[U-Boot] [U-boot] [Patch v2] ARM: keystone: aemif: move aemif driver to drivers/memory/ti-aemif.c
Move AEMIF driver to drivers/memory/ti-aemif.c along with AEMIF definitions collected in drivers/memory/ti-aemif.h
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com ---
Based on [U-boot] [Patch v2] mtd: nand: davinci: add header file for driver definitions
arch/arm/cpu/armv7/keystone/Makefile | 1 - arch/arm/cpu/armv7/keystone/aemif.c | 71 ------------------- arch/arm/include/asm/arch-keystone/hardware-k2hk.h | 7 -- arch/arm/include/asm/arch-keystone/hardware.h | 30 ++------ board/ti/k2hk_evm/board.c | 9 +-- drivers/Makefile | 1 + drivers/memory/Makefile | 1 + drivers/memory/ti-aemif.c | 80 ++++++++++++++++++++++ drivers/memory/ti-aemif.h | 39 +++++++++++ include/configs/k2hk_evm.h | 4 ++ 10 files changed, 134 insertions(+), 109 deletions(-) delete mode 100644 arch/arm/cpu/armv7/keystone/aemif.c create mode 100644 drivers/memory/Makefile create mode 100644 drivers/memory/ti-aemif.c create mode 100644 drivers/memory/ti-aemif.h
diff --git a/arch/arm/cpu/armv7/keystone/Makefile b/arch/arm/cpu/armv7/keystone/Makefile index b1bd022..c4af252 100644 --- a/arch/arm/cpu/armv7/keystone/Makefile +++ b/arch/arm/cpu/armv7/keystone/Makefile @@ -5,7 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += aemif.o obj-y += init.o obj-y += psc.o obj-y += clock.o diff --git a/arch/arm/cpu/armv7/keystone/aemif.c b/arch/arm/cpu/armv7/keystone/aemif.c deleted file mode 100644 index 9ba1549..0000000 --- a/arch/arm/cpu/armv7/keystone/aemif.c +++ /dev/null @@ -1,71 +0,0 @@ -/* - * Keystone2: Asynchronous EMIF Configuration - * - * (C) Copyright 2012-2014 - * Texas Instruments Incorporated, <www.ti.com> - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <../drivers/mtd/nand/davinci_nand.h> - -#define AEMIF_CFG_SELECT_STROBE(v) ((v) ? 1 << 31 : 0) -#define AEMIF_CFG_EXTEND_WAIT(v) ((v) ? 1 << 30 : 0) -#define AEMIF_CFG_WR_SETUP(v) (((v) & 0x0f) << 26) -#define AEMIF_CFG_WR_STROBE(v) (((v) & 0x3f) << 20) -#define AEMIF_CFG_WR_HOLD(v) (((v) & 0x07) << 17) -#define AEMIF_CFG_RD_SETUP(v) (((v) & 0x0f) << 13) -#define AEMIF_CFG_RD_STROBE(v) (((v) & 0x3f) << 7) -#define AEMIF_CFG_RD_HOLD(v) (((v) & 0x07) << 4) -#define AEMIF_CFG_TURN_AROUND(v) (((v) & 0x03) << 2) -#define AEMIF_CFG_WIDTH(v) (((v) & 0x03) << 0) - -#define set_config_field(reg, field, val) \ - do { \ - if (val != -1) { \ - reg &= ~AEMIF_CFG_##field(0xffffffff); \ - reg |= AEMIF_CFG_##field(val); \ - } \ - } while (0) - -void configure_async_emif(int cs, struct async_emif_config *cfg) -{ - unsigned long tmp; - - if (cfg->mode == ASYNC_EMIF_MODE_NAND) { - tmp = __raw_readl(&davinci_emif_regs->nandfcr); - tmp |= (1 << cs); - __raw_writel(tmp, &davinci_emif_regs->nandfcr); - - } else if (cfg->mode == ASYNC_EMIF_MODE_ONENAND) { - tmp = __raw_readl(&davinci_emif_regs->one_nand_cr); - tmp |= (1 << cs); - __raw_writel(tmp, &davinci_emif_regs->one_nand_cr); - } - - tmp = __raw_readl(&davinci_emif_regs->abncr[cs]); - - set_config_field(tmp, SELECT_STROBE, cfg->select_strobe); - set_config_field(tmp, EXTEND_WAIT, cfg->extend_wait); - set_config_field(tmp, WR_SETUP, cfg->wr_setup); - set_config_field(tmp, WR_STROBE, cfg->wr_strobe); - set_config_field(tmp, WR_HOLD, cfg->wr_hold); - set_config_field(tmp, RD_SETUP, cfg->rd_setup); - set_config_field(tmp, RD_STROBE, cfg->rd_strobe); - set_config_field(tmp, RD_HOLD, cfg->rd_hold); - set_config_field(tmp, TURN_AROUND, cfg->turn_around); - set_config_field(tmp, WIDTH, cfg->width); - - __raw_writel(tmp, &davinci_emif_regs->abncr[cs]); -} - -void init_async_emif(int num_cs, struct async_emif_config *config) -{ - int cs; - - for (cs = 0; cs < num_cs; cs++) - configure_async_emif(cs, config + cs); -} diff --git a/arch/arm/include/asm/arch-keystone/hardware-k2hk.h b/arch/arm/include/asm/arch-keystone/hardware-k2hk.h index 7ac2662..50ce649 100644 --- a/arch/arm/include/asm/arch-keystone/hardware-k2hk.h +++ b/arch/arm/include/asm/arch-keystone/hardware-k2hk.h @@ -9,13 +9,6 @@ #ifndef __ASM_ARCH_HARDWARE_K2HK_H #define __ASM_ARCH_HARDWARE_K2HK_H
-#define K2HK_ASYNC_EMIF_CNTRL_BASE 0x21000a00 -#define DAVINCI_ASYNC_EMIF_CNTRL_BASE K2HK_ASYNC_EMIF_CNTRL_BASE -#define K2HK_ASYNC_EMIF_DATA_CE0_BASE 0x30000000 -#define K2HK_ASYNC_EMIF_DATA_CE1_BASE 0x34000000 -#define K2HK_ASYNC_EMIF_DATA_CE2_BASE 0x38000000 -#define K2HK_ASYNC_EMIF_DATA_CE3_BASE 0x3c000000 - #define K2HK_PLL_CNTRL_BASE 0x02310000 #define CLOCK_BASE K2HK_PLL_CNTRL_BASE #define KS2_RSTCTRL (K2HK_PLL_CNTRL_BASE + 0xe8) diff --git a/arch/arm/include/asm/arch-keystone/hardware.h b/arch/arm/include/asm/arch-keystone/hardware.h index 6c532ca..ffdecbf 100644 --- a/arch/arm/include/asm/arch-keystone/hardware.h +++ b/arch/arm/include/asm/arch-keystone/hardware.h @@ -22,32 +22,6 @@ typedef volatile unsigned int dv_reg; typedef volatile unsigned int *dv_reg_p;
-#define ASYNC_EMIF_NUM_CS 4 -#define ASYNC_EMIF_MODE_NOR 0 -#define ASYNC_EMIF_MODE_NAND 1 -#define ASYNC_EMIF_MODE_ONENAND 2 -#define ASYNC_EMIF_PRESERVE -1 - -struct async_emif_config { - unsigned mode; - unsigned select_strobe; - unsigned extend_wait; - unsigned wr_setup; - unsigned wr_strobe; - unsigned wr_hold; - unsigned rd_setup; - unsigned rd_strobe; - unsigned rd_hold; - unsigned turn_around; - enum { - ASYNC_EMIF_8 = 0, - ASYNC_EMIF_16 = 1, - ASYNC_EMIF_32 = 2, - } width; -}; - -void init_async_emif(int num_cs, struct async_emif_config *config); - struct ddr3_phy_config { unsigned int pllcr; unsigned int pgcr1_mask; @@ -145,6 +119,10 @@ struct ddr3_emif_config { #define KS2_UART0_BASE 0x02530c00 #define KS2_UART1_BASE 0x02531000
