[PATCH v2 00/18] i2c: Chip away at some old code
This series aims to remove some of the older contents of i2c.h so that we can move towards having just the dm API.
It does not remove any boards, but instead removes functionality.
Changes in v2: - Drop omap3_beagle.h change as that board was removed - Leave pg_wcom alone as its boards were converted - Drop patch "pg-wcom: Drop CFG_SYS_I2C_MAX_HOPS"
Simon Glass (18): i2c: Remove board_i2c_init() i2c: Remove IC2_xxx enum i2c: Remove CFG_I2C_MULTI_BUS mips: malta: Drop CMD_DATE armv8: ls2085a: Drop CMD_DATE mx28 / mx51: Drop CMD_DATE MPC837XERDB: ethernut5: work_92105: Drop CMD_DATE rtc: Drop CFG_SYS_RTC_BUS_NUM date: Drop the legacy I2C code fsl: mxc: Drop legacy I2c i2c: Drop reference to SYS_I2C_INIT_BOARD octeon: Drop OCTEON_I2C_FDT dead code i2c: Remove I2C_SET_BUS() i2c: Remove I2C_GET_BUS() i2c: Drop CFG_SYS_MAX_I2C_BUS i2c: Drop i2c_get_bus_num_fdt() and i2c_reset_port_fdt() i2c: Remove CFG_SYS_I2C_MAX_HOPS i2c: Remove CFG_SYS_I2C_DIRECT_BUS
README | 27 +----- arch/mips/mach-octeon/octeon_fdt.c | 7 -- cmd/date.c | 32 ------- cmd/i2c.c | 23 ----- configs/MPC837XERDB_defconfig | 1 - configs/ethernut5_defconfig | 1 - configs/ls2080aqds_nand_defconfig | 1 - configs/ls2080aqds_qspi_defconfig | 1 - configs/ls2080ardb_nand_defconfig | 1 - configs/malta64_defconfig | 1 - configs/malta64el_defconfig | 1 - configs/malta_defconfig | 1 - configs/maltael_defconfig | 1 - configs/mx28evk_defconfig | 1 - configs/mx51evk_defconfig | 1 - configs/work_92105_defconfig | 1 - doc/I2C_Edge_Conditions | 10 +- drivers/ddr/fsl/main.c | 3 +- drivers/i2c/i2c_core.c | 141 ----------------------------- drivers/i2c/mxc_i2c.c | 1 + drivers/i2c/soft_i2c.c | 11 --- drivers/power/power_i2c.c | 5 - drivers/usb/host/ohci-lpc32xx.c | 4 - include/configs/ethernut5.h | 3 - include/configs/ls1028aqds.h | 1 - include/configs/ls1028ardb.h | 2 - include/configs/ls1046afrwy.h | 1 - include/configs/lx2160aqds.h | 3 - include/configs/lx2160ardb.h | 3 - include/configs/lx2162aqds.h | 3 - include/configs/m53menlo.h | 2 - include/configs/sniper.h | 14 --- include/configs/tqma6.h | 3 - include/configs/tqma6_wru4.h | 1 - include/i2c.h | 107 ---------------------- 35 files changed, 7 insertions(+), 412 deletions(-)
This function is not used, so drop it.
(no changes since v1)
include/i2c.h | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/include/i2c.h b/include/i2c.h index 4e59009cd93..8d91b24b43b 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -972,14 +972,6 @@ enum { I2C_8, I2C_9, I2C_10, };
-/** - * Get FDT values for i2c bus. - * - * @param blob Device tree blbo - * Return: the number of I2C bus - */ -void board_i2c_init(const void *blob); - /** * Find the I2C bus number by given a FDT I2C node. *
Hello Simon,
Thanks!
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
This is only used by devkit3250 which is being removed. Drop it.
drivers/usb/host/ohci-lpc32xx.c | 4 ---- include/i2c.h | 6 ------ 2 files changed, 10 deletions(-)
diff --git a/drivers/usb/host/ohci-lpc32xx.c b/drivers/usb/host/ohci-lpc32xx.c index ed04cae7afe..bf89bf8ab49 100644 --- a/drivers/usb/host/ohci-lpc32xx.c +++ b/drivers/usb/host/ohci-lpc32xx.c @@ -94,10 +94,6 @@ static int isp1301_set_value(struct udevice *dev, int reg, u8 value)
static void isp1301_configure(struct udevice *dev) { -#if !CONFIG_IS_ENABLED(DM_I2C) - i2c_set_bus_num(I2C_2); -#endif - /* * LPC32XX only supports DAT_SE0 USB mode * This sequence is important diff --git a/include/i2c.h b/include/i2c.h index 8d91b24b43b..1d3be3f6759 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -966,12 +966,6 @@ static inline void I2C_SET_BUS(unsigned int bus) i2c_set_bus_num(bus); }
-/* Multi I2C definitions */ -enum { - I2C_0, I2C_1, I2C_2, I2C_3, I2C_4, I2C_5, I2C_6, I2C_7, - I2C_8, I2C_9, I2C_10, -}; - /** * Find the I2C bus number by given a FDT I2C node. *
Hello Simon,
Thanks!
bye, Heiko
This is used by a few boards but we are years past the migration date, so let's drop it now.
README | 7 ------- include/configs/sniper.h | 14 -------------- include/configs/tqma6.h | 3 --- include/i2c.h | 2 +- 4 files changed, 1 insertion(+), 25 deletions(-)
diff --git a/README b/README index b76449b70a8..c3821c5ce4e 100644 --- a/README +++ b/README @@ -883,13 +883,6 @@ The following options need to be configured: You should define these to the GPIO value as given directly to the generic GPIO functions.
