[U-Boot] Problem with flash on a MPC5200B board
Hi Everyone
I'm pretty new to U-Boot and Embedded system globally, but in the last few weeks I have learn a lot and I'm now trying to port correctly U-Boot v 1.3.4 to a custom board based on a Icecube. I'm able to boot a linux kernel with it when I use the RAM with the bootm command.
Unfortunately, I must make it work with the FLASH. The chip used for the flash is a S29GL128 or a S29GL256 from Spansion, they are 16bits chips but the bus is only 8bits. By reading the datasheet, these chips are supposed to support the Common Flash Interface so I'm trying to make then work with the CFI driver of U-Boot.
Here is what I get when booting with DEBUG activated:
U-Boot 1.3.4 (Oct 7 2008 - 16:39:49)
CPU: MPC5200B v2.2, Core v1.4 at 378 MHz Bus 84 MHz, IPB 84 MHz, PCI 21 MHz Board: Icecube Based Board I2C: 93 kHz, ready DRAM: 64 MB Top of RAM usable for U-Boot at: 04000000 Reserving 551k for U-Boot at: 03f76000 Reserving 130k for malloc() at: 03f55800 Reserving 68 Bytes for Board Info at: 03f557bc Reserving 60 Bytes for Global Data at: 03f55780 Stack Pointer at: 03f55768 New Stack Pointer is: 03f55768 Now running in RAM - U-Boot at: 03f76000 FLASH: flash detect cfi fwc addr ff000000 cmd f0 f0 8bit x 8 bit fwc addr ff000000 cmd f0 f0 8bit x 8 bit fwc addr ff000055 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr ff000010 is= 0 51 fwc addr ff000555 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr ff000010 is= 0 51 fwc addr ff000000 cmd f0 f0f0 16bit x 8 bit fwc addr ff000000 cmd f0 f0f0 16bit x 8 bit fwc addr ff0000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr ff000020 is= 5151 5151 is= cmd 52(R) addr ff000022 is= 5252 5252 is= cmd 59(Y) addr ff000024 is= 5959 5959 device interface is 2 found port 2 chip 1 port 16 bits chip 8 bits 00 : 51 52 59 02 00 40 00 00 00 00 00 27 36 00 00 06 QRY..@.....'6... 10 : 06 09 13 03 05 03 02 19 02 00 06 00 01 ff 00 00 ................ 20 : 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 ............... fwc addr ff000000 cmd f0 f0f0 16bit x 8 bit fwc addr ff001554 cmd aa aaaa 16bit x 8 bit fwc addr ff000aaa cmd 55 5555 16bit x 8 bit fwc addr ff001554 cmd 90 9090 16bit x 8 bit fwc addr ff000000 cmd f0 f0f0 16bit x 8 bit fwc addr ff0000aa cmd 98 9898 16bit x 8 bit manufacturer is 2 manufacturer id is 0x5 device id is 0x56 device id2 is 0x0 cfi version is 0x3133 size_ratio 1 port 16 bits chip 8 bits found 1 erase regions erase region 0: 0x020000ff erase_region_count = 256 erase_region_size = 131072 ERROR: too many flash sectors fwc addr ff000000 cmd f0 f0 8bit x 8 bit flash_protect ON: from 0xFFF00000 to 0xFFF43FFF flash_protect ON: from 0xFFFE0000 to 0xFFFFFFFF 32 MB basetask = 0, tasks = 2 task_org = 0x03fb4c00 TDT start = 0x00000040, end = 0x000001b8 PCI: Bus Dev VenId DevId Class Int PCI Scan: Found Bus 0, Device 24, Function 0 00 18 168c 001b 0200 00 PCI Scan: Found Bus 0, Device 26, Function 0 00 1a 1057 5809 0680 00 In: serial Out: serial Err: serial U-Boot relocated to 03f76000 Net: mpc5xxx_fec_init_phy... Begin mpc5xxx_fec_init_phy... Done FEC ETHERNET
Type "boot" to boot to Linux (default) Type "help" for a list of commands
So I got an "ERROR: too many flash sectors" and a 32 MB size ... I know for sure that the chip is 16 MB so there is a kind of inconsistency... I'm also a bit confuse about what "#define" I should use to force my board to communicate in 8bit even if it's capable of 16bit. I though that I simply had to "#undef FLASH_CFI_16BIT" but that doesn't seem to do the trick.
I'm not sure to understand the debug output I got... fwc addr ff000000 cmd f0 f0 8bit x 8 bit ... fwc addr ff000000 cmd f0 f0f0 16bit x 8 bit
Also is the value of erase_region_count = 256 should be the number of sector on the chip ???? Because I know that the ship have a maximum of 128 sectors... If someone could brief me a bit about the debug output posted above I would greatly appreciate.
I'm pretty sure I have nearly complete the port except for this FLASH issue...
Help/Suggestion/Comments are welcome
Thank you
Sylvain
Humm ... Nobody can help me ? If you need more informations I can get them, I would really like to understand the debug output I'm seeing.