+/* AEMIF */ +#define KS2_AEMIF_CNTRL_BASE 0x21000a00 +#define DAVINCI_ASYNC_EMIF_CNTRL_BASE KS2_AEMIF_CNTRL_BASE + #ifdef CONFIG_SOC_K2HK #include <asm/arch/hardware-k2hk.h> #endif diff --git a/board/ti/k2hk_evm/board.c b/board/ti/k2hk_evm/board.c index 53f26b2..5dbe741 100644 --- a/board/ti/k2hk_evm/board.c +++ b/board/ti/k2hk_evm/board.c @@ -18,6 +18,7 @@ #include <asm/mach-types.h> #include <asm/arch/emac_defs.h> #include <asm/arch/psc_defs.h> +#include <../drivers/memory/ti-aemif.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -39,9 +40,9 @@ unsigned int external_clk[ext_clk_count] = { what is that */ };
-static struct async_emif_config async_emif_config[ASYNC_EMIF_NUM_CS] = { +static struct aemif_config aemif_configs[] = { { /* CS0 */ - .mode = ASYNC_EMIF_MODE_NAND, + .mode = AEMIF_MODE_NAND, .wr_setup = 0xf, .wr_strobe = 0x3f, .wr_hold = 7, @@ -49,7 +50,7 @@ static struct async_emif_config async_emif_config[ASYNC_EMIF_NUM_CS] = { .rd_strobe = 0x3f, .rd_hold = 7, .turn_around = 3, - .width = ASYNC_EMIF_8, + .width = AEMIF_WIDTH_8, },
}; @@ -66,7 +67,7 @@ int dram_init(void)
gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, CONFIG_MAX_RAM_BANK_SIZE); - init_async_emif(ARRAY_SIZE(async_emif_config), async_emif_config); + aemif_init(ARRAY_SIZE(aemif_configs), aemif_configs); return 0; }
diff --git a/drivers/Makefile b/drivers/Makefile index 5d03f37..b23076f 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -14,3 +14,4 @@ obj-y += twserial/ obj-y += video/ obj-y += watchdog/ obj-$(CONFIG_QE) += qe/ +obj-y += memory/ diff --git a/drivers/memory/Makefile b/drivers/memory/Makefile new file mode 100644 index 0000000..9bfb9c7 --- /dev/null +++ b/drivers/memory/Makefile @@ -0,0 +1 @@ +obj-$(CONFIG_TI_AEMIF) += ti-aemif.o diff --git a/drivers/memory/ti-aemif.c b/drivers/memory/ti-aemif.c new file mode 100644 index 0000000..0877183 --- /dev/null +++ b/drivers/memory/ti-aemif.c @@ -0,0 +1,80 @@ +/* + * Keystone2: Asynchronous EMIF Configuration + * + * (C) Copyright 2012-2014 + * Texas Instruments Incorporated, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include "ti-aemif.h" + +#define AEMIF_WAITCYCLE_CONFIG (CONFIG_AEMIF_CNTRL_BASE + 0x4) +#define AEMIF_NAND_CONTROL (CONFIG_AEMIF_CNTRL_BASE + 0x60) +#define AEMIF_ONENAND_CONTROL (CONFIG_AEMIF_CNTRL_BASE + 0x5c) +#define AEMIF_CONFIG(cs) (CONFIG_AEMIF_CNTRL_BASE + 0x10 \ + + (cs * 4)) + +#define AEMIF_CFG_SELECT_STROBE(v) ((v) ? 1 << 31 : 0) +#define AEMIF_CFG_EXTEND_WAIT(v) ((v) ? 