- CFG_I2C_MULTI_BUS - - This option allows the use of multiple I2C buses, each of which - must have a controller. At any point in time, only one bus is - active. To switch to a different bus, use the 'i2c dev' command. - Note that bus numbering is zero-based. - CFG_SYS_I2C_NOPROBES
This option specifies a list of I2C devices that will be skipped diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 45a3102aeee..d0ae5e18605 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -34,20 +34,6 @@
#define CFG_SYS_SDRAM_BASE 0x80000000
-/* - * I2C - */ - -#define CFG_I2C_MULTI_BUS - -/* - * Input - */ - -/* - * SPL - */ - /* * Serial */ diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 2da76f15431..ceeed174ec5 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -26,9 +26,6 @@
#define TQMA6_SPI_FLASH_SECTOR_SIZE SZ_64K
-/* I2C Configs */ -#define CFG_I2C_MULTI_BUS - #if !defined(CONFIG_DM_PMIC) #define CFG_POWER_PFUZE100_I2C_ADDR 0x08 #define TQMA6_PFUZE100_I2C_BUS 2 diff --git a/include/i2c.h b/include/i2c.h index 1d3be3f6759..622540c8265 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -942,7 +942,7 @@ unsigned int i2c_get_bus_speed(void); * only for backwardcompatibility, should go away if we switched * completely to new multibus support. */ -#if CONFIG_IS_ENABLED(SYS_I2C_LEGACY) || defined(CFG_I2C_MULTI_BUS) +#if CONFIG_IS_ENABLED(SYS_I2C_LEGACY) # if !defined(CFG_SYS_MAX_I2C_BUS) # define CFG_SYS_MAX_I2C_BUS 2 # endif
Hello Simon,
Changes in v2:
Thanks!
bye, Heiko
These boards use pre-driver model code and it is several years since the migration deadline. Disable the 'date' command so that this old code can be removed.
configs/malta64_defconfig | 1 - configs/malta64el_defconfig | 1 - configs/malta_defconfig | 1 - configs/maltael_defconfig | 1 - 4 files changed, 4 deletions(-)
diff --git a/configs/malta64_defconfig b/configs/malta64_defconfig index ff371daaa0d..8ac29b9289f 100644 --- a/configs/malta64_defconfig +++ b/configs/malta64_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_IDE_MAXBUS=1 diff --git a/configs/malta64el_defconfig b/configs/malta64el_defconfig index 5b130bcde9b..0a71013d5fc 100644 --- a/configs/malta64el_defconfig +++ b/configs/malta64el_defconfig @@ -29,7 +29,6 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_IDE_MAXBUS=1 diff --git a/configs/malta_defconfig b/configs/malta_defconfig index ce917a69de5..355292ef950 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_IDE_MAXBUS=1 diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index de29a7a3a5b..ffd27713963 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_PCI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_IDE_MAXBUS=1
Hello Simon,
Thanks!
bye, Heiko
configs/ls2080aqds_nand_defconfig | 1 - configs/ls2080aqds_qspi_defconfig | 1 - configs/ls2080ardb_nand_defconfig | 1 - 3 files changed, 3 deletions(-)
diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 06e41546d67..0066414f0f5 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -61,7 +61,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 0b54bc999e7..44a1459749f 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -43,7 +43,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index f1009e1738b..cbc8d6a5cf4 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -68,7 +68,6 @@ CONFIG_CMD_PCI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y
Hello Simon,
Thanks!
bye, Heiko
These use pre-driver model code and it is several years since the migration deadline. Disable the 'date' command so that this old code can be removed.
configs/mx28evk_defconfig | 1 - configs/mx51evk_defconfig | 1 - 2 files changed, 2 deletions(-)
diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 1fe68ef93f9..dddb57efd3e 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -32,7 +32,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index e5178fb3d6b..5932a15a33d 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -31,7 +31,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y
Hello Simon,
Thanks!
bye, Heiko
configs/MPC837XERDB_defconfig | 1 - configs/ethernut5_defconfig | 1 - configs/work_92105_defconfig | 1 - 3 files changed, 3 deletions(-)
diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index 9eac43a0fcb..dd30e8d30da 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -139,7 +139,6 @@ CONFIG_CMD_USB=y CONFIG_BOOTP_BOOTFILESIZE=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index cc2f567c8a8..004f1866162 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -46,7 +46,6 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_DNS=y CONFIG_CMD_BSP=y CONFIG_CMD_CACHE=y -CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 4b73e1551ce..e7da0de5df1 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -47,7 +47,6 @@ CONFIG_CMD_NAND=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y
Hello Simon,
Thanks!
bye, Heiko
This option is very old and the migration deadline was years ago. Drop it so that the I2C system can be simplified.
