[U-Boot-Users] I can get u-boot working on my ixp425 board.
Hi, all,
I am trying to use u-boot on my ixp425 based board. But it seems not working properly.
I got the u-boot-1.0.0. And make clean, make ixdp425_config , and make. The 1st first time there is a "Soft FP" issue. After I changed cpu/ixp/config.mk as following
" PLATFORM_RELFLAGS += -mhard-float #Change -msoft-float to -mhard-float"
The compile was OK and I got u-boot.bin. But after I burn into flash, I can see nothing from serial port. I am sure my serial port works fine and burn into flash correctly (because I have another pre-compiled u-boot.bin onhand, that one can work). What could be the problem in the configuration or something else?
Regards & Thanks
Then your cross toolchain is misconfigured / inadequate for this job.
Don;t do this!!!
Make sure to use a toolchain that supports soft-float.
Bernieshu
