[PATCH v2] common: Kconfig.boot: Add FIT_PRINT config option
Config allows to disable printing contents of fitImage to optimize boottime.
Signed-off-by: Ravik Hasija rahasij@linux.microsoft.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes for v2: - updated macro to check for CONFIG - fixed comment to reflect correct condition check --- common/Kconfig.boot | 6 ++++++ common/image-fit.c | 4 ++-- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/common/Kconfig.boot b/common/Kconfig.boot index 4525a12ab4..5eaabdfc27 100644 --- a/common/Kconfig.boot +++ b/common/Kconfig.boot @@ -140,6 +140,12 @@ config FIT_IMAGE_POST_PROCESS injected into the FIT creation (i.e. the blobs would have been pre- processed before being added to the FIT image).
+config FIT_PRINT + bool "Support FIT printing" + default y + help + Support printing the content of the fitImage in a verbose manner. + if SPL
config SPL_FIT diff --git a/common/image-fit.c b/common/image-fit.c index 21c44bdf69..4726051483 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -147,7 +147,7 @@ int fit_get_subimage_count(const void *fit, int images_noffset) return count; }
-#if !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_FIT_PRINT) +#if CONFIG_IS_ENABLED(FIT_PRINT) || CONFIG_IS_ENABLED(SPL_FIT_PRINT) /** * fit_image_print_data() - prints out the hash node details * @fit: pointer to the FIT format image header @@ -555,7 +555,7 @@ void fit_image_print(const void *fit, int image_noffset, const char *p) #else void fit_print_contents(const void *fit) { } void fit_image_print(const void *fit, int image_noffset, const char *p) { } -#endif /* !defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_FIT_PRINT) */ +#endif /* CONFIG_IS_ENABLED(FIR_PRINT) || CONFIG_IS_ENABLED(SPL_FIT_PRINT) */
/** * fit_get_desc - get node description property
Ravik Hasija