README | 5 ----- cmd/date.c | 6 ------ include/configs/ls1028aqds.h | 1 - include/configs/ls1028ardb.h | 2 -- include/configs/ls1046afrwy.h | 1 - include/configs/lx2160aqds.h | 3 --- include/configs/lx2160ardb.h | 3 --- include/configs/lx2162aqds.h | 3 --- include/configs/m53menlo.h | 2 -- include/configs/tqma6_wru4.h | 1 - include/i2c.h | 5 ----- 11 files changed, 32 deletions(-)
diff --git a/README b/README index c3821c5ce4e..37c959cc9c2 100644 --- a/README +++ b/README @@ -893,11 +893,6 @@ The following options need to be configured:
will skip addresses 0x50 and 0x68 on a board with one I2C bus
- CFG_SYS_RTC_BUS_NUM - - If defined, then this indicates the I2C bus number for the RTC. - If not defined, then U-Boot assumes that RTC is on I2C bus 0. - CONFIG_SOFT_I2C_READ_REPEATED_START
defining this will force the i2c_read() function in diff --git a/cmd/date.c b/cmd/date.c index 755adec1e71..bdb3e199b43 100644 --- a/cmd/date.c +++ b/cmd/date.c @@ -42,12 +42,6 @@ static int do_date(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_FAILURE; } } -#elif CONFIG_IS_ENABLED(SYS_I2C_LEGACY) - old_bus = i2c_get_bus_num(); - i2c_set_bus_num(CFG_SYS_RTC_BUS_NUM); -#else - old_bus = I2C_GET_BUS(); - I2C_SET_BUS(CFG_SYS_RTC_BUS_NUM); #endif
switch (argc) { diff --git a/include/configs/ls1028aqds.h b/include/configs/ls1028aqds.h index 769ece901c1..ed93b51d808 100644 --- a/include/configs/ls1028aqds.h +++ b/include/configs/ls1028aqds.h @@ -47,7 +47,6 @@ #endif
/* RTC */ -#define CFG_SYS_RTC_BUS_NUM 1 #define I2C_MUX_CH_RTC 0xB
/* Store environment at top of flash */ diff --git a/include/configs/ls1028ardb.h b/include/configs/ls1028ardb.h index 0f591e3c4ab..d44ce45fd6b 100644 --- a/include/configs/ls1028ardb.h +++ b/include/configs/ls1028ardb.h @@ -10,8 +10,6 @@
#define COUNTER_FREQUENCY_REAL (get_board_sys_clk() / 4)
-#define CFG_SYS_RTC_BUS_NUM 0 - /* Store environment at top of flash */
/* diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h index 5e03a962d10..21804fc6654 100644 --- a/include/configs/ls1046afrwy.h +++ b/include/configs/ls1046afrwy.h @@ -66,7 +66,6 @@
/* RTC */ #define CFG_SYS_I2C_RTC_ADDR 0x51 /* Channel 0 I2C bus 0*/ -#define CFG_SYS_RTC_BUS_NUM 0
/* * Environment diff --git a/include/configs/lx2160aqds.h b/include/configs/lx2160aqds.h index 3a316e73308..5b397e23d89 100644 --- a/include/configs/lx2160aqds.h +++ b/include/configs/lx2160aqds.h @@ -8,9 +8,6 @@
#include "lx2160a_common.h"
-/* RTC */ -#define CFG_SYS_RTC_BUS_NUM 0 - /* MAC/PHY configuration */
/* Initial environment variables */ diff --git a/include/configs/lx2160ardb.h b/include/configs/lx2160ardb.h index 6404b359111..e700a7b1135 100644 --- a/include/configs/lx2160ardb.h +++ b/include/configs/lx2160ardb.h @@ -8,9 +8,6 @@
-/* RTC */ -#define CFG_SYS_RTC_BUS_NUM 4 - #if defined(CONFIG_FSL_MC_ENET) #define AQR113C_PHY_ADDR1 0x0 #define AQR113C_PHY_ADDR2 0x08 diff --git a/include/configs/lx2162aqds.h b/include/configs/lx2162aqds.h index 54d7cea4c59..2d0db47b334 100644 --- a/include/configs/lx2162aqds.h +++ b/include/configs/lx2162aqds.h @@ -10,9 +10,6 @@
/* USB */
-/* RTC */ -#define CFG_SYS_RTC_BUS_NUM 0 - /* Initial environment variables */ #define CFG_EXTRA_ENV_SETTINGS \ EXTRA_ENV_SETTINGS \ diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 9cf46b2c362..c245cbe427b 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -57,8 +57,6 @@ #define CFG_FEC_MXC_PHYADDR 0x0 #endif
-#define CFG_SYS_RTC_BUS_NUM 1 /* I2C2 */ - /* * RTC */ diff --git a/include/configs/tqma6_wru4.h b/include/configs/tqma6_wru4.h index e06fc7fe155..5e21463305a 100644 --- a/include/configs/tqma6_wru4.h +++ b/include/configs/tqma6_wru4.h @@ -16,7 +16,6 @@ /* Watchdog */
/* Config on-board RTC */ -#define CFG_SYS_RTC_BUS_NUM 2 #define CFG_SYS_I2C_RTC_ADDR 0x68 /* Turn off RTC square-wave output to save battery */
diff --git a/include/i2c.h b/include/i2c.h index 622540c8265..45ca3d63e3f 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -655,11 +655,6 @@ void i2c_early_init_f(void); #undef CFG_SYS_I2C_DIRECT_BUS #endif
-/* define the I2C bus number for RTC and DTT if not already done */ -#if !defined(CFG_SYS_RTC_BUS_NUM) -#define CFG_SYS_RTC_BUS_NUM 0 -#endif - struct i2c_adapter { void (*init)(struct i2c_adapter *adap, int speed, int slaveaddr);
Hello Simon,
Thanks!
bye, Heiko
Drop two generations of old code in this command. All boards should use driver model for I2C from 2021.
