[U-Boot] [PATCH] sandbox: change local_irq_save() to macro
local_irq_save() should be a macro, not a function because local_irq_save() saves flag to the given argument.
GCC is silent about this issue, but Clang warns:
In file included from lib/asm-offsets.c:15: In file included from include/common.h:20: In file included from include/linux/bitops.h:110: arch/sandbox/include/asm/bitops.h:59:17: warning: variable 'flags' is uninitialized when used here [-Wuninitialized] local_irq_save(flags); ^~~~~
That change causes another warning:
In file included from include/linux/bitops.h:110:0, from include/common.h:20, from lib/asm-offsets.c:15: arch/sandbox/include/asm/bitops.h: In function ‘test_and_set_bit’: arch/sandbox/include/asm/bitops.h:56:16: warning: unused variable ‘flags’ [-Wunused-variable]
So, flags should be set to __always_unused.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Simon Glass sjg@chromium.org Cc: Jeroen Hofstee jeroen@myspectrum.nl --- arch/sandbox/include/asm/system.h | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/arch/sandbox/include/asm/system.h b/arch/sandbox/include/asm/system.h index 066acc5..02beed3 100644 --- a/arch/sandbox/include/asm/system.h +++ b/arch/sandbox/include/asm/system.h @@ -8,10 +8,7 @@ #define __ASM_SANDBOX_SYSTEM_H
/* Define this as nops for sandbox architecture */ -static inline void local_irq_save(unsigned flags __attribute__((unused))) -{ -} - +#define local_irq_save(x) #define local_irq_enable() #define local_irq_disable() #define local_save_flags(x)
Masahiro Yamada
