[PATCH 1/3] arm: mvebu: Use MVEBU_SPL_BOOT_DEVICE instead of SPL_BOOT_DEVICE
Update the way KWB_CFG_SEC_BOOT_DEV is determined to use CONFIG_MVEBU_SPL_BOOT_DEVICE_{SPI,MMC} instead of CONFIG_SPL_BOOT_DEVICE.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/mach-mvebu/Makefile | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index 8bd2246325ca..61eeb9c8c186 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -65,10 +65,12 @@ KWB_REPLACE += CSK_INDEX KWB_CFG_CSK_INDEX = $(CONFIG_SECURED_MODE_CSK_INDEX)
KWB_REPLACE += SEC_BOOT_DEV -KWB_CFG_SEC_BOOT_DEV=$(patsubst "%",%, \ - $(if $(findstring BOOT_SPI_NOR_FLASH,$(CONFIG_SPL_BOOT_DEVICE)),0x34) \ - $(if $(findstring BOOT_SDIO_MMC_CARD,$(CONFIG_SPL_BOOT_DEVICE)),0x31) \ - ) +ifneq ($(CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI),) + KWB_CFG_SEC_BOOT_DEV=0x34 +endif +ifneq ($(CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC),) + KWB_CFG_SEC_BOOT_DEV=0x31 +endif
KWB_REPLACE += SEC_FUSE_DUMP KWB_CFG_SEC_FUSE_DUMP = a38x
CONFIG_FIXED_SDHCI_ALIGNED_BUFFER is needed on some Marvell SoCs when booting from MMC. All existing usages of this have the same value so make this the default and have the Kconfig option depend on SPL && MVEBU_SPL_BOOT_DEVICE_MMC.
drivers/mmc/Kconfig | 13 +++++++++++++ include/configs/clearfog.h | 7 ------- include/configs/controlcenterdc.h | 7 ------- include/configs/db-88f6820-gp.h | 7 ------- include/configs/helios4.h | 7 ------- include/configs/turris_omnia.h | 7 ------- scripts/config_whitelist.txt | 1 - 7 files changed, 13 insertions(+), 36 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 5e2921ce41a7..c8f9709d2d49 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -484,6 +484,19 @@ config SPL_MMC_SDHCI_ADMA This enables support for the ADMA (Advanced DMA) defined in the SD Host Controller Standard Specification Version 3.00 in SPL.
+config FIXED_SDHCI_ALIGNED_BUFFER + hex "SDRAM address for fixed buffer" + depends on SPL && MVEBU_SPL_BOOT_DEVICE_MMC + default 0x00180000 + help + On the Marvell Armada 38x when the SPL runs it located in internal + SRAM which is the L2 cache locked to memory. When the MMC buffers + are located on the stack (or bss), the SDIO controller (SDHCI) can't + write into this L2 cache memory. + + This specifies the address of a fixed buffer located in SDRAM that + will be used for all SDHCI transfers in the SPL. + config MMC_SDHCI_ASPEED bool "Aspeed SDHCI controller" depends on ARCH_ASPEED diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 871e87c26d01..ec0f0e3ed115 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -56,13 +56,6 @@ #define CONFIG_SPL_STACK (0x40000000 + ((192 - 16) << 10)) #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
-#if defined(CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC) || defined(CONFIG_MVEBU_SPL_BOOT_DEVICE_SATA) -/* SPL related MMC defines */ -#ifdef CONFIG_SPL_BUILD -#define CONFIG_FIXED_SDHCI_ALIGNED_BUFFER 0x00180000 /* in SDRAM */ -#endif -#endif - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index b499d7085fd4..a8534e59d9b1 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -53,13 +53,6 @@ #define CONFIG_SPL_STACK (0x40000000 + ((212 - 16) << 10)) #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
-#if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SDIO_MMC_CARD -/* SPL related MMC defines */ -#ifdef CONFIG_SPL_BUILD -#define CONFIG_FIXED_SDHCI_ALIGNED_BUFFER 0x00180000 /* in SDRAM */ -#endif -#endif - /* * Environment Configuration */ diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 8dc73e8b1cc9..b4b58e0bcb8a 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -53,13 +53,6 @@ #define CONFIG_SPL_STACK (0x40000000 + ((192 - 16) << 10)) #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
-#if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SDIO_MMC_CARD -/* SPL related MMC defines */ -#ifdef CONFIG_SPL_BUILD -#define CONFIG_FIXED_SDHCI_ALIGNED_BUFFER 0x00180000 /* in SDRAM */ -#endif -#endif - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/helios4.h b/include/configs/helios4.h index 151ab66f4c3f..62a52e68b56a 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -56,13 +56,6 @@ #define CONFIG_SPL_STACK (0x40000000 + ((192 - 16) << 10)) #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
-#if defined(CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC) || defined(CONFIG_MVEBU_SPL_BOOT_DEVICE_SATA) -/* SPL related MMC defines */ -#ifdef CONFIG_SPL_BUILD -#define CONFIG_FIXED_SDHCI_ALIGNED_BUFFER 0x00180000 /* in SDRAM */ -#endif -#endif - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index 8119340b112f..112ddd3f4961 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -36,13 +36,6 @@ #define CONFIG_SPL_STACK (0x40000000 + ((192 - 16) << 10)) #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
-#ifdef CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC -/* SPL related MMC defines */ -# ifdef CONFIG_SPL_BUILD -# define CONFIG_FIXED_SDHCI_ALIGNED_BUFFER 0x00180000 /* in SDRAM */ -# endif -#endif - /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cecdda678191..25962b735f27 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -87,7 +87,6 @@ CONFIG_FDTFILE CONFIG_FEC_ENET_DEV CONFIG_FEC_FIXED_SPEED CONFIG_FEC_MXC_PHYADDR -CONFIG_FIXED_SDHCI_ALIGNED_BUFFER CONFIG_FLASH_BR_PRELIM CONFIG_FLASH_CFI_LEGACY CONFIG_FLASH_OR_PRELIM
On Sun, 29 May 2022 11:13:17 +1200 Chris Packham judge.packham@gmail.com wrote:
Reviewed-by: Marek Behún marek.behun@nic.cz
Thanks, Stefan
- hex "SDRAM address for fixed buffer"
- depends on SPL && MVEBU_SPL_BOOT_DEVICE_MMC
- default 0x00180000
- help
- config MMC_SDHCI_ASPEED bool "Aspeed SDHCI controller" depends on ARCH_ASPEED
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
- Environment Configuration
Viele Grüße, Stefan Roese
Signed-off-by: Chris Packham judge.packham@gmail.com Reviewed-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de
CONFIG_SPL_BOOT_DEVICE was made obsolete by CONFIG_MVEBU_SPL_BOOT_DEVICE_{SPI,MMC,SATA,UART}. CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI is the default so existing users of CONFIG_SPL_BOOT_DEVICE can simply have the option removed.
