[U-Boot] [PATCH v2 1/2] linux/sizes.h: sync from kernel
The kernel added SZ_4G macro in commit f2b9ba871b (arm64/kernel: kaslr: reduce module randomization range to 4 GB).
Include common.h for _AC() instead of the kernel linux/const.h header.
Drop a local SZ_4G definition in tegra code.
Cc: Tom Warren twarren@nvidia.com Signed-off-by: Baruch Siach baruch@tkos.co.il --- v2: No change --- arch/arm/mach-tegra/tegra186/nvtboot_mem.c | 3 +-- include/linux/sizes.h | 4 ++++ 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-tegra/tegra186/nvtboot_mem.c b/arch/arm/mach-tegra/tegra186/nvtboot_mem.c index 5c9467bfe8be..62142821a595 100644 --- a/arch/arm/mach-tegra/tegra186/nvtboot_mem.c +++ b/arch/arm/mach-tegra/tegra186/nvtboot_mem.c @@ -6,11 +6,10 @@ #include <common.h> #include <fdt_support.h> #include <fdtdec.h> +#include <linux/sizes.h> #include <asm/arch/tegra.h> #include <asm/armv8/mmu.h>
-#define SZ_4G 0x100000000ULL - /* * Size of a region that's large enough to hold the relocated U-Boot and all * other allocations made around it (stack, heap, page tables, etc.) diff --git a/include/linux/sizes.h b/include/linux/sizes.h index ce3e8150c174..9f3c13ee459b 100644 --- a/include/linux/sizes.h +++ b/include/linux/sizes.h @@ -8,6 +8,8 @@ #ifndef __LINUX_SIZES_H__ #define __LINUX_SIZES_H__
+#include <common.h> + #define SZ_1 0x00000001 #define SZ_2 0x00000002 #define SZ_4 0x00000004 @@ -44,4 +46,6 @@ #define SZ_1G 0x40000000 #define SZ_2G 0x80000000
+#define SZ_4G _AC(0x100000000, ULL) + #endif /* __LINUX_SIZES_H__ */
Some Armada 8K boards like Macchiatobin and Clearfog GT-8K use RAM from external DIMM. Hard coding the RAM size in the device-tree is not convenient. Fortunately, the ATF that initializes the RAM knows the size of RAM, and U-Boot can query the ATF using a SMC call.
The ATF maps the lower 3G of RAM starting at address 0. Higher RAM is mapped at 4G. This leaves a 1G hole between 3G and 4G for IO peripherals. Use a second bi_dram[] entry to describe the higher RAM area. As a result, CONFIG_NR_DRAM_BANKS must be set to 2 to use more than 3GB RAM.
This code in this commit is mostly taken from downstream Marvell U-Boot code by Grzegorz Jaszczyk.
Cc: Grzegorz Jaszczyk jaz@semihalf.com Signed-off-by: Baruch Siach baruch@tkos.co.il --- v2: Expand memory layout description in code comment and the commit log (Stefan) --- arch/arm/mach-mvebu/arm64-common.c | 50 +++++++++++++++++++++++++++++- 1 file changed, 49 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index f47273fde9c6..47bbf69944ec 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -7,6 +7,7 @@ #include <dm.h> #include <fdtdec.h> #include <linux/libfdt.h> +#include <linux/sizes.h> #include <pci.h> #include <asm/io.h> #include <asm/system.h> @@ -45,15 +46,62 @@ const struct mbus_dram_target_info *mvebu_mbus_dram_info(void)
/* DRAM init code ... */
+#define MV_SIP_DRAM_SIZE 0x82000010 + +static u64 a8k_dram_scan_ap_sz(void) +{ + struct pt_regs pregs; + + pregs.regs[0] = MV_SIP_DRAM_SIZE; + pregs.regs[1] = SOC_REGS_PHY_BASE; + smc_call(&pregs); + + return pregs.regs[0]; +} + +static void a8k_dram_init_banksize(void) +{ + /* + * The firmware (ATF) leaves a 1G whole above the 3G mark for IO + * devices. Higher RAM is mapped at 4G. + * + * Config 2 DRAM banks: + * Bank 0 - max size 4G - 1G + * Bank 1 - ram size - 4G + 1G + */ + phys_size_t max_bank0_size = SZ_4G - SZ_1G; + + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + if (gd->ram_size <= max_bank0_size) { + gd->bd->bi_dram[0].size = gd->ram_size; + return; + } + + gd->bd->bi_dram[0].size = max_bank0_size; + if (CONFIG_NR_DRAM_BANKS > 1) { + gd->bd->bi_dram[1].start = SZ_4G; + gd->bd->bi_dram[1].size = gd->ram_size - max_bank0_size; + } +} + int dram_init_banksize(void) { - fdtdec_setup_memory_banksize(); + if (CONFIG_IS_ENABLED(ARMADA_8K)) + a8k_dram_init_banksize(); + else + fdtdec_setup_memory_banksize();
return 0; }
int dram_init(void) { + if (CONFIG_IS_ENABLED(ARMADA_8K)) { + gd->ram_size = a8k_dram_scan_ap_sz(); + if (gd->ram_size != 0) + return 0; + } + if (fdtdec_setup_mem_size_base() != 0) return -EINVAL;
v2: No change
- Size of a region that's large enough to hold the relocated U-Boot and all
- other allocations made around it (stack, heap, page tables, etc.)
I think this is moving things in the wrong direction. In fact, 2a6713b09b8da58572338abac276aa764bb6eadd took things in the wrong direction. We need to import linux/const.h (and just combine uapi/linux/const.h with linux/const.h) with the _AC macro and then add in SZ_4G.
Baruch Siach
