RE: [U-Boot-Users] FW: [440GX/PCI]
I see in the function pci_440_init that pci_target_init(hose) is called quite late. Would not it be better to call that at the beginning so board that are used in agent mode(arbiter/PISE bit off) can defined their inbound window?
Renaud:
Can't hurt to try it, right? I assume you have a timing issue btw two processors, one being the monarch and the other a target (ie the 440gx in your case).
Try it, report your findings to the list, submit a patch :)
Best Regards,
-travis
Travis Sawyer