cmd/date.c | 26 -------------------------- 1 file changed, 26 deletions(-)
diff --git a/cmd/date.c b/cmd/date.c index bdb3e199b43..8614f022761 100644 --- a/cmd/date.c +++ b/cmd/date.c @@ -31,7 +31,6 @@ static int do_date(struct cmd_tbl *cmdtp, int flag, int argc, int old_bus __maybe_unused;
/* switch to correct I2C bus */ -#ifdef CONFIG_DM_RTC struct udevice *dev;
rcode = uclass_get_device_by_seq(UCLASS_RTC, 0, &dev); @@ -42,29 +41,19 @@ static int do_date(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_FAILURE; } } -#endif
switch (argc) { case 2: /* set date & time */ if (strcmp(argv[1],"reset") == 0) { puts ("Reset RTC...\n"); -#ifdef CONFIG_DM_RTC rcode = dm_rtc_reset(dev); if (!rcode) rcode = dm_rtc_set(dev, &default_tm); -#else - rtc_reset(); - rcode = rtc_set(&default_tm); -#endif if (rcode) puts("## Failed to set date after RTC reset\n"); } else { /* initialize tm with current time */ -#ifdef CONFIG_DM_RTC rcode = dm_rtc_get(dev, &tm); -#else - rcode = rtc_get(&tm); -#endif if (!rcode) { /* insert new date & time */ if (mk_date(argv[1], &tm) != 0) { @@ -72,11 +61,7 @@ static int do_date(struct cmd_tbl *cmdtp, int flag, int argc, break; } /* and write to RTC */ -#ifdef CONFIG_DM_RTC rcode = dm_rtc_set(dev, &tm); -#else - rcode = rtc_set(&tm); -#endif if (rcode) { printf("## Set date failed: err=%d\n", rcode); @@ -87,11 +72,7 @@ static int do_date(struct cmd_tbl *cmdtp, int flag, int argc, } fallthrough; case 1: /* get date & time */ -#ifdef CONFIG_DM_RTC rcode = dm_rtc_get(dev, &tm); -#else - rcode = rtc_get(&tm); -#endif if (rcode) { puts("## Get date failed\n"); break; @@ -108,13 +89,6 @@ static int do_date(struct cmd_tbl *cmdtp, int flag, int argc, rcode = CMD_RET_USAGE; }
- /* switch back to original I2C bus */ -#if CONFIG_IS_ENABLED(SYS_I2C_LEGACY) - i2c_set_bus_num(old_bus); -#elif !defined(CONFIG_DM_RTC) - I2C_SET_BUS(old_bus); -#endif - return rcode ? CMD_RET_FAILURE : 0; }
Hello Simon,
Thanks!
bye, Heiko
Drop some old code from the mxc_i2c and ddr/fsl drivers. This will allow removal of very old common I2C code.
Changes in v2: - Leave pg_wcom alone as its boards were converted
drivers/ddr/fsl/main.c | 3 +-- drivers/i2c/mxc_i2c.c | 1 + 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/ddr/fsl/main.c b/drivers/ddr/fsl/main.c index 31091bb4495..888dfb7ff33 100644 --- a/drivers/ddr/fsl/main.c +++ b/drivers/ddr/fsl/main.c @@ -111,7 +111,7 @@ static int ddr_i2c_read(DEV_TYPE *dev, unsigned int addr, #if CONFIG_IS_ENABLED(DM_I2C) ret = dm_i2c_read(dev, 0, buf, len); #else - ret = i2c_read(dev->chip, addr, alen, buf, len); + ret = 0; #endif
return ret; @@ -162,7 +162,6 @@ static void __get_spd(generic_spd_eeprom_t *spd, u8 i2c_address) }; dev = &ldev;
- i2c_set_bus_num(CONFIG_SYS_SPD_BUS_NUM); #endif
#ifdef CONFIG_SYS_FSL_DDR4 diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 84c0050eac0..2f3cb5908c9 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -620,6 +620,7 @@ int enable_i2c_clk(unsigned char enable, unsigned int i2c_num) __attribute__((weak, alias("__enable_i2c_clk")));
#if !CONFIG_IS_ENABLED(DM_I2C) + /* * Read data from I2C device *
Hello Simon,
Changes in v2:
Thanks!
bye, Heiko
This is not now used by any boards, so drop it.
doc/I2C_Edge_Conditions | 10 ++++------ drivers/i2c/soft_i2c.c | 11 ----------- 2 files changed, 4 insertions(+), 17 deletions(-)
diff --git a/doc/I2C_Edge_Conditions b/doc/I2C_Edge_Conditions index f4a99687011..9ccb21c5092 100644 --- a/doc/I2C_Edge_Conditions +++ b/doc/I2C_Edge_Conditions @@ -31,12 +31,10 @@ Notes !!!THIS IS AN UNDOCUMENTED I2C BUS BUG, NOT A AMCC 4xx BUG!!!
This reset edge condition could possibly be present in every I2C -controller and device available. For boards where a I2C bus reset -function can be implemented a i2c_init_board() function should be -provided and enabled by #define'ing CONFIG_SYS_I2C_INIT_BOARD in your -board's config file. Note that this is NOT necessary when using the -bit-banging I2C driver (common/soft_i2c.c) as this already includes -the I2C bus reset sequence. +controller and device available. + +Note that this problem does not happen when using the bit-banging I2C driver +(common/soft_i2c.c) as this already includes the I2C bus reset sequence.