1 << 30 : 0) +#define AEMIF_CFG_WR_SETUP(v) (((v) & 0x0f) << 26) +#define AEMIF_CFG_WR_STROBE(v) (((v) & 0x3f) << 20) +#define AEMIF_CFG_WR_HOLD(v) (((v) & 0x07) << 17) +#define AEMIF_CFG_RD_SETUP(v) (((v) & 0x0f) << 13) +#define AEMIF_CFG_RD_STROBE(v) (((v) & 0x3f) << 7) +#define AEMIF_CFG_RD_HOLD(v) (((v) & 0x07) << 4) +#define AEMIF_CFG_TURN_AROUND(v) (((v) & 0x03) << 2) +#define AEMIF_CFG_WIDTH(v) (((v) & 0x03) << 0) + +#define set_config_field(reg, field, val) \ + do { \ + if (val != -1) { \ + reg &= ~AEMIF_CFG_##field(0xffffffff); \ + reg |= AEMIF_CFG_##field(val); \ + } \ + } while (0) + +static void aemif_configure(int cs, struct aemif_config *cfg) +{ + unsigned long tmp; + + if (cfg->mode == AEMIF_MODE_NAND) { + tmp = __raw_readl(AEMIF_NAND_CONTROL); + tmp |= (1 << cs); + __raw_writel(tmp, AEMIF_NAND_CONTROL); + + } else if (cfg->mode == AEMIF_MODE_ONENAND) { + tmp = __raw_readl(AEMIF_ONENAND_CONTROL); + tmp |= (1 << cs); + __raw_writel(tmp, AEMIF_ONENAND_CONTROL); + } + + tmp = __raw_readl(AEMIF_CONFIG(cs)); + + set_config_field(tmp, SELECT_STROBE, cfg->select_strobe); + set_config_field(tmp, EXTEND_WAIT, cfg->extend_wait); + set_config_field(tmp, WR_SETUP, cfg->wr_setup); + set_config_field(tmp, WR_STROBE, cfg->wr_strobe); + set_config_field(tmp, WR_HOLD, cfg->wr_hold); + set_config_field(tmp, RD_SETUP, cfg->rd_setup); + set_config_field(tmp, RD_STROBE, cfg->rd_strobe); + set_config_field(tmp, RD_HOLD, cfg->rd_hold); + set_config_field(tmp, TURN_AROUND, cfg->turn_around); + set_config_field(tmp, WIDTH, cfg->width); + + __raw_writel(tmp, AEMIF_CONFIG(cs)); +} + +void aemif_init(int num_cs, struct aemif_config *config) +{ + int cs; + + if (num_cs > AEMIF_NUM_CS) { + num_cs = AEMIF_NUM_CS; + printf("AEMIF: csnum has to be <= 5"); + } + + for (cs = 0; cs < num_cs; cs++) + aemif_configure(cs, config + cs); +} diff --git a/drivers/memory/ti-aemif.h b/drivers/memory/ti-aemif.h new file mode 100644 index 0000000..4a311d4 --- /dev/null +++ b/drivers/memory/ti-aemif.h @@ -0,0 +1,39 @@ +/* + * AEMIF definitions + * + * (C) Copyright 2012-2014 + * Texas Instruments Incorporated, <www.ti.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _AEMIF_H_ +#define _AEMIF_H_ + +#define AEMIF_NUM_CS 4 +#define AEMIF_MODE_NOR 0 +#define AEMIF_MODE_NAND 1 +#define AEMIF_MODE_ONENAND 2 +#define AEMIF_PRESERVE -1 + +struct aemif_config { + unsigned mode; + unsigned select_strobe; + unsigned extend_wait; + unsigned wr_setup; + unsigned wr_strobe; + unsigned wr_hold; + unsigned rd_setup; + unsigned rd_strobe; + unsigned rd_hold; + unsigned turn_around; + enum { + AEMIF_WIDTH_8 = 0, + AEMIF_WIDTH_16 = 1, + AEMIF_WIDTH_32 = 2, + } width; +}; + +void aemif_init(int num_cs, struct aemif_config *config); + +#endif diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index 6ba7e62..7952036 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -129,6 +129,10 @@ #define CONFIG_SYS_SGMII_LINERATE_MHZ 1250 #define CONFIG_SYS_SGMII_RATESCALE 2
+/* AEMIF */ +#define CONFIG_TI_AEMIF +#define CONFIG_AEMIF_CNTRL_BASE KS2_AEMIF_CNTRL_BASE + /* NAND Configuration */ #define CONFIG_NAND_DAVINCI #define CONFIG_CMD_NAND_ECCLAYOUT
Ivan Khoronzhuk
