[U-Boot] pull request: u-boot-uniphier/master (2nd round)
Hi Tom,
Here is a pretty big series for UniPhier SoC changes. pinctrl drivers, various fixes, refactoring, new SoC/board support, etc.
Diff from the previous one: - fix memory over-run bug in a command to display boot-mode - sort pin-groups alphabetically in pinctrl drivers - Add one more patch to convert a license block to SPDX
The following changes since commit 8a5f6129d1450f5ff92a55cfcfd7b96ee019e303:
pinctrl: move dm_scan_fdt_node() out of pinctrl uclass (2015-09-19 15:42:15 -0600)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to a4bb44b027705f8c05fc525180cabaa3769247bb:
ARM: dts: uniphier: use SPDX-License-Identifier (2015-09-25 01:01:37 +0900)
---------------------------------------------------------------- Masahiro Yamada (33): pinctrl: uniphier: add UniPhier pinctrl core support pinctrl: uniphier: add UniPhier PH1-LD4 pinctrl driver pinctrl: uniphier: add UniPhier PH1-Pro4 pinctrl driver pinctrl: uniphier: add UniPhier PH1-sLD8 pinctrl driver pinctrl: uniphier: add UniPhier PH1-Pro5 pinctrl driver pinctrl: uniphier: add UniPhier ProXstream2 pinctrl driver pinctrl: uniphier: add UniPhier PH1-LD6b pinctrl driver ARM: uniphier: enable simple-bus driver for SPL ARM: uniphier: increase CONFIG_SYS_MALLOC_F_LEN to bind all nodes ARM: dts: uniphier: prepare device trees to use pinctrl in SPL ARM: uniphier: enable PINCTRL and SPL_PINCTRL ARM: uniphier: drop ad-hoc early pin-muxing settings ARM: uniphier: drop ad-hoc input enable settings ARM: uniphier: drop DCC micro support card support ARM: uniphier: enable setexpr command ARM: uniphier: change the external bus address mapping ARM: uniphier: remove ifdef CONFIG_{SOC} conditionals from sg-regs.h ARM: uniphier: parse device tree to determine DRAM base and size ARM: uniphier: remove unused header file ARM: uniphier: remove useless wrapper functions ARM: uniphier: refactor LED function ARM: uniphier: move CONFIG_SUPPORT_CARD_* macros to local file ARM: uniphier: allow to disable CONFIG_MICRO_SUPPORT_CARD ARM: uniphier: rename CONFIG_MACH_* to CONFIG_ARCH_UNIPHIER_* ARM: uniphier: delete unneeded input enable for low-level debug ARM: uniphier: fix glitch signal problem for low-level debug ARM: uniphier: unify low-level debug init code ARM: uniphier: remove kernel parameter settings from environment ARM: uniphier: allow to enable multiple SoCs ARM: uniphier: add PH1-Pro5 support ARM: uniphier: add ProXstream2 and PH1-LD6b support ARM: uniphier: fix init page table for ProXstream2/PH1-LD6b USB boot ARM: dts: uniphier: use SPDX-License-Identifier
arch/arm/dts/Makefile | 5 +- arch/arm/dts/uniphier-ph1-ld4-ref.dts | 16 ++- arch/arm/dts/uniphier-ph1-ld6b-ref.dts | 17 ++- arch/arm/dts/uniphier-ph1-pro4-ref.dts | 16 ++- arch/arm/dts/uniphier-ph1-pro5-4kbox.dts | 64 ++++++++++++ arch/arm/dts/uniphier-ph1-sld8-ref.dts | 16 ++- arch/arm/dts/uniphier-pinctrl.dtsi | 38 +------ arch/arm/dts/uniphier-proxstream2-gentil.dts | 62 +++++++++++ arch/arm/dts/uniphier-proxstream2-vodka.dts | 62 +++++++++++ arch/arm/mach-uniphier/Kconfig | 95 ++++++++--------- arch/arm/mach-uniphier/Makefile | 21 ++-- arch/arm/mach-uniphier/bcu/Makefile | 3 + arch/arm/mach-uniphier/{ph1-ld4/bcu_init.c => bcu/bcu-ph1-ld4.c} | 8 +- arch/arm/mach-uniphier/{ph1-sld3/bcu_init.c => bcu/bcu-ph1-sld3.c} | 8 +- arch/arm/mach-uniphier/board_common.c | 23 +--- arch/arm/mach-uniphier/board_early_init_f.c | 73 ++++++++++--- arch/arm/mach-uniphier/board_early_init_r.c | 7 +- arch/arm/mach-uniphier/boards.c | 130 +++++++++++++++++++++++ arch/arm/mach-uniphier/boot-mode/Makefile | 9 ++ .../{ph1-pro4/boot-mode.c => boot-mode/boot-mode-ph1-ld4.c} | 21 ++-- arch/arm/mach-uniphier/boot-mode/boot-mode-ph1-pro5.c | 75 +++++++++++++ .../{ph1-sld3/boot-mode.c => boot-mode/boot-mode-ph1-sld3.c} | 23 ++-- arch/arm/mach-uniphier/boot-mode/boot-mode-proxstream2.c | 75 +++++++++++++ arch/arm/mach-uniphier/boot-mode/boot-mode.c | 45 ++++++++ arch/arm/mach-uniphier/clk/Makefile | 7 ++ arch/arm/mach-uniphier/{ph1-ld4/clkrst_init.c => clk/clk-ph1-ld4.c} | 3 +- arch/arm/mach-uniphier/{ph1-pro4/clkrst_init.c => clk/clk-ph1-pro4.c} | 3 +- arch/arm/mach-uniphier/clk/clk-ph1-pro5.c | 44 ++++++++ arch/arm/mach-uniphier/clk/clk-proxstream2.c | 50 +++++++++ arch/arm/mach-uniphier/cmd_pinmon.c | 43 ++++++-- arch/arm/mach-uniphier/ddrphy/Makefile | 3 + .../arm/mach-uniphier/{ph1-ld4/ddrphy_init.c => ddrphy/ddrphy-ph1-ld4.c} | 4 +- .../mach-uniphier/{ph1-pro4/ddrphy_init.c => ddrphy/ddrphy-ph1-pro4.c} | 4 +- .../mach-uniphier/{ph1-sld8/ddrphy_init.c => ddrphy/ddrphy-ph1-sld8.c} | 4 +- arch/arm/mach-uniphier/{ddrphy_training.c => ddrphy/ddrphy-training.c} | 0 arch/arm/mach-uniphier/debug_ll.S | 185 +++++++++++++++++++++++++++++++++ arch/arm/mach-uniphier/dram_init.c | 51 ++++++++- arch/arm/mach-uniphier/early-clk/Makefile | 7 ++ .../{ph1-pro4/early_clkrst_init.c => early-clk/early-clk-ph1-ld4.c} | 5 +- arch/arm/mach-uniphier/early-clk/early-clk-ph1-pro5.c | 39 +++++++ arch/arm/mach-uniphier/early-clk/early-clk-proxstream2.c | 44 ++++++++ arch/arm/mach-uniphier/early-pinctrl/Makefile | 1 + arch/arm/mach-uniphier/early-pinctrl/early-pinctrl-ph1-sld3.c | 26 +++++ arch/arm/mach-uniphier/include/mach/board.h | 42 -------- arch/arm/mach-uniphier/include/mach/boot-device.h | 15 ++- arch/arm/mach-uniphier/include/mach/ddrphy-regs.h | 7 +- arch/arm/mach-uniphier/include/mach/debug-uart.S | 23 ---- arch/arm/mach-uniphier/include/mach/init.h | 99 ++++++++++++++++++ arch/arm/mach-uniphier/include/mach/led.h | 100 ------------------ arch/arm/mach-uniphier/include/mach/micro-support-card.h | 39 +++++++ arch/arm/mach-uniphier/include/mach/platdevice.h | 24 ----- arch/arm/mach-uniphier/include/mach/sc-regs.h | 25 ++++- arch/arm/mach-uniphier/include/mach/sg-regs.h | 50 +++++---- arch/arm/mach-uniphier/include/mach/soc_info.h | 63 +++++++++++ arch/arm/mach-uniphier/init/Makefile | 9 ++ arch/arm/mach-uniphier/init/init-ph1-ld4.c | 60 +++++++++++ arch/arm/mach-uniphier/init/init-ph1-pro4.c | 58 +++++++++++ arch/arm/mach-uniphier/init/init-ph1-pro5.c | 42 ++++++++ arch/arm/mach-uniphier/init/init-ph1-sld3.c | 53 ++++++++++ arch/arm/mach-uniphier/init/init-ph1-sld8.c | 60 +++++++++++ arch/arm/mach-uniphier/init/init-proxstream2.c | 41 ++++++++ arch/arm/mach-uniphier/init/init.c | 58 +++++++++++ arch/arm/mach-uniphier/init_page_table.S | 6 +- arch/arm/mach-uniphier/lowlevel_init.S | 3 +- arch/arm/mach-uniphier/memconf.c | 103 ------------------ arch/arm/mach-uniphier/memconf/Makefile | 4 + arch/arm/mach-uniphier/memconf/memconf-ph1-sld3.c | 59 +++++++++++ arch/arm/mach-uniphier/memconf/memconf-proxstream2.c | 64 ++++++++++++ arch/arm/mach-uniphier/memconf/memconf.c | 104 ++++++++++++++++++ arch/arm/mach-uniphier/{support_card.c => micro-support-card.c} | 169 +++++++++++++++--------------- arch/arm/mach-uniphier/ph1-ld4/Makefile | 15 --- arch/arm/mach-uniphier/ph1-ld4/boot-mode.c | 1 - arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c | 1 - arch/arm/mach-uniphier/ph1-ld4/early_pinctrl.c | 27 ----- arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S | 29 ------ arch/arm/mach-uniphier/ph1-ld4/pinctrl.c | 48 --------- arch/arm/mach-uniphier/ph1-ld4/pll_spectrum.c | 1 - arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c | 49 --------- arch/arm/mach-uniphier/ph1-ld4/sg_init.c | 18 ---- arch/arm/mach-uniphier/ph1-pro4/Makefile | 15 --- arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c | 26 ----- arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S | 39 ------- arch/arm/mach-uniphier/ph1-pro4/pinctrl.c | 49 --------- arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c | 42 -------- arch/arm/mach-uniphier/ph1-pro4/sg_init.c | 18 ---- arch/arm/mach-uniphier/ph1-sld3/Makefile | 15 --- arch/arm/mach-uniphier/ph1-sld3/clkrst_init.c | 1 - arch/arm/mach-uniphier/ph1-sld3/early_clkrst_init.c | 1 - arch/arm/mach-uniphier/ph1-sld3/early_pinctrl.c | 23 ---- arch/arm/mach-uniphier/ph1-sld3/lowlevel_debug.S | 33 ------ arch/arm/mach-uniphier/ph1-sld3/memconf.c | 52 --------- arch/arm/mach-uniphier/ph1-sld3/pinctrl.c | 24 ----- arch/arm/mach-uniphier/ph1-sld3/sbc_init_3cs.c | 37 ------- arch/arm/mach-uniphier/ph1-sld3/sg_init.c | 9 -- arch/arm/mach-uniphier/ph1-sld3/umc_init.c | 15 --- arch/arm/mach-uniphier/ph1-sld8/Makefile | 1 - arch/arm/mach-uniphier/ph1-sld8/bcu_init.c | 1 - arch/arm/mach-uniphier/ph1-sld8/boot-mode.c | 1 - arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c | 1 - arch/arm/mach-uniphier/ph1-sld8/early_clkrst_init.c | 1 - arch/arm/mach-uniphier/ph1-sld8/early_pinctrl.c | 27 ----- arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S | 29 ------ arch/arm/mach-uniphier/ph1-sld8/pinctrl.c | 51 --------- arch/arm/mach-uniphier/ph1-sld8/pll_spectrum.c | 1 - arch/arm/mach-uniphier/ph1-sld8/sbc_init.c | 1 - arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c | 57 ---------- arch/arm/mach-uniphier/ph1-sld8/sg_init.c | 1 - arch/arm/mach-uniphier/pinctrl/Makefile | 7 ++ arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-ld4.c | 49 +++++++++ arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-ld6b.c | 45 ++++++++ arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-pro4.c | 50 +++++++++ arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-pro5.c | 43 ++++++++ arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-sld3.c | 25 +++++ arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-sld8.c | 43 ++++++++ arch/arm/mach-uniphier/pinctrl/pinctrl-proxstream2.c | 45 ++++++++ arch/arm/mach-uniphier/pll/Makefile | 8 ++ arch/arm/mach-uniphier/{ph1-ld4/pll_init.c => pll/pll-init-ph1-ld4.c} | 34 ++++-- arch/arm/mach-uniphier/{ph1-pro4/pll_init.c => pll/pll-init-ph1-pro4.c} | 36 ++++--- arch/arm/mach-uniphier/{ph1-sld3/pll_init.c => pll/pll-init-ph1-sld3.c} | 5 +- arch/arm/mach-uniphier/{ph1-sld8/pll_init.c => pll/pll-init-ph1-sld8.c} | 5 +- .../{ph1-pro4/pll_spectrum.c => pll/pll-spectrum-ph1-ld4.c} | 6 +- .../{ph1-sld3/pll_spectrum.c => pll/pll-spectrum-ph1-sld3.c} | 5 +- arch/arm/mach-uniphier/print_misc_info.c | 2 +- arch/arm/mach-uniphier/sbc/Makefile | 7 ++ arch/arm/mach-uniphier/{ph1-ld4/sbc_init.c => sbc/sbc-ph1-ld4.c} | 17 +-- arch/arm/mach-uniphier/{ph1-pro4/sbc_init.c => sbc/sbc-ph1-pro4.c} | 17 +-- arch/arm/mach-uniphier/{ph1-sld3/sbc_init.c => sbc/sbc-ph1-sld3.c} | 19 ++-- arch/arm/mach-uniphier/sbc/sbc-proxstream2.c | 48 +++++++++ arch/arm/mach-uniphier/soc_info.c | 61 +++++++++++ arch/arm/mach-uniphier/spl.c | 76 -------------- arch/arm/mach-uniphier/umc/Makefile | 3 + arch/arm/mach-uniphier/{ph1-ld4/umc_init.c => umc/umc-ph1-ld4.c} | 30 +++--- arch/arm/mach-uniphier/{ph1-pro4/umc_init.c => umc/umc-ph1-pro4.c} | 36 ++++--- arch/arm/mach-uniphier/{ph1-sld8/umc_init.c => umc/umc-ph1-sld8.c} | 30 +++--- configs/ph1_ld4_defconfig | 9 +- configs/ph1_ld6b_defconfig | 30 ++++++ configs/ph1_pro4_defconfig | 8 +- configs/ph1_pro5_defconfig | 30 ++++++ configs/ph1_sld3_defconfig | 5 +- configs/ph1_sld8_defconfig | 9 +- doc/README.uniphier | 12 +++ drivers/pinctrl/Kconfig | 2 + drivers/pinctrl/Makefile | 2 + drivers/pinctrl/uniphier/Kconfig | 42 ++++++++ drivers/pinctrl/uniphier/Makefile | 8 ++ drivers/pinctrl/uniphier/pinctrl-ph1-ld4.c | 133 ++++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-ph1-ld6b.c | 133 ++++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-ph1-pro4.c | 130 +++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-ph1-pro5.c | 144 +++++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-ph1-sld8.c | 141 +++++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-proxstream2.c | 140 +++++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 154 +++++++++++++++++++++++++++ drivers/pinctrl/uniphier/pinctrl-uniphier.h | 113 ++++++++++++++++++++ include/configs/uniphier.h | 113 ++++---------------- 154 files changed, 4061 insertions(+), 1624 deletions(-) create mode 100644 arch/arm/dts/uniphier-ph1-pro5-4kbox.dts create mode 100644 arch/arm/dts/uniphier-proxstream2-gentil.dts create mode 100644 arch/arm/dts/uniphier-proxstream2-vodka.dts create mode 100644 arch/arm/mach-uniphier/bcu/Makefile rename arch/arm/mach-uniphier/{ph1-ld4/bcu_init.c => bcu/bcu-ph1-ld4.c} (84%) rename arch/arm/mach-uniphier/{ph1-sld3/bcu_init.c => bcu/bcu-ph1-sld3.c} (84%) create mode 100644 arch/arm/mach-uniphier/boards.c create mode 100644 arch/arm/mach-uniphier/boot-mode/Makefile rename arch/arm/mach-uniphier/{ph1-pro4/boot-mode.c => boot-mode/boot-mode-ph1-ld4.c} (88%) create mode 100644 arch/arm/mach-uniphier/boot-mode/boot-mode-ph1-pro5.c rename arch/arm/mach-uniphier/{ph1-sld3/boot-mode.c => boot-mode/boot-mode-ph1-sld3.c} (89%) create mode 100644 arch/arm/mach-uniphier/boot-mode/boot-mode-proxstream2.c create mode 100644 arch/arm/mach-uniphier/boot-mode/boot-mode.c create mode 100644 arch/arm/mach-uniphier/clk/Makefile rename arch/arm/mach-uniphier/{ph1-ld4/clkrst_init.c => clk/clk-ph1-ld4.c} (94%) rename arch/arm/mach-uniphier/{ph1-pro4/clkrst_init.c => clk/clk-ph1-pro4.c} (96%) create mode 100644 arch/arm/mach-uniphier/clk/clk-ph1-pro5.c create mode 100644 arch/arm/mach-uniphier/clk/clk-proxstream2.c create mode 100644 arch/arm/mach-uniphier/ddrphy/Makefile rename arch/arm/mach-uniphier/{ph1-ld4/ddrphy_init.c => ddrphy/ddrphy-ph1-ld4.c} (95%) rename arch/arm/mach-uniphier/{ph1-pro4/ddrphy_init.c => ddrphy/ddrphy-ph1-pro4.c} (95%) rename arch/arm/mach-uniphier/{ph1-sld8/ddrphy_init.c => ddrphy/ddrphy-ph1-sld8.c} (95%) rename arch/arm/mach-uniphier/{ddrphy_training.c => ddrphy/ddrphy-training.c} (100%) create mode 100644 arch/arm/mach-uniphier/debug_ll.S create mode 100644 arch/arm/mach-uniphier/early-clk/Makefile rename arch/arm/mach-uniphier/{ph1-pro4/early_clkrst_init.c => early-clk/early-clk-ph1-ld4.c} (86%) create mode 100644 arch/arm/mach-uniphier/early-clk/early-clk-ph1-pro5.c create mode 100644 arch/arm/mach-uniphier/early-clk/early-clk-proxstream2.c create mode 100644 arch/arm/mach-uniphier/early-pinctrl/Makefile create mode 100644 arch/arm/mach-uniphier/early-pinctrl/early-pinctrl-ph1-sld3.c delete mode 100644 arch/arm/mach-uniphier/include/mach/board.h delete mode 100644 arch/arm/mach-uniphier/include/mach/debug-uart.S create mode 100644 arch/arm/mach-uniphier/include/mach/init.h delete mode 100644 arch/arm/mach-uniphier/include/mach/led.h create mode 100644 arch/arm/mach-uniphier/include/mach/micro-support-card.h delete mode 100644 arch/arm/mach-uniphier/include/mach/platdevice.h create mode 100644 arch/arm/mach-uniphier/include/mach/soc_info.h create mode 100644 arch/arm/mach-uniphier/init/Makefile create mode 100644 arch/arm/mach-uniphier/init/init-ph1-ld4.c create mode 100644 arch/arm/mach-uniphier/init/init-ph1-pro4.c create mode 100644 arch/arm/mach-uniphier/init/init-ph1-pro5.c create mode 100644 arch/arm/mach-uniphier/init/init-ph1-sld3.c create mode 100644 arch/arm/mach-uniphier/init/init-ph1-sld8.c create mode 100644 arch/arm/mach-uniphier/init/init-proxstream2.c create mode 100644 arch/arm/mach-uniphier/init/init.c delete mode 100644 arch/arm/mach-uniphier/memconf.c create mode 100644 arch/arm/mach-uniphier/memconf/Makefile create mode 100644 arch/arm/mach-uniphier/memconf/memconf-ph1-sld3.c create mode 100644 arch/arm/mach-uniphier/memconf/memconf-proxstream2.c create mode 100644 arch/arm/mach-uniphier/memconf/memconf.c rename arch/arm/mach-uniphier/{support_card.c => micro-support-card.c} (53%) delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/Makefile delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/boot-mode.c delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/early_clkrst_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/early_pinctrl.c delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/lowlevel_debug.S delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/pinctrl.c delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/pll_spectrum.c delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/sbc_init_3cs.c delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/sg_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-pro4/Makefile delete mode 100644 arch/arm/mach-uniphier/ph1-pro4/early_pinctrl.c delete mode 100644 arch/arm/mach-uniphier/ph1-pro4/lowlevel_debug.S delete mode 100644 arch/arm/mach-uniphier/ph1-pro4/pinctrl.c delete mode 100644 arch/arm/mach-uniphier/ph1-pro4/sbc_init_3cs.c delete mode 100644 arch/arm/mach-uniphier/ph1-pro4/sg_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/Makefile delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/clkrst_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/early_clkrst_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/early_pinctrl.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/lowlevel_debug.S delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/memconf.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/pinctrl.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/sbc_init_3cs.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/sg_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/umc_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/Makefile delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/bcu_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/boot-mode.