Many thanks to Bill Hunter for finding this serious BUG. diff --git a/drivers/i2c/soft_i2c.c b/drivers/i2c/soft_i2c.c index 89ddf821063..79f7a320502 100644 --- a/drivers/i2c/soft_i2c.c +++ b/drivers/i2c/soft_i2c.c @@ -107,16 +107,13 @@ DECLARE_GLOBAL_DATA_PTR; /*----------------------------------------------------------------------- * Local functions */ -#if !defined(CONFIG_SYS_I2C_INIT_BOARD) static void send_reset (void); -#endif static void send_start (void); static void send_stop (void); static void send_ack (int); static int write_byte (uchar byte); static uchar read_byte (int);
-#if !defined(CONFIG_SYS_I2C_INIT_BOARD) /*----------------------------------------------------------------------- * Send a reset sequence consisting of 9 clocks with the data signal high * to clock any confused device back into an idle state. Also send a @@ -144,7 +141,6 @@ static void send_reset(void) send_stop(); I2C_TRISTATE; } -#endif
/*----------------------------------------------------------------------- * START: High -> Low on SDA while SCL is High @@ -277,12 +273,6 @@ static uchar read_byte(int ack) */ static void soft_i2c_init(struct i2c_adapter *adap, int speed, int slaveaddr) { -#if defined(CONFIG_SYS_I2C_INIT_BOARD) - /* call board specific i2c bus reset routine before accessing the */ - /* environment, which might be in a chip on that bus. For details */ - /* about this problem see doc/I2C_Edge_Conditions. */ - i2c_init_board(); -#else /* * WARNING: Do NOT save speed in a static variable: if the * I2C routines are called before RAM is initialized (to read @@ -290,7 +280,6 @@ static void soft_i2c_init(struct i2c_adapter *adap, int speed, int slaveaddr) * system will crash. */ send_reset (); -#endif }
Hello Simon,
Thanks!
bye, Heiko
This option is not defined by any board, so drop the code.
arch/mips/mach-octeon/octeon_fdt.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/arch/mips/mach-octeon/octeon_fdt.c b/arch/mips/mach-octeon/octeon_fdt.c index c74fe9d9fb8..15ce292be95 100644 --- a/arch/mips/mach-octeon/octeon_fdt.c +++ b/arch/mips/mach-octeon/octeon_fdt.c @@ -687,13 +687,6 @@ int octeon_fdt_i2c_get_bus(const void *fdt, int node_offset) while (node_offset > 0 && !(found = !fdt_node_check_compatible(fdt, node_offset, compat))) { node_offset = fdt_parent_offset(fdt, node_offset); -#ifdef CONFIG_OCTEON_I2C_FDT - bus = i2c_get_bus_num_fdt(node_offset); - if (bus >= 0) { - debug("%s: Found bus 0x%x\n", __func__, bus); - return bus; - } -#endif } if (!found) { printf("Error: node %d in device tree is not a child of the I2C bus\n",
Hello Simon,
Thanks!
bye, Heiko
This is very old, predating even the legacy I2C support, so drop it.
drivers/power/power_i2c.c | 5 ----- include/i2c.h | 7 ------- 2 files changed, 12 deletions(-)
diff --git a/drivers/power/power_i2c.c b/drivers/power/power_i2c.c index a871fc41987..c2fc1c6b42f 100644 --- a/drivers/power/power_i2c.c +++ b/drivers/power/power_i2c.c @@ -33,8 +33,6 @@ int pmic_reg_write(struct pmic *p, u32 reg, u32 val) p->bus); return -ENXIO; } -#else /* Non DM I2C support - will be removed */ - I2C_SET_BUS(p->bus); #endif
switch (pmic_i2c_tx_num) { @@ -93,9 +91,6 @@ int pmic_reg_read(struct pmic *p, u32 reg, u32 *val) return -ENXIO; } ret = dm_i2c_read(dev, reg, buf, pmic_i2c_tx_num); -#else /* Non DM I2C support - will be removed */ - I2C_SET_BUS(p->bus); - ret = i2c_read(pmic_i2c_addr, reg, 1, buf, pmic_i2c_tx_num); #endif if (ret) return ret; diff --git a/include/i2c.h b/include/i2c.h index 45ca3d63e3f..1d1430b74a6 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -954,13 +954,6 @@ static inline unsigned int I2C_GET_BUS(void) return I2C_MULTI_BUS ? i2c_get_bus_num() : 0; }
-static inline void I2C_SET_BUS(unsigned int bus) __attribute__((always_inline)); -static inline void I2C_SET_BUS(unsigned int bus) -{ - if (I2C_MULTI_BUS) - i2c_set_bus_num(bus); -} - /** * Find the I2C bus number by given a FDT I2C node. *
Hello Simon,
Thanks!
bye, Heiko
include/i2c.h | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/include/i2c.h b/include/i2c.h index 1d1430b74a6..b6727bb2a73 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -947,13 +947,6 @@ unsigned int i2c_get_bus_speed(void); # define I2C_MULTI_BUS 0 #endif
-/* NOTE: These two functions MUST be always_inline to avoid code growth! */ -static inline unsigned int I2C_GET_BUS(void) __attribute__((always_inline)); -static inline unsigned int I2C_GET_BUS(void) -{ - return I2C_MULTI_BUS ? i2c_get_bus_num() : 0; -} - /** * Find the I2C bus number by given a FDT I2C node. *
Hello Simon,
Thanks!
bye, Heiko
Only one board uses this option and it is very old. Let's drop it.
