[PATCH] sandbox, test: change hog gpio
Since commit 9ba84329dc45 ("sandbox, test: add test for GPIO_HOG function"), the gpio_a 0,1,2 and 3 are used by hog in test.dts. But 2 leds 'sandbox:red' and 'sandbox:green' are using gpio_a 0 and 1. As hog always request his gpios, the led command on both led is broken:
=> led sandbox:red LED 'sandbox:red' not found (err=-16)
The gpio is already requested by hog, so it can't be enabled for led 'sandbox:red'.
This commit change the gpio used by hog to 10, 11, 12 and 13, so the led command could be used again with 'sandbox:red' and 'sandbox:green'.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/sandbox/dts/test.dts | 8 ++++---- test/dm/gpio.c | 12 ++++++------ 2 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 2ae4239..2325ec6 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -355,22 +355,22 @@ hog_input_active_low { gpio-hog; input; - gpios = <0 GPIO_ACTIVE_LOW>; + gpios = <10 GPIO_ACTIVE_LOW>; }; hog_input_active_high { gpio-hog; input; - gpios = <1 GPIO_ACTIVE_HIGH>; + gpios = <11 GPIO_ACTIVE_HIGH>; }; hog_output_low { gpio-hog; output-low; - gpios = <2 GPIO_ACTIVE_HIGH>; + gpios = <12 GPIO_ACTIVE_HIGH>; }; hog_output_high { gpio-hog; output-high; - gpios = <3 GPIO_ACTIVE_HIGH>; + gpios = <13 GPIO_ACTIVE_HIGH>; }; };
diff --git a/test/dm/gpio.c b/test/dm/gpio.c index 2970138..b7ee8fc 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -114,21 +114,21 @@ static int dm_test_gpio(struct unit_test_state *uts) /* add gpio hog tests */ ut_assertok(gpio_hog_lookup_name("hog_input_active_low", &desc)); ut_asserteq(GPIOD_IS_IN | GPIOD_ACTIVE_LOW, desc->flags); - ut_asserteq(0, desc->offset); + ut_asserteq(10, desc->offset); ut_asserteq(1, dm_gpio_get_value(desc)); ut_assertok(gpio_hog_lookup_name("hog_input_active_high", &desc)); ut_asserteq(GPIOD_IS_IN, desc->flags); - ut_asserteq(1, desc->offset); + ut_asserteq(11, desc->offset); ut_asserteq(0, dm_gpio_get_value(desc)); ut_assertok(gpio_hog_lookup_name("hog_output_low", &desc)); ut_asserteq(GPIOD_IS_OUT, desc->flags); - ut_asserteq(2, desc->offset); + ut_asserteq(12, desc->offset); ut_asserteq(0, dm_gpio_get_value(desc)); ut_assertok(dm_gpio_set_value(desc, 1)); ut_asserteq(1, dm_gpio_get_value(desc)); ut_assertok(gpio_hog_lookup_name("hog_output_high", &desc)); ut_asserteq(GPIOD_IS_OUT, desc->flags); - ut_asserteq(3, desc->offset); + ut_asserteq(13, desc->offset); ut_asserteq(1, dm_gpio_get_value(desc)); ut_assertok(dm_gpio_set_value(desc, 0)); ut_asserteq(0, dm_gpio_get_value(desc)); @@ -137,8 +137,8 @@ static int dm_test_gpio(struct unit_test_state *uts) ut_assertok(gpio_lookup_name("hog_input_active_low", &dev, &offset, &gpio)); ut_asserteq_str(dev->name, "base-gpios"); - ut_asserteq(0, offset); - ut_asserteq(CONFIG_SANDBOX_GPIO_COUNT + 0, gpio); + ut_asserteq(10, offset); + ut_asserteq(CONFIG_SANDBOX_GPIO_COUNT + 10, gpio); ut_assert(gpio_lookup_name("hog_not_exist", &dev, &offset, &gpio));
On Fri, 24 Jul 2020 at 07:51, Philippe Reynes philippe.reynes@softathome.com wrote:
Hello Philippe,
Am 24.07.2020 um 15:51 schrieb Philippe Reynes:
Thanks!
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Philippe,
Thanks!
bye, Heiko
Heiko Schocher
Philippe Reynes
