[U-Boot] [PATCH] ARM: dts: logicpd som-lvs and torpedos: Shrink SPL DTB
Since we have limited resources in SPL, it is the best interest to keep the SPL as small as possible and that includes the DTB. There are a few items in the device tree that can be removed, because these boards don't use them.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi index 956199a2b4..1abd9a3887 100644 --- a/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi @@ -10,6 +10,11 @@ chosen { stdout-path = &uart1; }; + + aliases { + /delete-property/ serial1; + /delete-property/ serial2; + }; };
&i2c1 { @@ -20,11 +25,8 @@ clock-frequency = <400000>; };
-&mmc2 { - status = "disabled"; -}; - -&mmc3 { - status = "disabled"; -}; +/delete-node/ &uart2; +/delete-node/ &uart3; +/delete-node/ &mmc2; +/delete-node/ &mmc3;
diff --git a/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi index 956199a2b4..1abd9a3887 100644 --- a/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi @@ -10,6 +10,11 @@ chosen { stdout-path = &uart1; }; + + aliases { + /delete-property/ serial1; + /delete-property/ serial2; + }; };
diff --git a/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi index 2c599f1c51..1635e42b55 100644 --- a/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi @@ -6,6 +6,13 @@
#include "omap3-u-boot.dtsi"
+/ { + aliases { + /delete-property/ serial1; + /delete-property/ serial2; + }; +}; + &i2c1 { clock-frequency = <400000>; }; @@ -14,11 +21,7 @@ clock-frequency = <400000>; };
-&mmc2 { - status = "disabled"; -}; - -&mmc3 { - status = "disabled"; -}; - +/delete-node/ &uart2; +/delete-node/ &uart3; +/delete-node/ &mmc2; +/delete-node/ &mmc3; diff --git a/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi index 2c599f1c51..976330f897 100644 --- a/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi @@ -6,6 +6,13 @@
+/ { + aliases { + /delete-property/ serial1; + /delete-property/ serial2; + }; +}; + &i2c1 { clock-frequency = <400000>; }; @@ -14,11 +21,8 @@ clock-frequency = <400000>; };
Adam Ford
