[U-Boot] [PATCH I2C] fix: error ATMEL_FIO_BASE undeclared, if use I2C_Soft on AT91
* Since AT91 name schema was changed to ATMEL_BASE_xxx, I2C_SOFT on AT91 devices fails with 'error: ATMEL_FIO_BASE undeclared' * change ATMEL_PIO_BASE to ATMEL_BASE_PIOA will fix this
Signed-off-by: Jens Scharsig esw@bus-elektronik.de --- include/i2c.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/i2c.h b/include/i2c.h index ee31034..1f35acf 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -78,7 +78,7 @@ # elif (defined(CONFIG_AT91RM9200) || \ defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9261) || \ defined(CONFIG_AT91SAM9263)) && !defined(CONFIG_AT91_LEGACY) -# define I2C_SOFT_DECLARATIONS at91_pio_t *pio = (at91_pio_t *) AT91_PIO_BASE; +# define I2C_SOFT_DECLARATIONS at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIOA; # else # define I2C_SOFT_DECLARATIONS # endif
Hello esw@bus-elektronik.de (Jens?),
esw@bus-elektronik.de wrote:
- Since AT91 name schema was changed to ATMEL_BASE_xxx, I2C_SOFT on AT91 devices fails with 'error: ATMEL_FIO_BASE undeclared'
- change ATMEL_PIO_BASE to ATMEL_BASE_PIOA will fix this
Thanks!
[hs@pollux u-boot-i2c]$ ./MAKEALL -a arm -s at91 [...]
--------------------- SUMMARY ---------------------------- Boards compiled: 55 ---------------------------------------------------------- [hs@pollux u-boot-i2c]$
Applied to u-boot-i2c.git
bye, Heiko
Heiko Schocher