include/configs/ethernut5.h | 3 --- include/i2c.h | 14 -------------- 2 files changed, 17 deletions(-)
diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 807c6963192..c327bbbe07d 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -59,9 +59,6 @@ #define CFG_SYS_I2C_RTC_ADDR 0x51 #endif
-/* I2C */ -#define CFG_SYS_MAX_I2C_BUS 1 - #define I2C_SOFT_DECLARATIONS
#define GPIO_I2C_SCL AT91_PIO_PORTA, 24 diff --git a/include/i2c.h b/include/i2c.h index b6727bb2a73..282f3cd700f 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -933,20 +933,6 @@ int i2c_set_bus_speed(unsigned int); unsigned int i2c_get_bus_speed(void); #endif /* CONFIG_SYS_I2C_LEGACY */
-/* - * only for backwardcompatibility, should go away if we switched - * completely to new multibus support. - */ -#if CONFIG_IS_ENABLED(SYS_I2C_LEGACY) -# if !defined(CFG_SYS_MAX_I2C_BUS) -# define CFG_SYS_MAX_I2C_BUS 2 -# endif -# define I2C_MULTI_BUS 1 -#else -# define CFG_SYS_MAX_I2C_BUS 1 -# define I2C_MULTI_BUS 0 -#endif - /** * Find the I2C bus number by given a FDT I2C node. *
Hello Simon,
Thanks!
bye, Heiko
These functions are 11 years old and are only used by one board. Drop them.
include/i2c.h | 18 ------------------ 1 file changed, 18 deletions(-)
diff --git a/include/i2c.h b/include/i2c.h index 282f3cd700f..f468b52cd7b 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -933,24 +933,6 @@ int i2c_set_bus_speed(unsigned int); unsigned int i2c_get_bus_speed(void); #endif /* CONFIG_SYS_I2C_LEGACY */
-/** - * Find the I2C bus number by given a FDT I2C node. - * - * @param blob Device tree blbo - * @param node FDT I2C node to find - * Return: the number of I2C bus (zero based), or -1 on error - */ -int i2c_get_bus_num_fdt(int node); - -/** - * Reset the I2C bus represented by the given a FDT I2C node. - * - * @param blob Device tree blbo - * @param node FDT I2C node to find - * Return: 0 if port was reset, -1 if not found - */ -int i2c_reset_port_fdt(const void *blob, int node); - #endif /* !CONFIG_DM_I2C */
#endif /* _I2C_H_ */
Hello Simon,
Thanks!
bye, Heiko
Now that this is always 0, remove it and the associated dead code.
README | 10 +--------- cmd/i2c.c | 23 ----------------------- drivers/i2c/i2c_core.c | 37 ------------------------------------- include/i2c.h | 7 ------- 4 files changed, 1 insertion(+), 76 deletions(-)
diff --git a/README b/README index 37c959cc9c2..4ffa4b8b68c 100644 --- a/README +++ b/README @@ -773,19 +773,11 @@ The following options need to be configured:
CFG_SYS_I2C_DIRECT_BUS define this, if you don't use i2c muxes on your hardware. - if CFG_SYS_I2C_MAX_HOPS is not defined or == 0 you can - omit this define. - - CFG_SYS_I2C_MAX_HOPS - define how many muxes are maximal consecutively connected - on one i2c bus. If you not use i2c muxes, omit this - define.
CFG_SYS_I2C_BUSES hold a list of buses you want to use, only used if CFG_SYS_I2C_DIRECT_BUS is not defined, for example - a board with CFG_SYS_I2C_MAX_HOPS = 1 and - CFG_SYS_NUM_I2C_BUSES = 9: + a board with CFG_SYS_NUM_I2C_BUSES = 9:
CFG_SYS_I2C_BUSES {{0, {I2C_NULL_HOP}}, \ {0, {{I2C_MUX_PCA9547, 0x70, 1}}}, \ diff --git a/cmd/i2c.c b/cmd/i2c.c index 7dac0a9fb6c..7246c4fa3e7 100644 --- a/cmd/i2c.c +++ b/cmd/i2c.c @@ -1698,18 +1698,6 @@ static int do_i2c_show_bus(struct cmd_tbl *cmdtp, int flag, int argc,
for (i = 0; i < CFG_SYS_NUM_I2C_BUSES; i++) { printf("Bus %d:\t%s", i, I2C_ADAP_NR(i)->name); -#ifndef CFG_SYS_I2C_DIRECT_BUS - int j; - - for (j = 0; j < CFG_SYS_I2C_MAX_HOPS; j++) { - if (i2c_bus[i].next_hop[j].chip == 0) - break; - printf("->%s@0x%2x:%d", - i2c_bus[i].next_hop[j].mux.name, - i2c_bus[i].next_hop[j].chip, - i2c_bus[i].next_hop[j].channel); - } -#endif printf("\n"); } #endif @@ -1734,17 +1722,6 @@ static int do_i2c_show_bus(struct cmd_tbl *cmdtp, int flag, int argc, return -1; } printf("Bus %d:\t%s", i, I2C_ADAP_NR(i)->name); -#ifndef CFG_SYS_I2C_DIRECT_BUS - int j; - for (j = 0; j < CFG_SYS_I2C_MAX_HOPS; j++) { - if (i2c_bus[i].next_hop[j].chip == 0) - break; - printf("->%s@0x%2x:%d", - i2c_bus[i].next_hop[j].mux.name, - i2c_bus[i].next_hop[j].chip, - i2c_bus[i].next_hop[j].channel); - } -#endif printf("\n"); #endif } diff --git a/drivers/i2c/i2c_core.c b/drivers/i2c/i2c_core.c index 7c43a5546d3..f371d952af5 100644 --- a/drivers/i2c/i2c_core.c +++ b/drivers/i2c/i2c_core.c @@ -111,23 +111,6 @@ static int i2c_mux_set_all(void) struct i2c_bus_hose *i2c_bus_tmp = &i2c_bus[I2C_BUS]; int i;
