[U-Boot-Users] CFG_INIT_DCACHE_CS
Hello. Everyone. Now I am trying to port ppcboot to a simple custom board, with ppc405cr, 32M RAM, 4M EEPROM, JTAG, UART.
I can not understand some Marcos in the header file include/configs/xxx.h.
#define CFG_INIT_DCACHE_CS 4 /* use cs # 4 for data cache memory */
there is no OCM in 405CR, so ppcboot needs data cache for initial stacks and data. but what does the "chip select" mean?
As I know, chip select should be used on some peripheral devices, like Flash, NVRAM, why is it needed for data cache which is inside the CPU core?
Is the CS only a concept inside ppcboot? or something according to the hardware?
thanks a lot in advance.
maoyuan
Hello Moayuan,
Welcome!
You are right, the PPC405CR doesn't have the OCM, so the data cache has to be used for the initial stack. The Chip-Select is required to specify a memory region, so the PPC doesn't generate "bus-errors" upon accessing this cached memory region. Please use an unconnected CS (if possible) for this setup.
Best regards, Stefan.
Stefan Roese
yu