include/configs/controlcenterdc.h | 11 ----------- include/configs/db-88f6820-amc.h | 12 ------------ include/configs/db-88f6820-gp.h | 11 ----------- scripts/config_whitelist.txt | 1 - 4 files changed, 35 deletions(-)
diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index a8534e59d9b1..3d7da4b2a33e 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -23,17 +23,6 @@ #endif
/* SPL */ -/* - * Select the boot device here - * - * Currently supported are: - * SPL_BOOT_SPI_NOR_FLASH - Booting via SPI NOR flash - * SPL_BOOT_SDIO_MMC_CARD - Booting via SDIO/MMC card (partition 1) - */ -#define SPL_BOOT_SPI_NOR_FLASH 1 -#define SPL_BOOT_SDIO_MMC_CARD 2 -#define CONFIG_SPL_BOOT_DEVICE SPL_BOOT_SPI_NOR_FLASH - /* Defines for SPL */ #define CONFIG_SPL_SIZE (160 << 10)
diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 6538e66052aa..d044292d6b5a 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -27,18 +27,6 @@ "initrd_high=0x10000000\0"
/* SPL */ -/* - * Select the boot device here - * - * Currently supported are: - * SPL_BOOT_SPI_NOR_FLASH - Booting via SPI NOR flash - * - * MMC is not populated on this board. - * NAND support may be added in the future. - */ -#define SPL_BOOT_SPI_NOR_FLASH 1 -#define CONFIG_SPL_BOOT_DEVICE SPL_BOOT_SPI_NOR_FLASH - /* Defines for SPL */ #define CONFIG_SPL_SIZE (140 << 10) #define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - (CONFIG_SPL_TEXT_BASE - 0x40000000)) diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index b4b58e0bcb8a..35ff6a876fde 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -28,17 +28,6 @@ "initrd_high=0x10000000\0"
/* SPL */ -/* - * Select the boot device here - * - * Currently supported are: - * SPL_BOOT_SPI_NOR_FLASH - Booting via SPI NOR flash - * SPL_BOOT_SDIO_MMC_CARD - Booting via SDIO/MMC card (partition 1) - */ -#define SPL_BOOT_SPI_NOR_FLASH 1 -#define SPL_BOOT_SDIO_MMC_CARD 2 -#define CONFIG_SPL_BOOT_DEVICE SPL_BOOT_SPI_NOR_FLASH - /* Defines for SPL */ #define CONFIG_SPL_SIZE (140 << 10) #define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - (CONFIG_SPL_TEXT_BASE - 0x40000000)) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 25962b735f27..a8766c9755ab 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -565,7 +565,6 @@ CONFIG_SPI_HALF_DUPLEX CONFIG_SPI_N25Q256A_RESET CONFIG_SPL_BOARD_LOAD_IMAGE CONFIG_SPL_BOOTROM_SAVE -CONFIG_SPL_BOOT_DEVICE CONFIG_SPL_BSS_MAX_SIZE CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_CMT
On Sun, 29 May 2022 11:13:18 +1200 Chris Packham judge.packham@gmail.com wrote:
Thanks, Stefan
/* SPL */ -/*
- Select the boot device here
- Currently supported are:
- SPL_BOOT_SPI_NOR_FLASH - Booting via SPI NOR flash
- SPL_BOOT_SDIO_MMC_CARD - Booting via SDIO/MMC card (partition 1)
/* SPL */ -/*
- MMC is not populated on this board.
- NAND support may be added in the future.
/* SPL */ -/*
Thanks, Stefan
- KWB_CFG_SEC_BOOT_DEV=0x34
- KWB_CFG_SEC_BOOT_DEV=0x31
+endif
Signed-off-by: Chris Packham judge.packham@gmail.com Reviewed-by: Stefan Roese sr@denx.de
Chris Packham
Marek Behún
Stefan Roese