- /* Connect requested bus if behind muxes */ - if (i2c_bus_tmp->next_hop[0].chip != 0) { - /* Set all muxes along the path to that bus */ - for (i = 0; i < CFG_SYS_I2C_MAX_HOPS; i++) { - int ret; - - if (i2c_bus_tmp->next_hop[i].chip == 0) - break; - - ret = i2c_mux_set(I2C_ADAP, - i2c_bus_tmp->next_hop[i].mux.id, - i2c_bus_tmp->next_hop[i].chip, - i2c_bus_tmp->next_hop[i].channel); - if (ret != 0) - return ret; - } - } return 0; }
@@ -140,26 +123,6 @@ static int i2c_mux_disconnect_all(void) if (I2C_ADAP->init_done == 0) return 0;
- /* Disconnect current bus (turn off muxes if any) */ - if ((i2c_bus_tmp->next_hop[0].chip != 0) && - (I2C_ADAP->init_done != 0)) { - i = CFG_SYS_I2C_MAX_HOPS; - do { - uint8_t chip; - int ret; - - chip = i2c_bus_tmp->next_hop[--i].chip; - if (chip == 0) - continue; - - ret = I2C_ADAP->write(I2C_ADAP, chip, 0, 0, &buf, 1); - if (ret != 0) { - printf("i2c: mux disconnect error\n"); - return ret; - } - } while (i > 0); - } - return 0; } #endif diff --git a/include/i2c.h b/include/i2c.h index f468b52cd7b..180b71f1451 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -645,15 +645,9 @@ void i2c_early_init_f(void); */ #define I2C_RXTX_LEN 128 /* maximum tx/rx buffer length */
-#if !defined(CFG_SYS_I2C_MAX_HOPS) /* no muxes used bus = i2c adapters */ #define CFG_SYS_I2C_DIRECT_BUS 1 -#define CFG_SYS_I2C_MAX_HOPS 0 #define CFG_SYS_NUM_I2C_BUSES ll_entry_count(struct i2c_adapter, i2c) -#else -/* we use i2c muxes */ -#undef CFG_SYS_I2C_DIRECT_BUS -#endif
struct i2c_adapter { void (*init)(struct i2c_adapter *adap, int speed, @@ -712,7 +706,6 @@ struct i2c_next_hop {
struct i2c_bus_hose { int adapter; - struct i2c_next_hop next_hop[CFG_SYS_I2C_MAX_HOPS]; }; #define I2C_NULL_HOP {{-1, ""}, 0, 0} extern struct i2c_bus_hose i2c_bus[];
Hello Simon.
Thanks!
bye, Heiko
Now that this is always 1, remove it and the associated dead code.
Changes in v2: - Drop patch "pg-wcom: Drop CFG_SYS_I2C_MAX_HOPS"
README | 7 +-- drivers/i2c/i2c_core.c | 104 ----------------------------------------- include/i2c.h | 35 -------------- 3 files changed, 1 insertion(+), 145 deletions(-)
diff --git a/README b/README index 4ffa4b8b68c..4be1e8c22a0 100644 --- a/README +++ b/README @@ -771,13 +771,8 @@ The following options need to be configured: CFG_SYS_NUM_I2C_BUSES Hold the number of i2c buses you want to use.
- CFG_SYS_I2C_DIRECT_BUS - define this, if you don't use i2c muxes on your hardware. - CFG_SYS_I2C_BUSES - hold a list of buses you want to use, only used if - CFG_SYS_I2C_DIRECT_BUS is not defined, for example - a board with CFG_SYS_NUM_I2C_BUSES = 9: + hold a list of buses you want to use
CFG_SYS_I2C_BUSES {{0, {I2C_NULL_HOP}}, \ {0, {{I2C_MUX_PCA9547, 0x70, 1}}}, \ diff --git a/drivers/i2c/i2c_core.c b/drivers/i2c/i2c_core.c index f371d952af5..cccd45027db 100644 --- a/drivers/i2c/i2c_core.c +++ b/drivers/i2c/i2c_core.c @@ -33,100 +33,8 @@ struct i2c_adapter *i2c_get_adapter(int index) return i2c_adap_p; }
-#if !defined(CFG_SYS_I2C_DIRECT_BUS) -struct i2c_bus_hose i2c_bus[CFG_SYS_NUM_I2C_BUSES] = - CFG_SYS_I2C_BUSES; -#endif - DECLARE_GLOBAL_DATA_PTR;
-#ifndef CFG_SYS_I2C_DIRECT_BUS -/* - * i2c_mux_set() - * ------------- - * - * This turns on the given channel on I2C multiplexer chip connected to - * a given I2C adapter directly or via other multiplexers. In the latter - * case the entire multiplexer chain must be initialized first starting - * with the one connected directly to the adapter. When disabling a chain - * muxes must be programmed in reverse order, starting with the one - * farthest from the adapter. - * - * mux_id is the multiplexer chip type from defined in i2c.h. So far only - * NXP (Philips) PCA954x multiplexers are supported. Switches are NOT - * supported (anybody uses them?) - */ - -static int i2c_mux_set(struct i2c_adapter *adap, int mux_id, int chip, - int channel) -{ - uint8_t buf; - int ret; - - /* channel < 0 - turn off the mux */ - if (channel < 0) { - buf = 0; - ret = adap->write(adap, chip, 0, 0, &buf, 1); - if (ret) - printf("%s: Could not turn off the mux.