Thank you
Sylvain
2008/10/7 Sylvain Lamontagne sylvain.lamontagne@gmail.com
Hi Everyone
Thank you
Sylvain
Hi again everyone
I tried a lot of stuff today but was still unable get it to work. Here is my Flash configuration:
/* * Flash configuration */ #define CFG_FLASH_BASE 0xFF000000 #define CFG_FLASH_SIZE 0x1000000 //#define CFG_ENV_ADDR 0xFFFE0000 #define CFG_ENV_OFFSET 0x00FE0000 //#define CFG_FLASH_MAX_SIZE 0x00ffffff #define CFG_ENV_ADDR (CFG_FLASH_BASE + CFG_ENV_OFFSET) #define CFG_MAX_FLASH_BANKS 1 /* max num of memory banks */ #define CFG_MAX_FLASH_SECT 128 /* max num of sectors on one chip */ #define CFG_FLASH_SECT_SIZE 0x20000 #define CFG_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */
#undef CONFIG_FLASH_16BIT /* Flash is 8-bit */ //#define CONFIG_FLASH_16BIT #define CFG_FLASH_CFI_DRIVER #define CFG_FLASH_CFI #define CFG_FLASH_USE_BUFFER_WRITE #define CFG_FLASH_BANKS_LIST {CFG_FLASH_BASE}
I think the problem may come from the Manufacturer ID and Device ID, from the datasheet it's supposed to be: Manufacturer ID xx01h/1h Device ID, Word 1 227Eh/7Eh
The CFI detection seems to report them as manufacturer id is 0x5 device id is 0x56
How can I force it ? Or maybe I'm totally searching in the wrong direction...
Sylvain
2008/10/8 Sylvain Lamontagne sylvain.lamontagne@gmail.com
Thank you
Sylvain
Hi Everyone
Thank you
Sylvain
Sylvain Lamontagne wrote:
Hi again everyone
- Flash configuration
There is no force. No Jedi Knights. Sorry.
You need to figure out your hardware and why the CFI detection isn't working or why it *is* working but the flash you have isn't what you expected.
My advice is to *manually* do the CFI command sequences to read the QRY response and the manufacturer's ID info using "mw" (memory write) commands.
Ahh, here are some good instructions: <www.spansion.com/application_notes/read_debug_using_CFI_an_01e.pdf>
Things I've found by manually probing: byte lanes swapped (gotta love those hardware folks helping me...), bits swapped end-for-end (not really - I haven't had this for flash but I have for other h/w grrrr), chip width and data lane width, misunderstanding of how the data should look when the chip is in command/status mode, etc.
Sylvain
Thank you
Sylvain
Hi Everyone
Which specific one are you using on your board, 128 or 256? Are they really Spansion parts or are the "just like Spansion" parts? How many are soldered down on the board?
Your results (below) are indicating that they are CFI.
Sorry, I am not sure how to interpret this. Do it by hand and see what the results are. The address offsets seem to say 2 chips x8, but the data seems to be saying 4 chips x8.
Get the raw data by hand and dissect it.
Are you *sure* you have Spansion parts on the board? Read the brand and chip number off the chips soldered to your board, don't trust the h/w engineers, they are out to get you. ;-)
Also, do the ID sequence by hand, don't trust the s/w.
Seems right.
Whoops, 1 erase region isn't right.
More badness.
The chips "are capable", but the selection between x8 and x16 is a hardware selection that was chosen by the h/w engineer when he drew the schematic. There isn't any "force" nor choice by the time you get the board. You need to understand his choice and configure for it.
I'm not knowledgeable of the flash debug prints because I've never used them. I would do the flash probing manually and decode it against the data sheet.
Cut out the middleman, understand what your hardware is telling you without the the s/w (debug) interpreting it.
Thank you
Sylvain
HTH, gvb
Sylvain,
there may be a combination of several faults.
What exact type of flash are you using ->have a look at the suffix like "TFIR040" to figure out if it's a fixed x8 or x16 or configurable and how the sector layout is supposed to be (top/bottom boot or uniform sector flash).
Send me the correct code and I'll have a look.
If it is a configurable width chip you should ask the designer how he decided to connect the "byte#" pin, i.e. pull-up or pull-down.
Last point is the MPC5200 local bus running in little endian mode since it's basically designed for PCI - that's a common mistake. If your byteorder matches and you're running with 16-Bit you should x-check the byte lanes, i.e. check if upper and lower date byte are connected to the flash in a proper way.
If you can post the schematic (single page containing the Flash and LPB) I'll verify it.
regards, Andre
Hi again everyone
Sylvain
Thank you
Sylvain
Hi Everyone
Seems right.
More badness.
Thank you
Sylvain
HTH, gvb _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
MATRIX VISION GmbH, Talstraße 16, DE-71570 Oppenweiler - Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschäftsführer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
Andre Schwarz
Jerry Van Baren
Sylvain Lamontagne
