[PATCH] env: fat: Add new lines at the end of print statements
Add some new line feeds at the end of print messages to make things easier to read on the console. The other env options do this so this is just an omission for FAT env.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- env/fat.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/env/fat.c b/env/fat.c index 9d37d26f9e..fdccd6cd2a 100644 --- a/env/fat.c +++ b/env/fat.c @@ -77,7 +77,7 @@ static int env_fat_save(void) * This printf is embedded in the messages from env_save that * will calling it. The missing \n is intentional. */ - printf("Unable to use %s %d:%d... ", + printf("Unable to use %s %d:%d... \n", CONFIG_ENV_FAT_INTERFACE, dev, part); return 1; } @@ -93,7 +93,7 @@ static int env_fat_save(void) * This printf is embedded in the messages from env_save that * will calling it. The missing \n is intentional. */ - printf("Unable to write "%s" from %s%d:%d... ", + printf("Unable to write "%s" from %s%d:%d... \n", file, CONFIG_ENV_FAT_INTERFACE, dev, part); return 1; } @@ -135,7 +135,7 @@ static int env_fat_load(void) * This printf is embedded in the messages from env_save that * will calling it. The missing \n is intentional. */ - printf("Unable to use %s %d:%d... ", + printf("Unable to use %s %d:%d... \n", CONFIG_ENV_FAT_INTERFACE, dev, part); goto err_env_relocate; } @@ -153,7 +153,7 @@ static int env_fat_load(void) * This printf is embedded in the messages from env_save that * will calling it. The missing \n is intentional. */ - printf("Unable to read "%s" from %s%d:%d... ", + printf("Unable to read "%s" from %s%d:%d... \n", CONFIG_ENV_FAT_FILE, CONFIG_ENV_FAT_INTERFACE, dev, part); goto err_env_relocate; }
It would be better to remove the comment above as well.
-Takahiro Akashi
return 1; }printf("Unable to use %s %d:%d... \n", CONFIG_ENV_FAT_INTERFACE, dev, part);
printf("Unable to write \"%s\" from %s%d:%d... ",
return 1; }printf("Unable to write \"%s\" from %s%d:%d... \n", file, CONFIG_ENV_FAT_INTERFACE, dev, part);
goto err_env_relocate; }printf("Unable to use %s %d:%d... \n", CONFIG_ENV_FAT_INTERFACE, dev, part);
printf("Unable to read \"%s\" from %s%d:%d... ",
goto err_env_relocate; }printf("Unable to read \"%s\" from %s%d:%d... \n", CONFIG_ENV_FAT_FILE, CONFIG_ENV_FAT_INTERFACE, dev, part);
-- 2.33.1
AKASHI Takahiro
Peter Robinson
