[U-Boot] granularity of bootm subcommands
So I proposed a set of subcommands that looked like:
bootm start <args> bootm prep bootm load_os bootm load_fdt bootm load_initrd bootm jump bootm restore
is this the right granularity or should we go finer?
"prep" could be:
bootm disable_interrupts bootm usb_stop bootm disable_caches
"load_os" stays as is.
"load_fdt" could be:
bootm load_fdt bootm boardsetup_fdt bootm fdt_resize
"load_initrd" could be: bootm load_initrd bootm fdt_initrd_fixup
"jump" stays as is.
"restore" could be: bootm enable_interrupts bootm usb_start bootm enable_caches
Also I'm adding in: bootm cmdline bootm kbd (kernel bd_t)
Finally I'd like to change the subcommands to be prefixed with '_' to make parsing easier: bootm _start <args> bootm _prep bootm _load_os ...
- k
"prep" could be:
This is "usb stop"
This is "icache off && dcache off"
Decompresses to a destination address? I didn't see a gunzip/bz2 command in my brief search. I would rather have a "decompress" general purpose command (perhaps it is/should be part of the "image" (im*) command set?).
I'm speculating based on a very brief look at the code/structs that an image command could do a "load" on a kernel image and ramdisk image identically (filling out an image header struct as a side effect?). For "FIT" images, there are potentially more pieces, but the concept would be the same.
I'm kinda hung up on how to use the image header struct. I think we want to be able to reference values for scripting (e.g. fixing up fdt properties) which implies the values need to be put into env variables (ugh, lots of 'em) or we need a way for an "image" command (?) to pull values out of the image header struct?
<fill in clever ideas here>
bootm load_fdt
This is probably "fdt move"? (which is a misnomer: it actually is a copy - my bad) The fdt source and destination addresses need to be determined (source from the image or "fdt address", malloc/lmb the destination?). I would advocate an "image" (iminfo?) command that sets, as a side effect env variables or the image header structure you identified previously.
Obviously, I have not thought through this very carefully.
Use "fdt boardsetup"
bootm fdt_resize
"fdt move" with a size will do a resize. Perhaps a new "fdt resize" command to make it more obvious. Do we really need to resize, can we just make the fdt blob "big enough" (at the source or when we do the "fdt move") and not worry about it? Note that I addressed this previously with the "-S" dtc flag (now deprecated, use -p instead) and forced the problem on whoever built the blob originally. Not 100% satisfactory, but making it SEP is very effective. ;-)
See "load_os" comments on it being an "image" command.
This is fixing up the fdt blob to point to the initrd? That should be doable with a couple of "fdt set <path> <value>" commands.
"jump" stays as is.
YEAH! The Core Functionality.
"usb reset" looks like it does this?
bootm enable_caches
icache on && dcache on
Use "fdt set <path> $cmdline"?
I presume "kbd" is shorthand for "kernel bd", aka. legacy boot. Maybe "bootm legacybd"? (shortenable to "bootm legacy")
Bleah, I dislike typing underscores, it requires me to use both hands and seriously impacts my ability to drink beer. :-P Since these commands will all be scripted (normally), I can live with that.
Thanks, gvb
bootm usb_stop
This is "usb stop"
So this case is easy since its a compile time choice.
I assume you are suggesting new toplevel cache commands.
This is orthogonal to the bootm discussion. We can refactor the code to allow for such a toplevel command and reuse the code. But the bootm commands CAN NOT require control flow in the scripting lang. Thus the desire to decompress or not, and what type has to be hidden inside a command like "load_os". I'm ok w/providing and optional argument to the command to override the desired dest addr.
"load_fdt" could be: bootm load_fdt
Some of this can be dealt with in a second pass.
We can't use it directly. Remember the unconditionality/control issues.
bootm fdt_resize
Andy providing a patch that makes -S/-p not needed anymore. I'd prefer to keep that functionality. So we should have resize support.
The key to remember is in the first pass we have to be able to do all the steps in order and it work regardless of the input differences.. thus mimicking the current bootm functionality. This means no (if..than..else) which means we can't use any of the current commands directly.
- k
Kumar Gala wrote:
bootm usb_stop
This is "usb stop"
No, existing: cmd_cache.c
Agreed on the orthogonality. Last night I started looking at image.c to how much "bootm" functionality is implemented in image.c. My thought is that the image manipulation functions (iminfo, imtest, imls) should be factored out of cmd_bootm.c into a new cmd_image.c (or something like that) and I'm thinking we need some new "image" commands to do the image processing for OS images (various types), ramdisk images, and ?others?.
Wolfgang advocated supporting the old parser. Personally, I'm OK with requiring hush in order to enable the New Improved bootm behavior and leaving users of the old parser with the old bootm (arrrr, more #ifdefs). I'm not sure we can get to a reasonable state without /some/ hush conditionals.
I think it would be foolish to cripple or kill a bootm refactor simply because we were unwilling to require hush.
Either conditionals or have two scripts, one with fdt and one without (which still is a conditional, just SEP to implement the conditional).
My drive is to get bootm to only boot stuff out of memory and I'm fixating on getting bootm out of the business of rearranging and fixing up stuff in memory. IMHO there are or should be other commands to do all the rearranging and fixing up. Well, as much as possible anyway.
bootm fdt_resize
Yes, but I would like it to be built into the fdt command, not the bootm command.
While autoresizing is cool, I struggle seeing why we need to work so hard. Adding 4K padding isn't /that/ bad (ducks as Wolfgang swings). Doing two passes is ugly IMHO. Oh well, another dog, another day.
- k
Hush little baby, don't say a word... gvb
Dear Jerry Van Baren,
I think that the default boot behaviour will not need *any* shell commands, because we can implement this easily in C function calls.
It is just when a user wants to redefine boot behaviour that the shell interface comes into play, and then it's the user's decision if he has simple needs that can be implemented with the old parser, or if he needs more scripting capabilities and has to enable hush.
Scott Wood wrote:
Ick. How about using a different name than "bootm"?
-Scott
Yeah, reusing "bootm" may be too clever.
What I had in mind for overloading bootm is to do strncmp() operations for each of the subcommands (and where none of the subcommands could be interpreted as hex numbers - i.e. have a letter g-z or "_" in it) and, if none of the valid subcommands passed, do a legacy implementation where the three parameters are parsed as hex (or "-" for the ramdisk).
Again, while I like the concept of using "bootm" since we are familiar with it (and I don't have a better name), I would not be adverse to using a different command name since the New Improved "bootm" will be substantially different than bootm-classic.
Best regards, gvb
participants (5)
Jerry Van Baren
Jerry Van Baren
Kumar Gala
Scott Wood
