[U-Boot] Pull request v2: u-boot-sh/rmobile into u-boot-arm/master
Dear Albert Aribaud,
Please pull u-boot-sh/rmobile into u-boot-arm/master.
The following changes since commit 0a26e1d6c394aacbf1153977b7348d1dff85db3f:
arm: fix a double-definition error of _start symbol (2014-06-09 10:36:40 +0200)
git://git.denx.de/u-boot-sh.git rmobile
for you to fetch changes up to 2f7b27caf4e6bdc6cb4047ef3ee4021f20e14c5f:
arm: rmobile: lager: Remove NOR-Flash support from boards.cfg (2014-06-11 06:59:36 +0900)
---------------------------------------------------------------- Nobuhiro Iwamatsu (2): arm: rmobile: koelsch: Remove NOR-Flash support from boards.cfg arm: rmobile: lager: Remove NOR-Flash support from boards.cfg
boards.cfg | 2 -- 1 file changed, 2 deletions(-)
Hi Nobuhiro,
On Wed, 18 Jun 2014 12:24:47 +0900, Nobuhiro Iwamatsu iwamatsu@nigauri.org wrote:
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Nobuhiro Iwamatsu