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/clkrst_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/early_clkrst_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/early_pinctrl.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/lowlevel_debug.S delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/pinctrl.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/pll_spectrum.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/sbc_init.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/sbc_init_3cs.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/sg_init.c create mode 100644 arch/arm/mach-uniphier/pinctrl/Makefile create mode 100644 arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-ld4.c create mode 100644 arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-ld6b.c create mode 100644 arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-pro4.c create mode 100644 arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-pro5.c create mode 100644 arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-sld3.c create mode 100644 arch/arm/mach-uniphier/pinctrl/pinctrl-ph1-sld8.c create mode 100644 arch/arm/mach-uniphier/pinctrl/pinctrl-proxstream2.c create mode 100644 arch/arm/mach-uniphier/pll/Makefile rename arch/arm/mach-uniphier/{ph1-ld4/pll_init.c => pll/pll-init-ph1-ld4.c} (90%) rename arch/arm/mach-uniphier/{ph1-pro4/pll_init.c => pll/pll-init-ph1-pro4.c} (88%) rename arch/arm/mach-uniphier/{ph1-sld3/pll_init.c => pll/pll-init-ph1-sld3.c} (62%) rename arch/arm/mach-uniphier/{ph1-sld8/pll_init.c => pll/pll-init-ph1-sld8.c} (97%) rename arch/arm/mach-uniphier/{ph1-pro4/pll_spectrum.c => pll/pll-spectrum-ph1-ld4.c} (72%) rename arch/arm/mach-uniphier/{ph1-sld3/pll_spectrum.c => pll/pll-spectrum-ph1-sld3.c} (73%) create mode 100644 arch/arm/mach-uniphier/sbc/Makefile rename arch/arm/mach-uniphier/{ph1-ld4/sbc_init.c => sbc/sbc-ph1-ld4.c} (67%) rename arch/arm/mach-uniphier/{ph1-pro4/sbc_init.c => sbc/sbc-ph1-pro4.c} (64%) rename arch/arm/mach-uniphier/{ph1-sld3/sbc_init.c => sbc/sbc-ph1-sld3.c} (62%) create mode 100644 arch/arm/mach-uniphier/sbc/sbc-proxstream2.c create mode 100644 arch/arm/mach-uniphier/soc_info.c delete mode 100644 arch/arm/mach-uniphier/spl.c create mode 100644 arch/arm/mach-uniphier/umc/Makefile rename arch/arm/mach-uniphier/{ph1-ld4/umc_init.c => umc/umc-ph1-ld4.c} (88%) rename arch/arm/mach-uniphier/{ph1-pro4/umc_init.c => umc/umc-ph1-pro4.c} (85%) rename arch/arm/mach-uniphier/{ph1-sld8/umc_init.c => umc/umc-ph1-sld8.c} (87%) create mode 100644 configs/ph1_ld6b_defconfig create mode 100644 configs/ph1_pro5_defconfig create mode 100644 drivers/pinctrl/uniphier/Kconfig create mode 100644 drivers/pinctrl/uniphier/Makefile create mode 100644 drivers/pinctrl/uniphier/pinctrl-ph1-ld4.c create mode 100644 drivers/pinctrl/uniphier/pinctrl-ph1-ld6b.c create mode 100644 drivers/pinctrl/uniphier/pinctrl-ph1-pro4.c create mode 100644 drivers/pinctrl/uniphier/pinctrl-ph1-pro5.c create mode 100644 drivers/pinctrl/uniphier/pinctrl-ph1-sld8.c create mode 100644 drivers/pinctrl/uniphier/pinctrl-proxstream2.c create mode 100644 drivers/pinctrl/uniphier/pinctrl-uniphier-core.c create mode 100644 drivers/pinctrl/uniphier/pinctrl-uniphier.h
On Fri, Sep 25, 2015 at 01:10:42AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
