c027c 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -243,13 +243,6 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0x80 /* address 0x10000 */ #define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0x80 /* 64KiB */
-/* NAND */ -#ifdef CONFIG_NAND -#define CONFIG_CMD_SPL_NAND_OFS 0x240000 /* end of u-boot */ -#define CONFIG_SYS_NAND_SPL_KERNEL_OFFS 0x280000 -#define CONFIG_CMD_SPL_WRITE_SIZE 0x2000 -#endif - /* spl export command */ #define CONFIG_CMD_SPL #endif @@ -275,7 +268,6 @@ #define CONFIG_SPL_NAND_ECC #define CONFIG_SPL_MTD_SUPPORT #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #endif #endif /* !CONFIG_NOR_BOOT */
[PATCH 3/3] in this series is updated version of below patch http://lists.denx.de/pipermail/u-boot/2014-July/183719.html
with regards, pekon
Gupta, Pekon
Pekon Gupta