\n", __func__); - return ret; - } - - switch (mux_id) { - case I2C_MUX_PCA9540_ID: - case I2C_MUX_PCA9542_ID: - if (channel > 1) - return -1; - buf = (uint8_t)((channel & 0x01) | (1 << 2)); - break; - case I2C_MUX_PCA9544_ID: - if (channel > 3) - return -1; - buf = (uint8_t)((channel & 0x03) | (1 << 2)); - break; - case I2C_MUX_PCA9547_ID: - if (channel > 7) - return -1; - buf = (uint8_t)((channel & 0x07) | (1 << 3)); - break; - case I2C_MUX_PCA9548_ID: - if (channel > 7) - return -1; - buf = (uint8_t)(0x01 << channel); - break; - default: - printf("%s: wrong mux id: %d\n", __func__, mux_id); - return -1; - } - - ret = adap->write(adap, chip, 0, 0, &buf, 1); - if (ret) - printf("%s: could not set mux: id: %d chip: %x channel: %d\n", - __func__, mux_id, chip, channel); - return ret; -} - -static int i2c_mux_set_all(void) -{ - struct i2c_bus_hose *i2c_bus_tmp = &i2c_bus[I2C_BUS]; - int i; - - return 0; -} - -static int i2c_mux_disconnect_all(void) -{ - struct i2c_bus_hose *i2c_bus_tmp = &i2c_bus[I2C_BUS]; - int i; - uint8_t buf = 0; - - if (I2C_ADAP->init_done == 0) - return 0; - - return 0; -} -#endif - /* * i2c_init_bus(): * --------------- @@ -200,11 +108,6 @@ int i2c_set_bus_num(unsigned int bus) if ((bus == I2C_BUS) && (I2C_ADAP->init_done > 0)) return 0;
-#ifndef CFG_SYS_I2C_DIRECT_BUS - if (bus >= CFG_SYS_NUM_I2C_BUSES) - return -1; -#endif - max = ll_entry_count(struct i2c_adapter, i2c); if (I2C_ADAPTER(bus) >= max) { printf("Error, wrong i2c adapter %d max %d possible\n", @@ -212,17 +115,10 @@ int i2c_set_bus_num(unsigned int bus) return -2; }
-#ifndef CFG_SYS_I2C_DIRECT_BUS - i2c_mux_disconnect_all(); -#endif - gd->cur_i2c_bus = bus; if (I2C_ADAP->init_done == 0) i2c_init_bus(bus, I2C_ADAP->speed, I2C_ADAP->slaveaddr);
-#ifndef CFG_SYS_I2C_DIRECT_BUS - i2c_mux_set_all(); -#endif return 0; }
diff --git a/include/i2c.h b/include/i2c.h index 180b71f1451..91917f54be9 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -646,7 +646,6 @@ void i2c_early_init_f(void); #define I2C_RXTX_LEN 128 /* maximum tx/rx buffer length */
/* no muxes used bus = i2c adapters */ -#define CFG_SYS_I2C_DIRECT_BUS 1 #define CFG_SYS_NUM_I2C_BUSES ll_entry_count(struct i2c_adapter, i2c)
struct i2c_adapter { @@ -692,47 +691,13 @@ struct i2c_adapter {
struct i2c_adapter *i2c_get_adapter(int index);
-#ifndef CFG_SYS_I2C_DIRECT_BUS -struct i2c_mux { - int id; - char name[16]; -}; - -struct i2c_next_hop { - struct i2c_mux mux; - uint8_t chip; - uint8_t channel; -}; - -struct i2c_bus_hose { - int adapter; -}; -#define I2C_NULL_HOP {{-1, ""}, 0, 0} -extern struct i2c_bus_hose i2c_bus[]; - -#define I2C_ADAPTER(bus) i2c_bus[bus].adapter -#else #define I2C_ADAPTER(bus) bus -#endif #define I2C_BUS gd->cur_i2c_bus
#define I2C_ADAP_NR(bus) i2c_get_adapter(I2C_ADAPTER(bus)) #define I2C_ADAP I2C_ADAP_NR(gd->cur_i2c_bus) #define I2C_ADAP_HWNR (I2C_ADAP->hwadapnr)
-#ifndef CFG_SYS_I2C_DIRECT_BUS -#define I2C_MUX_PCA9540_ID 1 -#define I2C_MUX_PCA9540 {I2C_MUX_PCA9540_ID, "PCA9540B"} -#define I2C_MUX_PCA9542_ID 2 -#define I2C_MUX_PCA9542 {I2C_MUX_PCA9542_ID, "PCA9542A"} -#define I2C_MUX_PCA9544_ID 3 -#define I2C_MUX_PCA9544 {I2C_MUX_PCA9544_ID, "PCA9544A"} -#define I2C_MUX_PCA9547_ID 4 -#define I2C_MUX_PCA9547 {I2C_MUX_PCA9547_ID, "PCA9547A"} -#define I2C_MUX_PCA9548_ID 5 -#define I2C_MUX_PCA9548 {I2C_MUX_PCA9548_ID, "PCA9548"} -#endif - #ifndef I2C_SOFT_DECLARATIONS # if (defined(CONFIG_AT91RM9200) || \ defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9261) || \
Hello Simon,
Changes in v2:
Thanks!
bye, HEiko
Hello Simon,
Changes in v2:
Many thanks for this work. Applied them locally base on origin/next and started azure build:
https://dev.azure.com/hs0298/hs/_build/results?buildId=122&view=results
If all is fine, I sent pull request to Tom.
bye, Heiko
Heiko Schocher
